Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 11-09-2010, 03:20 PM   #1
RRTDiesel
Vehicle Year: 2000
Vehicle Make: Ford
Vehicle Model: ranger
RRTDiesel is on a distinguished road
Default how to set timing in a 2000 3.0 ford ranger
how do you set the timing in a 2000 ford ranger with 3.0 l v6?
RRTDiesel is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 11-09-2010, 04:36 PM   #2
Sasquatch_Ryda
Coast Mountain Crawlers
Sasquatch_Ryda's Avatar
Vehicle Year: 1991/2002/2008
Vehicle Make: Ford
Vehicle Model: Ranger/SportTrac/SuperDuty
I use this vehicle for: Play toy/Daily Driver/Tow Rig
Sasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud of
Send a message via MSN to Sasquatch_Ryda
Default
You don't. The PCM does.
__________________
1991 Ranger - one tons, 3 link, air shocks and 40's
2002 Explorer Sport Trac - torsion crank, body lift, 35's
2008 F350 - 6.4L Powerstoke Diesel, 35x12.50R18 Procomp Xtreem AT's on 18x9 Incubus Crushers, AFE DPF/DOC Delete pipe, H&S XRT Pro tuner, AFE Stage 2 intake
1967 Mustang Coupe - 289, c4, pretty much stock
Sasquatch_Ryda is offline   Reply With Quote
Old 11-09-2010, 05:08 PM   #3
RRTDiesel
Vehicle Year: 2000
Vehicle Make: Ford
Default
so it will set itself?
Old 11-09-2010, 05:44 PM   #4
stegomon
stegomon's Avatar
Vehicle Year: 1987/1990
Vehicle Make: fords and only
stegomon has a spectacular aura aboutstegomon has a spectacular aura aboutstegomon has a spectacular aura about
Send a message via AIM to stegomon
Default
i think you could set it by the timing chain
__________________
1988 b2. Duff lift. Dana35 swap. 5 speed swap. Locked front And back. 4.0 rad and clutch swap
Future plans are gears and tires
stegomon is offline   Reply With Quote
Old 11-10-2010, 12:37 PM   #5
TomB1269
TomB1269's Avatar
Vehicle Year: 2002, 2005, & 2
Vehicle Make: All Fords
Vehicle Model: Ranger Edge '02, Freestar '06 & The newest '05 F150 FX4 SCrew
I use this vehicle for: Original Daily Driver/New DD
TomB1269 is on a distinguished road
Default
Yup, the computer controls the timing curve to meet fuel needs at given temp, and humidity......... When you change your plugs or replace a sensor you should disconnect the battery (negative cable will do) and let it sit for a few minutes to reset the ECM/Computer.
TomB1269 is offline   Reply With Quote
Old 11-12-2010, 05:13 PM   #6
McCormack
Vehicle Year: 2000
Vehicle Make: Ford
McCormack is on a distinguished road
Default
You need either a chip or a tuner to change the timing. I've got an SCT tuner and I program the timing that I want on my home computer and load it into the SCT, then I take the tuner out to the truck ('00 Ranger) and flash the truck's PCM.
McCormack is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
