Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 01-21-2008, 08:25 PM   #1
BIIHawg
December OTOTM Winner
BIIHawg's Avatar
Vehicle Year: 1989
Vehicle Make: Ford
Vehicle Model: Bronco II
BIIHawg is on a distinguished road
Default 4.0L Performance mods???
I'm gonna be rebuilding a 1991 4.0L OHV to throw in the old B2. Any suggestions (other than the Morana stroker kit) to help build some horsepower and torque. Flat top pistons?, performance cams?, chips?, or anything else anyone has done od heard of/seen and where I might be able to purchase such items. Any help would be much appreciated?
Oh, and cone filter, hedders and electirc fan are already checked off the list.
Thanks
BIIHawg is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 01-22-2008, 12:09 AM   #2
bandit
bandit's Avatar
Vehicle Year: 87
Vehicle Make: ford
Vehicle Model: Bronco 2
bandit is on a distinguished road
Send a message via AIM to bandit
Default
james duff had chips for them dont know if they still carry them
__________________
13' f-250 superduty fx4 powerstroke(dd&tow rig)
95' ranger supercab stx 4x4(offroader)
06' ranger fx4(wifes)
bandit is offline   Reply With Quote
Old 01-22-2008, 07:07 AM   #3
mxracer652
Vehicle Year: 04
Vehicle Model: Ranger
I use this vehicle for: Making fun of rice
mxracer652 is on a distinguished road
Default
If you're going to rebuild it anyway , have the stock crank (2.123" journal, I believe) offset ground down to a 2" rod journal, picking up somewhere around .100" stroke. This costs no more than turning the crank, which you were going to have to do anyway.
Buy a set of off the shelf 5.7" SBC rods with a 2" big end, a quality forged Scat set will run you about $160 (cheaper than you can buy reman stock junk). A call to Wiseco for a custom 1.4xx" c/h piston (should be around $500). And you have one very light rotating assembly, that is more reliable, and less expensive than a stock rebuild.
You now have a 4.18L stroker kit for less than $1000 including bearings and gaskets. The machine work is a wash because you were going to have to do that anyway.
__________________
04 xlt, 4.10, 5spd
M90, around 10psi
E85
Tweecer R/T
Some other stuff
mxracer652 is offline   Reply With Quote
Old 01-22-2008, 09:54 AM   #4
MAKG
RBV Technical Advisor
Vehicle Year: 1991
Vehicle Make: Ford
Vehicle Model: Explorer
MAKG will become famous soon enough
Default
You forgot the custom cam grind.
'Cause changing the stroke like that is going to change the cam you need in order to make anywhere near the full 5% effect you're looking for. Of course, you'll never feel 5% with an ass dyno, so you really have no idea.
And weakening the crank doesn't seem like a very good idea for an effect that can't be felt.
This is a SYSTEM and by shotgunning modifications, you are not going to do much (if any) good. You CAN make it worse.
__________________
1990 VW Jetta GL, 1.8L 8V gasoline engine, manual transmission, painted in oxidized red paint and ponderosa pine sap, unknown mileage.
1991 Exploder, 4.0L, M5OD-R1 manual transmission, electronic BW1354 transfer case, 3.54 gears, 31 inch tires, icky two-tone blue paint with little clear coat, 230K miles.
1972 Chevy C-10, 250 I-6, SM465 (2WD) four-on-the-floor, 3.73 gears in a GM 12-bolt, puke green with a white cab. The "4 wheeled trash can," with x70K miles. x is probably 2.
MAKG is offline   Reply With Quote
Old 01-22-2008, 10:04 AM   #5
Monzilla
Junior Member
Monzilla's Avatar
Vehicle Year: 1989
Vehicle Make: Ranger
Vehicle Model: Std. Cab Short Box
I use this vehicle for: Asphalt Circle Track
Monzilla is on a distinguished road
Default
Those pistons are a 4.000" bore 1.425" pin height. They are used with a 350sbc block, 400sbc crank (3.750" stroke) and 5.7 rods to make a 377 stroker. Or the .030" overbore makes the common 383 stroker. Find some chevy guys with blown up engines. Collect 6 rods. Then 6 pistons. Then machine work. Then let me know if it works.
Monzilla is offline   Reply With Quote
Old 01-22-2008, 10:41 AM   #6
Bird
Bird is on a distinguished road
Default
Quote:
And when you overbore the 4.0 block to accept those pistons and start pressurizing your cooling system, then you will realize it's not worth it - would have to have custom pistoms made specifically for the bore of our engines for it to be marginally 'feasible'.
I prefer 'artificial' displacement.....aka: forced induction.
Bird
__________________
93 Splash - 4.0 SOHC, C-4 tranny, 4.10 Auburn LS, M-112
01 Lightning - built 5.4, Whipple , 2600 stall TC, Bassani Exhaust
1998 SS Camaro - never knew killing Cobras would be so easy.
Bird is offline   Reply With Quote
Old 01-22-2008, 10:48 AM   #7
mxracer652
Vehicle Year: 04
Default
Quote:
Your previous cam points are valid, but for less money and better pieces, why not take the free cubes? Shit, I'm running 10psi on my SOHC with the stock cams, it's not ideal, but it does make more power. I would have 2 ground, but no blanks are made, and I'm not using reduced base circle garbage. I agree it is not optimal, but I hardly would accept it running worse.
There's nothing to be scared of with a 2" journal, the radius is the key. Look at all the cast crank 347s & SBCs out there living above 6500. A measly 180 hp (at best) below 6000 isn't going to do anything.
Monzilla,
I'd be hesitant to go to 4.000" bore, that's .050 over, and I don't think the walls would sonic that far. I don't know if it can be decked down to that c/h, trust me, I've thought of the OTS SBC rebuild stuff before.
__________________
04 xlt, 4.10, 5spd
M90, around 10psi
E85
Tweecer R/T
Some other stuff
Old 01-22-2008, 01:56 PM   #8
Monzilla
Junior Member
Monzilla's Avatar
Vehicle Year: 1989
Default
Most publications say not to overbore small block fords past .030". Ive had 351W done to .060" with 11:1 pistons. As long as its a naturally aspirated engine, not forced induction or additive like NOS or nitropropane, I dont see any forseen problems.
Live on the edge. Try something new. Henry Ford didnt create this corporation by saying, "It might have to thin of metal. I think we should be safe and not do it."
Never know til ya try.
Old 01-22-2008, 02:38 PM   #9
Bird
Default
Guess what - it's been tried before............... Ever hear of a guy called Sven Pruitt? He's played that game before and has repeatedly stated that even .40 over on the 4.0 has caused porosity problems and ring sealing inadequacies due to cylinder wall flex at rpm. Now, get some custom pistoms made up ($$$$) that will fit the stock/.020 over bore, then you'd be OK.
Bird
__________________
Old 01-22-2008, 02:55 PM   #10
mxracer652
Vehicle Year: 04
Default
What if that N/A engine is 8300 down the straight or through the traps?
All I am saying is that if you're going to bore a block, you should get it sonic checked so that you know it doesn't suffer from a shift and that it has an acceptable amount of wall thickness left. If it sonics OK to go .050, then by all means, have at it, but I'd rather KNOW it will live than hope.
I've blown up way too many engines to guess anymore, LOL!
__________________
04 xlt, 4.10, 5spd
M90, around 10psi
E85
Tweecer R/T
Some other stuff
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
