Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 10-18-2010, 09:03 AM   #1
Quill
Vehicle Year: 88 Bronco II, 8
I use this vehicle for: Daily Driver
Quill is on a distinguished road
Default Transmission Additive
They replaced the transmission on my 99 Ranger automatic with one from a salvage yard. I bought this truck with a bad tranny, replaced with a used one and had to warranty it within a month because it crapped out. It's been a long time since I had an automatic. This one just seems slow. I called the shop that put it in and the guy said that is how it is. I would like to put a good additive in the trans to see if that smooths thing out. By the way it shifts fine, it's just when you put it in gear it is not super responsive. This is a 4x4 too. I have had 4 Rangers with manual transmissions prior to this. The hip starts to bother nowadays running a clutch. Thanks for any ideas.
Quill is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 10-18-2010, 11:14 AM   #2
Rearanger
Vehicle Year: 2003
Vehicle Make: Ford
Vehicle Model: Ranger 3.0L
Rearanger is on a distinguished road
Default
I'm usually not for additives but this one I used twice and it worked twice.
http://www.transmaticsc.com/
__________________
2003 3.0L Long Box, 5spd Manual, 2wd, 3.73 LS,
P235/70R-16, Synthetic fluids, 91.5k miles
Rearanger is offline   Reply With Quote
Old 10-21-2010, 08:46 PM   #3
Quill
Default
Yeah I am not much for additives. I am thinking more of switching to Redline fluid.
Old 10-21-2010, 09:44 PM   #4
barrys
barrys's Avatar
Vehicle Year: 2010
Vehicle Make: Ford
Vehicle Model: Ranger XLT
I use this vehicle for: Daily driver and being a "friend with a truck"
barrys is on a distinguished road
Default
I have no experience to comment on the additives. I have heard some stories of additives freeing up bits of gunk that move to cause more trouble than their sitting where they're at. That might be why others don't recommend them. But, mine is the opinion of a forum reader only...
I think it's just a bit of a clunky, slow shifting automatic. I've been driving mine for about 8 years and have a Honda CR-V (not that smooth either), and had a VW Passat (an Autobahn dream tranny with tiptronic). Both of those make the Ranger seem to shift more like me on a manual when I was 17. Sometimes my 1st to 2nd rolling shift feels like someone dropped the clutch.
Anyway, even though I'm rambling, I think it's just the nature of the beast. I would definitely do a tranny service (drain, refill, replace filter and gasket) if you haven't, and make sure it's done as per procedure by someone who knows what they're doing -- which could be you. That helps mine a lot every 30K.
barrys is offline   Reply With Quote
Old 10-21-2010, 09:58 PM   #5
-Nathan-
Premium Member
-Nathan-'s Avatar
Vehicle Year: 1993 / 2001
Vehicle Make: Ford
Vehicle Model: Ranger / F-250
I use this vehicle for: prerunner/ daily driver-tow rig
-Nathan- is a jewel in the rough-Nathan- is a jewel in the rough-Nathan- is a jewel in the rough
Default
Ive used Lucas trans fix, worked good. Any additive however is usually just a band-aid solution.
__________________
1993 Ford Ranger - 5.0 / M5OD-R2 / BW 1356 / long travel Dana 54 TTB / Sterling 10.25 ........go-fast trailrunner/prerunner
2001 Ford F-250 4x4 - 7.3 Powerstroke Diesel - ZF-6 speed - bunch of goodies ........daily driver/tow rig
-Nathan- is offline   Reply With Quote
Old 10-27-2010, 10:19 PM   #6
Runnin'OnEmpty
Junior Member
Vehicle Year: 2004
Vehicle Make: Ford
Vehicle Model: Ranger Edge
Runnin'OnEmpty is on a distinguished road
Lightbulb
If the trans has a delayed low/reverse engagement, you can
improve it by replacing the low/reverse servo O-ring. The servo
is located behind the valve body and can be serviced when the
pan is dropped. It's as easy as replacing the filter. A lot of gunk
accumulates at the bottom of the servo housing, and can be
cleaned out at the same time.
There's also a Superior shift kit available for the 5R44E that
helps with lazy shifts.
I use LubeGard in the red bottle in all my automatics.
ROE
Runnin'OnEmpty is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
