Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 12-01-2010, 05:33 PM   #1
whcherman
Vehicle Year: 1988
Vehicle Make: ford
Vehicle Model: bronco 2
whcherman is on a distinguished road
Default capacitor?
88 b2 2.9 L i found what appears to be a capacitor near the coil associated with the distributor. what is this never seen in wiring schematics before.
whcherman is offline   Reply With Quote
Advertisement (Not shown to 'Premium Members')
Old 12-01-2010, 05:58 PM   #2
Robert_1967
Robert_1967's Avatar
Vehicle Year: 1988/1989
Vehicle Make: Ford
Vehicle Model: Ranger Supercab/BroncoII
I use this vehicle for: Soon to be hot rod/Daily Driver
Robert_1967 has a spectacular aura aboutRobert_1967 has a spectacular aura about
Default
Got one on my 88 Ranger 2.3, well had one, the Engine is gone right now, and I have one on my 89 BII with a 2.9.
it use to be in the Dizzy when there was points in the Dizzy.
Robert
__________________
My 88 Ranger II build thread
If I can't work on my Ranger or BroncoII, I rather be fishing.
If Facebook, MySpace, and Twitter were all destroyed, 90% of teens would go insane.
Robert_1967 is offline   Reply With Quote
Old 12-01-2010, 07:22 PM   #3
adsm08
Premium Member
Asteroids Champion
adsm08's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
Vehicle Model: Ranger XLT
I use this vehicle for: Making money and being broke.
adsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond repute
Send a message via AIM to adsm08
Default
It's a capacitor. The coil produces a lot of EM and RF noise. That capacitor is there to catch it and keep it out of the engine control wires and radio. The engine will run, usually just fine, without it, but there will be all sorts of noise in the radio.
__________________
Project: Hillbilly Deluxe
Project: Amazing Grace
Project: Cash 'N Carry
Project: 12-Volt Sandwich, project finished
Project: Birthday Present
I like it when things catch fire and explode, which means I do not have your best interests in mind.
adsm08 is offline   Reply With Quote
Old 12-01-2010, 07:30 PM   #4
whcherman
Vehicle Year: 1988
Vehicle Make: ford
Default
thanks to all, that is what i thought but haven't seen them for some time. even searched advanced auto for a replacement but there were none. dont think it has anything to do with my current problems of no spark.
Old 12-01-2010, 07:33 PM   #5
adsm08
Premium Member
Asteroids Champion
adsm08's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
Default
No, a bad capacitor won't cause no spark.
I'd be looking at the TFI module.
__________________
Old 12-01-2010, 07:46 PM   #6
whcherman
Vehicle Year: 1988
Vehicle Make: ford
Default
replaced tfi, rotor and cap. white wire jumped coil and sparked. cranking engine with spark plug attached to coil wire no spark?
Old 12-01-2010, 09:16 PM   #7
kimcrwbr1
kimcrwbr1's Avatar
Vehicle Year: 1983
Vehicle Make: ford
Vehicle Model: ranger
I use this vehicle for: DD tow boat
kimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to behold
Default
With the plug in the coil wire plug sitting on a good ground with the key on, jump the neg side of the coil to ground quick touches you should get a brite blue spark. if so coil is good, then you need to troubleshoot the module and the pickup coil in the dizzy. Check all the wires and connectors first. The tech library under TFI diagnostics and a volt meter will get you there just print it out and have at it. I always read it through a couple times so you know how it works to help the diagnostic.
__________________
it takes a nickle to go first class
when it stops hurting it will feel alot better
kimcrwbr1 is offline   Reply With Quote
Old 12-01-2010, 09:25 PM   #8
whcherman
Vehicle Year: 1988
Vehicle Make: ford
Default
yes, thank you. I have looked at the tfi sheet in the library. the only unclear pt to me is the diagnosis of the pick up coil. can this be done through the spout connector (used for checking timming)? or how? I have tested the tfi's new and old and there connectors for voltage. but the pick up coil is still the gray area in my mind. again thanks oh and how do you replace the pickup coil, been looking all day.
Old 12-02-2010, 06:00 AM   #9
kimcrwbr1
kimcrwbr1's Avatar
Vehicle Year: 1983
Vehicle Make: ford
Default
You have to pull the dizzy to replace the coil. You can test it with jumper leads attach male spade connectors to some jumper wires and push them up into the coil using the module as a guide for which one is which. That is also how you can put the remote module setup just jumper wire the coil to the module and mount it on a heat sink similar to one you would find on a computer processor always use heat sink grease when mounting the module. To change the coil you have to remove the cam gear and pull out the shaft easy enough to do with a drift pin and a block of wood tap out the roll pin and if the cam gear is worn this is the time to replace it also. Check the bushings in the dizzy for slop first if there is any slop side to side it can affect the spark and end play can affect the timing and replace the o-ring when putting the dizzy back in. A rebuilt dizzy is a good option and in general the more expensive the module the better it is.
__________________
Old 12-02-2010, 06:03 AM   #10
kimcrwbr1
kimcrwbr1's Avatar
Vehicle Year: 1983
Vehicle Make: ford
Default
Turn the rotor to where you have a point to reference when you take it out to put it back the same place.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
