Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 10-11-2010, 06:13 PM   #1
84stealthranger
84stealthranger's Avatar
Vehicle Year: 1984
Vehicle Make: ford
Vehicle Model: ranger
I use this vehicle for: DD and some off road when i get a chance
84stealthranger will become famous soon enough
Send a message via AIM to 84stealthranger Send a message via Yahoo to 84stealthranger Send a message via Skype™ to 84stealthranger
Question jeep dana 30 swap who's done it?
well im pretty locked on doing this swap if i can find a front axle. the dana 30 seems to be plenty strong with the right upgrades. i was thinking of just running 33s or 35s for now. does any one know what axle year i need to use coils? or should i do a leaf spring swap?
__________________
1984 4wd ranger reg. cab 3" body lift 31x10.50s mud claw radial M/Ts
Originally Posted by pillen140
tell them its not a brake line..... its a suspension limiting strap, lol.
Quote:
Originally Posted by 91rangerxlt View Post
slap her, take her clothes off, stick it in er and pee!!!
84stealthranger is offline   Reply With Quote
Advertisement (Not shown to 'Premium Members')
Old 10-11-2010, 06:16 PM   #2
Bennybooster
Bennybooster's Avatar
Vehicle Year: 1996
Vehicle Make: Ford
Vehicle Model: Ranger
I use this vehicle for: Driving over stuff
Bennybooster is a splendid one to beholdBennybooster is a splendid one to beholdBennybooster is a splendid one to beholdBennybooster is a splendid one to beholdBennybooster is a splendid one to beholdBennybooster is a splendid one to behold
Default
search button
__________________
Built not bought
1 Ton, Caged Ranger build
Bennybooster is offline   Reply With Quote
Old 10-11-2010, 06:18 PM   #3
84stealthranger
Vehicle Year: 1984
Vehicle Make: ford
Default
Quote:
Originally Posted by Bennybooster View Post
search button
ahaha i just posted to see if any one on here has done it and if they liked it or not.
__________________
Old 10-11-2010, 06:30 PM   #4
84stealthranger
Vehicle Year: 1984
Vehicle Make: ford
Default
and the reason for a dana 30 is i dont want full size axles..well not yet any ways i wanna keep it on the road for a while and i dont wanna have to get new rims and tires as soon as i put it in. im easy on the gas and from what ive read its just as strong as a dana 35 and thats all i really need. im going for front end flex i have tons of rear flex and no front. i just dont see much flex in a ttb set up unless i put a expensive custom lift kit in.
__________________
Old 10-11-2010, 08:54 PM   #5
4x4junkie
Mall-Rated
4x4junkie's Avatar
Vehicle Year: 1990,1994
Vehicle Make: Ford
Vehicle Model: Bronco II, Ranger
I use this vehicle for: Crawling over things
4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold4x4junkie is a splendid one to behold
Default
The best D30 ('95-'99 XJ) is still a hair under that of the D35, mainly due to the smaller R&P gears (I've seen them strip teeth on occasion). 33s should be fine on it, but I'd be hesitant to use anything bigger with it under an RBV (yeah I know Jeep guys run 35s on it all the time, Jeeps are also lighter up front). There are at least a few D30s in use under RBVs however. I'd suggest looking in the RBVs Under Construction section, I recall see at least one right near the top there just recently.
Quote:
I've got maybe $700 into mine... Not exactly "expensive" (you'll usually blow past that with a SAS), however no doubt it is pretty custom (at least in application of parts used, not so much the parts themselves... Most are available for purchase although I did make a lot of it myself such as the radius arms which kept the cost down somewhat).
__________________
'90 Bronco II XLT
5" lift (Skyjacker Jeep coils), D35 & 8.8" w/5.13s (locked), 1354 dual T-case, 35x12.50s
'94 Ranger XLT
6" Skyjacker, ARB D44 front, Detroit 8.8" rear, Atlas 4.3, 33s
4x4junkie is offline   Reply With Quote
Old 10-11-2010, 10:35 PM   #6
Todd
HCT
Todd's Avatar
Vehicle Year: 90/91/99/04
Vehicle Model: BII/Ranger
I use this vehicle for: Da bush
Todd will become famous soon enough
Default
The TTB can flex. I didnt have a lot of money into mine and was very happy with it.
Only reason I went strait 1 tons was the strength. I was starting to ask more of the 35 then what it could handle.
__________________
Rig: BIITR, BII frame Ranger cab, Wontons, Winches, Transfer cases, Batteries, 40's. None street legal.
Todd is offline   Reply With Quote
Old 10-12-2010, 03:38 AM   #7
dangerranger83
5.0 HO under the hood!!!
dangerranger83's Avatar
Vehicle Year: 1983
Vehicle Make: Ford
I use this vehicle for: My DD, play toy
dangerranger83 has much to be proud ofdangerranger83 has much to be proud ofdangerranger83 has much to be proud ofdangerranger83 has much to be proud ofdangerranger83 has much to be proud ofdangerranger83 has much to be proud ofdangerranger83 has much to be proud ofdangerranger83 has much to be proud ofdangerranger83 has much to be proud of
Send a message via Skype™ to dangerranger83
Default
I hope to be putting my D30 under my truck in the next few weeks, just got the rest of the stuff needed to get it started to be put under my truck.
__________________
Build thread, 5.0 swap happening now!!!! Click me
5.0 HO carbed, np435 with an np208 transfercase, 32 inch BFGoodrich M/T's, D30 SAS with 6.5 XJ coils, 63 inch leaves in rear.
dangerranger83 is offline   Reply With Quote
Old 10-12-2010, 08:57 PM   #8
BowTech99
BowTech99's Avatar
Vehicle Year: 1999 and 1998
Vehicle Make: Ford
I use this vehicle for: Making people ask, Are you crazy?!?
BowTech99 is on a distinguished road
Default
Stay out the rocks with it and 36's are fine. Muds alot easier on parts.
Anything bigger than 33 in the rocks and not so good. Good axle, and plenty of aftermarket, just cost $$ to get one right.
__________________
A word to the wise ain't neccasary, its the stupid ones that need it
BowTech99 is offline   Reply With Quote
Old 11-22-2010, 11:53 PM   #9
#1greenranger
Junior Member
#1greenranger's Avatar
Vehicle Year: 1998
Vehicle Make: Ford
#1greenranger is on a distinguished road
Default
heres an 05 with a D30 5inch lift rocking 38 15.50's as a daily and beat to death on the trails and hasnt broke anything yet with rocking the38's for 30,000 miles
__________________
3inch body
1inch t-bar
35's
#1greenranger is offline   Reply With Quote
Old 11-23-2010, 12:26 AM   #10
r1hatman
r1hatman's Avatar
Vehicle Year: 1983
Vehicle Make: ford
Vehicle Model: ranger 4x4
I use this vehicle for: daily driver
r1hatman will become famous soon enough
Default
Here you go;
http://knoxville.craigslist.org/pts/2074635366.html
__________________
R1hatman
r1hatman is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
