Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Help Forums - Styling & Electrical > Misc Electrical & Gauges
Misc Electrical & Gauges Post your speedometer, gauges, interior and non audio/video questions here.
Reply
Thread Tools Display Modes
Old 09-29-2010, 12:38 AM   #1
fire57dan
Vehicle Year: 1986
Vehicle Make: Ford
Vehicle Model: Ranger 4x4
I use this vehicle for: Gets better mileage than the Powerstroke!
fire57dan is on a distinguished road
Default Pulse wiper setting
I have an 86 ranger and the wiper only works on the fast setting, The pulse anf medium setting does not work at all. I figured it was the switch so I repaced that with a new one and still no change. I just found out about the wiper relay did not think of that before, Is it more likely that the relay is out or the motor?
Thanks,
Dan
__________________
1986 Ranger 4x4 4'' rough country lift, 31'' BFG Mud Terrains on Black Crawlers. Manual BW-1354 t-case swap, Painted Machine Gray, Custom fabricated headache rack and tailgate, Flowmaster dual exhaust 40 series, Brush guard, Galaxy 979 with dual whips, duraback coated front bumper, 100 gal transfer tank, electric cooling pusher fan.
fire57dan is offline   Reply With Quote
Advertisement (Not shown to 'Premium Members')
Old 09-29-2010, 11:43 AM   #2
rtg143
rtg143's Avatar
Vehicle Year: 2002
Vehicle Make: Ford
Vehicle Model: F150 XLT
rtg143 has a brilliant futurertg143 has a brilliant futurertg143 has a brilliant futurertg143 has a brilliant futurertg143 has a brilliant futurertg143 has a brilliant futurertg143 has a brilliant futurertg143 has a brilliant futurertg143 has a brilliant futurertg143 has a brilliant futurertg143 has a brilliant future
Default
Probably the wiper relay.
__________________
Bert
rtg143 is offline   Reply With Quote
Old 09-29-2010, 12:40 PM   #3
jhammel85
Lurker
Posts: n/a
Default
I would rule out the motor and say it could be the relay not switching on like it should.
Old 10-02-2010, 01:07 AM   #4
fire57dan
Vehicle Year: 1986
Vehicle Make: Ford
Default
ok sounds logical because the motor is plenty strong on the fast setting.
__________________
Old 10-02-2010, 02:05 AM   #5
kimcrwbr1
kimcrwbr1's Avatar
Vehicle Year: 1983
Vehicle Make: ford
Vehicle Model: ranger
I use this vehicle for: DD tow boat
kimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to behold
Default
It is possibly the govenor (relay). I added the delay wipers on my 83 I had to get the switch and the govenor. It plugged right in and works great. The govenor on mine was by the fuse block under the dash. Check your connectors for corrosion there are 4 wires to the motor red is hot all the time the key is on if your getting power in low and high positions it is the motor if not it is in the wires switch or govenor. I believe wht is high and dk/blu is low/pulse but not sure. Does the govenor click when have it on delay. I fought it forever trying to use a aftermarket delay finally went to the bone yard and pulled the govenor and switch and plugged it right in. I mounted the govenor on the duct for the floor vent it needs a good ground for it to work another possible problem.
__________________
it takes a nickle to go first class
when it stops hurting it will feel alot better
kimcrwbr1 is offline   Reply With Quote
Old 10-10-2010, 02:55 PM   #6
fire57dan
Vehicle Year: 1986
Vehicle Make: Ford
Default
I got a used relay and installed it. Works great now. Thanks for all the help.
__________________
Old 10-10-2010, 07:46 PM   #7
jhammel85
Lurker
Posts: n/a
Default
Awesome! Thanks for posting your results.
Old 10-10-2010, 08:05 PM   #8
kimcrwbr1
kimcrwbr1's Avatar
Vehicle Year: 1983
Vehicle Make: ford
Default
Yea the only place I could find mine was at the bone yard glag you got it working.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
