Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Help Forums - Axles, Brakes, Wheels & Tires > Ranger Axles
Ranger Axles Dana 28, Dana 35, Ford 7.5 & Ford 8.8
Reply
Thread Tools Display Modes
Old 01-23-2008, 12:03 AM   #1
Blackdog
Blackdog's Avatar
Vehicle Year: 1997
Vehicle Make: Ford
Vehicle Model: Ranger
Blackdog is on a distinguished road
Default C clip removal
I need to remove my axles. My diff has the factory LS. How can I remove the C clips? Does the S spring have to come out first?
__________________
2006 4X2 Ranger 2.3, 5 speed manual.
2004 F150 Supercab 4X4 5.3, auto.
1997 4X4 Ranger standard cab, James Duff Stage 3, 5.5" lift, Explorer rear axle with disc, Detroit Truetrac, 4:88 gears, 33" MTR's. 3.0, auto.
Blackdog is offline   Reply With Quote
Advertisement (Not shown to 'Premium Members')
Old 01-23-2008, 12:10 AM   #2
Hahnsb2
Hahnsb2's Avatar
Vehicle Year: 88-95
Vehicle Make: Ford-Dodge
Vehicle Model: BII-Dakota
I use this vehicle for: Going where I point it-Going fast
Hahnsb2 is just really niceHahnsb2 is just really niceHahnsb2 is just really niceHahnsb2 is just really niceHahnsb2 is just really nice
Send a message via AIM to Hahnsb2
Default
No, pull the bolt holding the crosspin, slid the crosspin out, push the axle in, remove c-clip, remove axle.
__________________
88 Bronco II, 4.0L, M5OD, 4.56s, Aussie Locked 8.8/D35, 1354M, 34" LTBs
95 Dakota CC, 5.2, 5 Spd, 2WD,Turbo, Megasquirt, 3.55s, Locked
Hahnsb2 is offline   Reply With Quote
Old 01-23-2008, 12:57 AM   #3
Blackdog
Blackdog's Avatar
Vehicle Year: 1997
Vehicle Make: Ford
Default
Quote:
OK, tried again and got one axle out. The other clip is a real tight fit, I'll try it again in the morning. Noticed a loose "O" ring under the C clip, what's the deal with that? Thanks
__________________
Old 01-23-2008, 01:23 AM   #4
Hahnsb2
Hahnsb2's Avatar
Vehicle Year: 88-95
Default
O-ring, I really have no idea
__________________
Old 01-23-2008, 10:09 AM   #5
metalmacguyver
Yeah, I built that.
metalmacguyver's Avatar
Vehicle Year: 1997, 1994
Vehicle Make: Ford
Vehicle Model: Ranger, F350
I use this vehicle for: Working and Wheeling
metalmacguyver is on a distinguished road
Send a message via AIM to metalmacguyver
Default
that o ring is there to hold the C-clip during assembly at the factory.
__________________
Horsepower is how fast you hit a wall. Torque is how far you move a wall.
http://www.therangerstation.com/foru...ad.php?t=21890
1994 F350 7.3L PSD, 5spd, DD/tow rig, 2wd for now...
1997 Excab/4.0/5spd/Manual1354/4.88/locked F/R /35"BFG MTs/WarnXD9000i/6"lift/HYDROBOOST!!/Extended radius arms/Wheeling only.
metalmacguyver is offline   Reply With Quote
Old 12-27-2010, 10:04 PM   #6
ehayes928
Vehicle Year: 1997
Vehicle Make: Ford
Vehicle Model: Ranger 2.3
I use this vehicle for: everything
ehayes928 is on a distinguished road
Default
is it mandatory that you have the o-rings when you put it back together? I pulled one shaft and no o-ring on the c-clip end...
ehayes928 is offline   Reply With Quote
Old 12-27-2010, 10:35 PM   #7
86 slo-vo
02/2011 OTOTM Winner
86 slo-vo's Avatar
Vehicle Year: 1994
Vehicle Make: ford
Vehicle Model: ranger
I use this vehicle for: work and play
86 slo-vo is a name known to all86 slo-vo is a name known to all86 slo-vo is a name known to all86 slo-vo is a name known to all86 slo-vo is a name known to all86 slo-vo is a name known to all
Default
no you dont need the o-rings
__________________
FORD....built without your tax dollars.
86 slo-vo is offline   Reply With Quote
Old 12-28-2010, 01:25 AM   #8
AllanD
RBV Technical Advisor
Vehicle Year: 1987... sorta
Vehicle Make: Ford
Vehicle Model: Ranger Supercab
I use this vehicle for: Roadtrip Warrior
AllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud ofAllanD has much to be proud of
Default
The O-ring just holds the C-clip in place until you give the axle shaft a good yank outwards.
It's an "assembly aid"
a Damned convenient one...
AD
__________________
These two short sentences sum up the US government's views and ideology:
1) The government tells us NOT TO JUDGE ALL MUSLIMS because of a FEW lunatics.
2) The government ENCOURAGES US TO JUDGE ALL GUN OWNERS because of a FEW lunatics.
AllanD is offline   Reply With Quote
Old 12-28-2010, 02:45 AM   #9
dangerranger83
5.0 HO under the hood!!!
dangerranger83's Avatar
Vehicle Year: 1983
Vehicle Make: Ford
I use this vehicle for: My DD, play toy
dangerranger83 has much to be proud ofdangerranger83 has much to be proud ofdangerranger83 has much to be proud ofdangerranger83 has much to be proud ofdangerranger83 has much to be proud ofdangerranger83 has much to be proud ofdangerranger83 has much to be proud ofdangerranger83 has much to be proud ofdangerranger83 has much to be proud of
Send a message via Skype™ to dangerranger83
Default
Thats good to know about the o-ring. When my rear end needed new seals put in it, we ripped it out on accident and never put a new one in but all has worked well for the last 3 years.
__________________
Build thread, 5.0 swap happening now!!!! Click me
5.0 HO carbed, np435 with an np208 transfercase, 32 inch BFGoodrich M/T's, D30 SAS with 6.5 XJ coils, 63 inch leaves in rear.
dangerranger83 is offline   Reply With Quote
Old 12-28-2010, 05:25 PM   #10
woofer2609
Vehicle Year: 2004
Vehicle Make: Mazda
Vehicle Model: B2300
I use this vehicle for: Everything, towing my boat, slide-in camper carrier, commuter, etc.
woofer2609 is on a distinguished road
Default
O-ring fits towards the wheel side of slot, with c-clip inboard of o-ring
woofer2609 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
