Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Truck Discussions (Not for tech help - Use Help Forums further down) > General Discussions
General Discussions This forum is for general discussions. If you're in need of help, post it below in the appropriate topic forum.
Reply
Thread Tools Display Modes
Old 11-25-2010, 08:31 PM   #1
Boggin
Boggin's Avatar
Vehicle Model: 89 bronco ii
I use this vehicle for: going inappropriate places
Boggin is a splendid one to beholdBoggin is a splendid one to beholdBoggin is a splendid one to beholdBoggin is a splendid one to beholdBoggin is a splendid one to beholdBoggin is a splendid one to behold
Send a message via AIM to Boggin Send a message via MSN to Boggin
Default how to test a coil
what is the most accurate way to test a coil? i think i may have mine blown on the mazda. thanks
__________________
05 F250 - 6.0, 6 speed, deleted by RCD, SCT tuned, blue spring, sinister coolant filter, dummy plugs/stand pipes, Atlas 80 ficm, afe intake, 4" turbo back straight to 5" mitre cuts, 6" lift with rear air bags, 35" pro comps
04 Ranger 4.0 4x4 - stock
02 Duramax - afe intake, Super chip, straight pipe
93 W 250 12v cummins - stage 5 fuel pin
Lots of past rbv's
"Dont know how to drive automatic"- Chance. RIP Buddy.
Boggin is offline   Reply With Quote
Advertisement (Not shown to 'Premium Members')
Old 11-25-2010, 08:36 PM   #2
adsm08
Premium Member
Asteroids Champion
adsm08's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
Vehicle Model: Ranger XLT
I use this vehicle for: Making money and being broke.
adsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond repute
Send a message via AIM to adsm08
Default
Grab the prop rod or some other part of the body. Then stick your tongue on the end of the coil wire and have someone crank the engine over. If you survive, you need a new coil. If you survive and have brain damage or need a pace maker now, you probably still need a new coil. If you die, you don't need a new coil, you won't be driving anymore.
Seriously though, if it's a distributor system, I like to take the dizzy end of the coil wire and jam a Philips head in it and hold the driver about 1/2 inch from the prop rod. Then have someone crank the engine. If you hear a sharp snap and see blue spark it's good. If you hear a weak crackling and see orange or red spark, coil time.
If you are not in direct contact with the body you shouldn't get zapped.
If it's a coil-pack system do the same thing, but pull the fuel pump relay first. And you gotta do it once for every coil.
__________________
Project: Hillbilly Deluxe
Project: Amazing Grace
Project: Cash 'N Carry
Project: 12-Volt Sandwich, project finished
Project: Birthday Present
I like it when things catch fire and explode, which means I do not have your best interests in mind.
adsm08 is offline   Reply With Quote
Old 11-25-2010, 08:37 PM   #3
4.0B2
Premium Member
4.0B2's Avatar
Vehicle Year: 1988
Vehicle Make: Ford
Vehicle Model: Bronco II
I use this vehicle for: Taking my Money
4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute
Default
can you get a hold of one off another mazda? me having the ex and b2 with an ex's drivetrain, i just swap parts around
4.0B2 is offline   Reply With Quote
Old 11-25-2010, 08:40 PM   #4
Boggin
Boggin's Avatar
Default
i knew of that way but just wondered if there was a better way, like even some way to do it with a test light or volt meter?
thanks though!
__________________
Lots of past rbv's
Old 11-25-2010, 08:49 PM   #5
adsm08
Premium Member
Asteroids Champion
adsm08's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
Default
You can always ohm the primary windings, but that test is ineffective at best since a new coil and a functional but weak coil will usually ohm the same or close, and I've done resistance tests that showed good on non-functional coils.
Using a test light or voltmeter to test it is not a great method for a few reasons. "Slow" firing of the coil is still thousands of times a second. That makes it hard to accurately gauge how well it fires since it is running at thousands of hertz while your eyes can process about 60hz. Also, these coils produce up to 40 Kv and a few hundred amps. that will just fry your meter and probably your test light too.
A load test with the screwdriver or an actual spark tester (which functions much the same way) is the best and most accurate method.
__________________
Old 11-25-2010, 08:55 PM   #6
lil_Blue_Ford
Super Moderator
lil_Blue_Ford's Avatar
Vehicle Year: 95
Vehicle Make: Ford
Vehicle Model: F-150
I use this vehicle for: Work
lil_Blue_Ford has much to be proud oflil_Blue_Ford has much to be proud oflil_Blue_Ford has much to be proud oflil_Blue_Ford has much to be proud oflil_Blue_Ford has much to be proud oflil_Blue_Ford has much to be proud oflil_Blue_Ford has much to be proud oflil_Blue_Ford has much to be proud oflil_Blue_Ford has much to be proud of
Send a message via AIM to lil_Blue_Ford
Default
So that's how the spark plug tester screwdriver I picked up is supposed to work...
Wasn't sure how it was supposed to be used, I got it without any instructions, just a flat head screwdriver with a spring in the handle and it's labeled "Craftsman Spark Plug Tester." I threw it in my toolbox and it's sat there for the past 4 years or so...
__________________
"lil Blue" 2000 Ranger Supercab xlt: 3.0L, 5-spd, 2wd
"S**tbrick" 1988 Bronco II Eddie Bauer: 2.9L, auto, 4x4
1989 Bronco II choptop: 4.0L, 5-spd, 4x4, 7" lift, locked f/r, 35's
"Blue Ox" 1995 F-150 xl: 4.9L, 5-spd, 4x4
2000 Ranger Supercab xlt: 4.0, auto, 4x4
Quote:
Originally Posted by JohnnyO View Post
Some people are too stupid to be in management. That's why they keep getting promoted.
lil_Blue_Ford is offline   Reply With Quote
Old 11-30-2010, 12:46 PM   #7
AgPete139
09/2014 OTOTM Winner
AgPete139's Avatar
Vehicle Year: 1997
Vehicle Make: Ford
Vehicle Model: Ranger XLT Xcab
I use this vehicle for: DD, hauling stuff, & getting me everywhere a car can't
AgPete139 is a splendid one to beholdAgPete139 is a splendid one to beholdAgPete139 is a splendid one to beholdAgPete139 is a splendid one to beholdAgPete139 is a splendid one to beholdAgPete139 is a splendid one to beholdAgPete139 is a splendid one to beholdAgPete139 is a splendid one to behold
Default
Boggin, when did you get the Gen3?
__________________
Green Ranger Build:
1997 Ranger Ext 4.0L 5spd BW1354M, ~7" lift Deaver springs & Explorer leaves, front D44 welded 4.88, rear Expo 8.8" autolocker, 35x12.50x15 KM2's, 1.25" DOM front bumper, shock towers + buckets, communication & stereo bits
ADD YOURSELF TO THE TRS MEMBERS MAP !!!
http://www.therangerstation.com/foru...d.php?t=128467
AgPete139 is offline   Reply With Quote
Old 11-30-2010, 01:38 PM   #8
Boggin
Boggin's Avatar
Default
Quote:
this summer, few months ago
__________________
Lots of past rbv's
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
