Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 10-12-2010, 09:13 PM   #1
Mike Tonon
Mike Tonon's Avatar
Vehicle Year: 2007
Vehicle Make: Ford
Vehicle Model: Ranger
Mike Tonon is on a distinguished road
Default I need coolant, what kind???
The book says yellow, will green work? Also, the truck is 3 1/2 years old with 20,000 miles. should it be changed yet?
Mike Tonon is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 10-12-2010, 10:12 PM   #2
JohnnyO
Moderator Emeritus
JohnnyO's Avatar
Vehicle Year: 2008
Vehicle Make: Ford
Vehicle Model: Sport Trac
I use this vehicle for: Daily Driver
JohnnyO is a splendid one to beholdJohnnyO is a splendid one to beholdJohnnyO is a splendid one to beholdJohnnyO is a splendid one to beholdJohnnyO is a splendid one to beholdJohnnyO is a splendid one to beholdJohnnyO is a splendid one to behold
Default
I always use the Prestone that says it's compatible with anything. Flush it good with water first. 20,000 isn't a lot of miles but the time can still cause electrolysis because of the different metals it's exposed to, so after 3 1/2 years I'd say change it. In my vehicles I flush them with tap water but use distilled water for the final fill with the antifreeze.
__________________
'08 Sport Trac, custom 2.5" single exhaust with Flowmaster DBX muffler, K&N, Firestone Destination A/T's, Truxxx 2.5"/1.5" strut lift.
JohnnyO is offline   Reply With Quote
Old 10-12-2010, 10:23 PM   #3
exbass94
exbass94's Avatar
Vehicle Year: 2006, 1994
Vehicle Make: Ford
Vehicle Model: Ranger, Explorer
I use this vehicle for: Pavement Poundin'
exbass94 is just really niceexbass94 is just really niceexbass94 is just really niceexbass94 is just really niceexbass94 is just really nice
Default
Use Zerex G-05 ONLY. Available at Napa. (Napa part #ZXG051)
Or go to the Ford dealer and pick up some Motorcraft Premium Gold coolant. The "all makes/models" is NOT the right stuff, and is not compatible with the factory coolant!
One more thing, color means nothing. Just because two coolants are yellow, doesn't necessarily mean they have the same chemistry and are compatible.
I'd say it's a little early to change it. It certainly wouldn't hurt to do it now, but it'll still be good for another year or two.
__________________
2006 Ford Ranger Sport 4x4 2-dr Extended Cab, 63k miles
1994 Ford Explorer Sport 2-dr 4x4, 203k miles
1992 Honda Accord EX, 182k miles
1994 Ford Bronco XLT (project)
2014 Subaru XV Crosstrek, 33k miles (wife's)
exbass94 is offline   Reply With Quote
Old 10-13-2010, 06:02 PM   #4
nitrofan1
Man without a Ranger
nitrofan1's Avatar
Vehicle Year: 2000
Vehicle Make: Subaru
Vehicle Model: Forester
I use this vehicle for: Everything and then some
nitrofan1 is a jewel in the roughnitrofan1 is a jewel in the roughnitrofan1 is a jewel in the roughnitrofan1 is a jewel in the rough
Default
As long as it's a "Global" mix it will work. G5 if you want OE. Different brands may be yellow or greenish yellow. Make sure the jug says all makes all models.
__________________
No matter where you go, there you are
nitrofan1 is offline   Reply With Quote
Old 10-13-2010, 06:40 PM   #5
exbass94
exbass94's Avatar
Vehicle Make: Ford
Default
Quote:
"All makes/models" coolant is essentially the same thing as Dexcool. I would NOT put Dexcool in any vehicle that wasn't designed for it. You know that Ford is slowly switching over to Dexcool in some 2011 vehicles, particularly the new v8s in the Mustang and F150? They would have started in 2010, but the 4.6 and 5.4 v8s were NOT DESIGNED for it, so they waited one more year for the new engines to come out, which are already designed for Dexcool.
Look at the back of a jug of G-05. It specifically states it is NOT compatible with OAT (organic acid technology AKA Dexcool) coolants.
Google Dexcool sludge and see what happens when you use Dexcool in a system not designed for it. Heck, it even happens in some systems that ARE designed for it.
I'll say it one more time: Do not use "all makes/models" coolant in your truck! G-05 ONLY!!!
__________________
Old 10-13-2010, 07:18 PM   #6
Mike Tonon
Mike Tonon's Avatar
Vehicle Year: 2007
Vehicle Make: Ford
Default
I'm glad I asked about this. I thought there were only 2 or 3 types of coolant and mine looked greenish, so I was going to just use green. Then I thought I better make sure and the manual said what you guys are saying. The guy at advance auto said that the "any make and model" coolant would be fine. But the guy at napa told me its technically not.
BTW, I flushed out my 87 2.9l cooling system back in high school and put the orange stuff in. Seemed to work, but after a few years I flushed it out and put green back in. Sometimes, durng the last few years I owned it, the engine would suddenly overheat and holding the throttle usually brought it back down. Was the coolant mixture clogging the system.
thanks for the help
Old 10-13-2010, 08:31 PM   #7
rrbrian222
rrbrian222's Avatar
Vehicle Year: 1995
Vehicle Make: Ford
Vehicle Model: Ranger SuperCab
I use this vehicle for: Rust/Corrosion Experiment
rrbrian222 will become famous soon enoughrrbrian222 will become famous soon enough
Default
Here's some info I stumbled upon over the summer when I was doing my coolant change. I hadn't realized how many different blends of coolant are out there now days, but this article kinda cleared up the confusion for me. Be sure to check the links at the bottom of the article too.
http://howtomatthew.blogspot.com/200...ntifreeze.html
__________________
1995 Ranger Ext. Cab 2.3L 5 speed 2wd
White, Straight, Republican, Male. How else can I piss you off today?
rrbrian222 is offline   Reply With Quote
Old 10-13-2010, 09:27 PM   #8
nitrofan1
nitrofan1's Avatar
Vehicle Year: 2000
Default
Dexcool and global do the same job but aren't the same. Dexcool won't mix with anything. Put Dexcool into something with green or yellow antifreeze and you'll get lumpy chocolate sludge. Same if you reverse it and add something to Dexcool. Global does the 5yr 50,000 mile deal like dexcool but is Propylene Glycol. It simulates the old green Etheline Glycol without the short life span. Plus Dexcool is orange so it's easy to identify to GM owners.
And add only distilled water to antifreeze no matter what the type. Tap water's impurities will shorten the life span of any antifreeze. Or go 50/50 pre-mix.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
