Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 11-04-2010, 05:55 PM   #1
nctom
Vehicle Year: 1995
Vehicle Make: ford
Vehicle Model: ranger
nctom is on a distinguished road
Default engine pings
I've got a 95 Ranger 2.3 that runs great with one exception.At highway speeds with the A/C on,it pings like craky unless I'm running premium gas.It has new plugs.No help.Is this just something I have to live with?Other than that,it's a great truck.Any suggestions?
Thanks
nctom is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 11-04-2010, 06:24 PM   #2
RangerSVT
Oct 09 OTOTM
RangerSVT's Avatar
Vehicle Year: 1996 2002
Vehicle Make: Ford
Vehicle Model: SAS Ranger SC 4x4 V8 Sport Trac
I use this vehicle for: Anger Management
RangerSVT is a splendid one to beholdRangerSVT is a splendid one to beholdRangerSVT is a splendid one to beholdRangerSVT is a splendid one to beholdRangerSVT is a splendid one to beholdRangerSVT is a splendid one to beholdRangerSVT is a splendid one to beholdRangerSVT is a splendid one to behold
Send a message via Yahoo to RangerSVT
Default
The pinging you are hearing is fuel knock, when the engine is under a heavy load and is running on low octane fuel, it will "knock" or ping...You will need to run a higher octane fuel...
SVT
__________________
Ranger V8 Swap Expert
Member of the Turkey Bay Crew
SVT Build Thread (96 V8 Ranger)
ST Build Thread (02 V8 Sport Trac)
V8 swap Club/Info
Tuning with SCT
RangerSVT is offline   Reply With Quote
Old 11-07-2010, 10:06 PM   #3
steve63
steve63's Avatar
Vehicle Year: 1990
Vehicle Make: ford
I use this vehicle for: anythingandeverything
steve63 is on a distinguished road
Default
sounds like you might have some carbon deposis in youre combustion chamberss/valves ,when these deposits get hot the cause the fuel/air charge to pre-ignite causing a ping,try some fuel injection cleaner or seafoam,to clean some of those deposits out,you shouldnt need premium fuel on the 2.3 to run.
steve63 is offline   Reply With Quote
Old 11-08-2010, 06:55 AM   #4
v8318cid
Vehicle Year: 2010
Vehicle Make: Ford
Vehicle Model: Ranger XLT
I use this vehicle for: Occasional DD
v8318cid is on a distinguished road
Default
I have driven several later model Fords of various makes and engine designs. All of them pinged. Even more interesting, Ford actually discourages using high-octane fuel because they say it leads to heavy carbon deposits. Not sure I understand why... Anyway, I have a 2010 2.3 liter with 5k miles on it that pings under a moderate load. Its not horrible, but apparently its normal. Heavy pinging or knocking could suggest a timing issue, but you'll have to use your judgement as to whether you consider it harsh or not.
v8318cid is offline   Reply With Quote
Old 11-08-2010, 08:55 AM   #5
RangerSVT
Oct 09 OTOTM
RangerSVT's Avatar
Vehicle Make: Ford
Default
The heavy deposits from high octane fuel is coming from the ethanol mixture in the fuel...As far as I know, Southern States Co-op is the only fueling station (at least around northwestern TN/south-western KY) that has no ethanol mixed into the fuel...
SVT
__________________
V8 swap Club/Info
Tuning with SCT
Old 11-08-2010, 09:32 AM   #6
TastySloth
TastySloth's Avatar
Vehicle Year: 1998
Vehicle Make: Ford
I use this vehicle for: Designated Dave, Braaaping
TastySloth is on a distinguished road
Default
I have a similar issue in my '86. I already tried retarding the base timing 2 degrees, it helped but it still pings at low rpm. What should the computer should be bumping the timing to at an idle?
TastySloth is offline   Reply With Quote
Old 11-09-2010, 12:11 PM   #7
v8318cid
Vehicle Year: 2010
Vehicle Make: Ford
Default
Would love to find a no-ethanol fuel locally. No one here sells it without unless you want to buy from a no-name station whose reputation is less-than-stellar to begin with. Who knows what else you might be getting... Then again, big gov wants to up the ethanol content to 15% in the near future. That should really get the engines going eh?
Old 11-09-2010, 12:48 PM   #8
ZenXtra07
Vehicle Year: 1996
Vehicle Make: Ford
ZenXtra07 is on a distinguished road
Default
I had similar problems, then changed the timing belt and water pump and it all disappeared. Until about 20k miles later.
ZenXtra07 is offline   Reply With Quote
Old 11-09-2010, 06:08 PM   #9
RangerSVT
Oct 09 OTOTM
RangerSVT's Avatar
Vehicle Make: Ford
Default
Timing will help, but you can only get so much...
SVT
__________________
V8 swap Club/Info
Tuning with SCT
Old 11-10-2010, 06:15 PM   #10
steve63
steve63's Avatar
Vehicle Year: 1990
Vehicle Make: ford
Default
theres a variety of things that can cause pinging-timing,carbon deposits,fuel,dont know what they do to the fuel here in calif.,but mine hasnt pinged in the 5 years ive owned it,and i just use 87 octane reg. unleaded.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
