Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Help Forums - Styling & Electrical > Misc Electrical & Gauges
Misc Electrical & Gauges Post your speedometer, gauges, interior and non audio/video questions here.
Reply
Thread Tools Display Modes
Old 11-11-2010, 08:05 PM   #1
hockeyray
Vehicle Year: 1984
Vehicle Make: Ford
Vehicle Model: Bronco 2
hockeyray is on a distinguished road
Cool 84 Ford Bronco 2 Not Charging
I have a 1984 Ford Bronco 2 and have replaced the alternator, voltage regulator and the battery. I have checked to make sure it is wired correctly and it is, but at the back of the alternator I have 26 volt output and where the power wire connects to the power wire connect to the solenoid I have whatever the battery is putting out. I need help, this is my son's truck and right now he is driving my Super Duty and I want him out of it.
hockeyray is offline   Reply With Quote
Advertisement (Not shown to 'Premium Members')
Old 11-11-2010, 09:00 PM   #2
kimcrwbr1
kimcrwbr1's Avatar
Vehicle Year: 1983
Vehicle Make: ford
Vehicle Model: ranger
I use this vehicle for: DD tow boat
kimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to behold
Default
Take all the grounds apart and sand them metal to metal. Check the fusable links are you getting power from the batt to the alternator with the key off (large wire). There are actually ony two wires working from the alternator one goes to the battery and the other goes to the regulator. If you have a idiot light the third wire wht/blk goes to the regulator. It sounds like the link is blown between the battery and the alternator. A quick check for the charging system fully charge the battery. check the battery voltage say 12.8 volts start it and run it around 1500 rpm and check the batt volts it should be no higher than 2 volts over battery voltage no higher than 14.8 volts then turn the lights on high and heater on high and at 2000 rpm the batt voltage should be no lower than .5 volts over battery voltage or no lower than 13.3 volts. If it passes those two tests load/noload it is working correct.
__________________
it takes a nickle to go first class
when it stops hurting it will feel alot better
kimcrwbr1 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
