Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 10-24-2010, 09:18 PM   #1
Brandon12
Brandon12's Avatar
Vehicle Year: 1988/91
Vehicle Make: Ford
Vehicle Model: Ranger STX/Explorer E.B
I use this vehicle for: DD/Trails/Showing up Toyotas
Brandon12 is on a distinguished road
Default Wont go into gear (automatic)
I just pulled out the bad tranny on my 91 explorer 4x4 and put in a new one from a junk yard that supposedly works. I got everything hooked up and the tranny is full on fluid and it sounds fine when i start it but when i put it into any gear it does nothing. You can see underneath that it is shifting it when i move the never but it just seems like it stays in park and does nothing but rev up. Tried in all ranges with the transfer case and nothing. What could be wrong?
__________________
Quote:
Originally Posted by IRKillroy View Post
you did... you built a damn plane!!!
Quote:
Originally Posted by Doom's Day Custom View Post
well i just pulled it out and chased her around the house until she play with it .....
Brandon12 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 10-25-2010, 04:23 PM   #2
Brandon12
Brandon12's Avatar
Vehicle Make: Ford
Default
pulled the filter off and it seems to be ok but going to replace it. Could the tourque converter be bad or the pump? How do you tell? Please help
__________________
Old 10-25-2010, 04:30 PM   #3
RangerSVT
Oct 09 OTOTM
RangerSVT's Avatar
Vehicle Year: 1996 2002
Vehicle Make: Ford
Vehicle Model: SAS Ranger SC 4x4 V8 Sport Trac
I use this vehicle for: Anger Management
RangerSVT is a splendid one to beholdRangerSVT is a splendid one to beholdRangerSVT is a splendid one to beholdRangerSVT is a splendid one to beholdRangerSVT is a splendid one to beholdRangerSVT is a splendid one to beholdRangerSVT is a splendid one to beholdRangerSVT is a splendid one to behold
Send a message via Yahoo to RangerSVT
Default
It is possible its the TC, you did get the one with the trans from the JY, right?? If you remove one of the cooling lines from the radiator and start the truck, if the pump is good it will shoot out fluid...You may have a bad trans
SVT
__________________
Ranger V8 Swap Expert
Member of the Turkey Bay Crew
SVT Build Thread (96 V8 Ranger)
ST Build Thread (02 V8 Sport Trac)
V8 swap Club/Info
Tuning with SCT
RangerSVT is offline   Reply With Quote
Old 10-25-2010, 04:50 PM   #4
feellnfroggy
feellnfroggy's Avatar
Vehicle Year: 1993
Vehicle Make: Ford
I use this vehicle for: DD for right now.
feellnfroggy is a jewel in the roughfeellnfroggy is a jewel in the roughfeellnfroggy is a jewel in the rough
Send a message via AIM to feellnfroggy
Default
Bad tranny is what Im thinking, this is what Hatmans c4 was doing and his direct drive clutches were fried, but he had reverse. If you have nothing at all then im thinkin TC or hydraulics.
Not to ask the obvious, but did you double check the shifter cable? Are any rubber grommets in their mounting points properly? Just like the old cable clutches if they are sitting in their mounts the cable just flops.
__________________
This signature has encountered technical difficulties...
Quote:
Originally Posted by Hopman View Post
Like I say to the newbies who join us: "Pull up a chair, grab a cold drink, & watch for low-flying BS!!!!"
Quote:
Originally Posted by Shran View Post
Used to happen to my mom's Grand Marquis all the time when we took it offroad. Don't worry about it.
Agreed. "Whiskey Tango Foxtrot" doesn't begin to cover the ugliness of this thing.
feellnfroggy is offline   Reply With Quote
Old 10-25-2010, 04:50 PM   #5
Brandon12
Brandon12's Avatar
Vehicle Make: Ford
Default
Ok so if i pull that line off and fluid shoots out my pump is good. How do i tell if the torque converter is bad? would it be easier (cheaper, less time) to just put in another tranny than try to rebuild that one? And in a 91 explorer 4x4 that would be an A4LD correct?
__________________
Old 10-25-2010, 04:51 PM   #6
Brandon12
Brandon12's Avatar
Vehicle Make: Ford
Default
Checked the cable and everything moves when you pull the shift lever so its trying to change the gear on the outside but nothing happens inside the tranny
__________________
Old 10-25-2010, 06:57 PM   #7
RangerSVT
Oct 09 OTOTM
RangerSVT's Avatar
Vehicle Make: Ford
Default
Correct, you have the A4LD...unfortunately those trannies are problematic, and don't last long on the mileage, at least from my own experience...I've been through 2 of them, I can say the 91-94 A4LD's out of the explorers are better than the ones in the earlier rangers and B2's...The TC will need to be taken to a trans shop to have it tested, not really a way for the DIY'er to test it...
SVT
__________________
V8 swap Club/Info
Tuning with SCT
Old 10-25-2010, 09:32 PM   #8
Brandon12
Brandon12's Avatar
Vehicle Make: Ford
Default
Alright thanks. Think it would be more cost efficient to rebuild the tranny or replace it with another one that "works" like the one i already bought?
__________________
Old 10-25-2010, 09:50 PM   #9
RangerSVT
Oct 09 OTOTM
RangerSVT's Avatar
Vehicle Make: Ford
Default
I say get it rebuilt, since any JY or used A4LD will likely have mid to high mileage and would be unknown the remaining lifespan would be, if you get it rebuilt, you'd know you have at least 5 years of use, depending on mileage driven
SVT
__________________
V8 swap Club/Info
Tuning with SCT
Old 10-25-2010, 11:32 PM   #10
Brandon12
Brandon12's Avatar
Vehicle Make: Ford
Default
Alright, THANKS SVT!!
I appreciate the help
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
