Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Truck Discussions (Not for tech help - Use Help Forums further down) > General Discussions
General Discussions This forum is for general discussions. If you're in need of help, post it below in the appropriate topic forum.
Reply
Thread Tools Display Modes
Old 12-06-2010, 06:11 AM   #1
R***A**N**G**E***R
Vehicle Year: 1996
Vehicle Make: Ford
Vehicle Model: Ranger supercab STX
I use this vehicle for: everything
R***A**N**G**E***R will become famous soon enoughR***A**N**G**E***R will become famous soon enough
Default Column gear shifter/stuck in PARK
I have a 1996 ford ranger 4x4 and for the last month my column shifter has felt a bit sloppy and also when I put it in park and then get back in my truck to go some place else it won't shift out of park BUT after a couple tries of turning the key and removing my foot from brake and back again it always would shift out of parking gear and off I would go but today was a different story,as I was getting back in my truck after going to the store I could NOT get it out of park for like 5 minutes FINALLY it shifted out of park and I put it in drive and went home.
I have decided from now on to put it in neutral,turn it off and put on my emergency brake and lock it up when I am not in it, so the obvious question is what in the hell is going on???
update/ALSO the last few days I have noticed that when I have cruise control on and when I go to TAP the brake to disengage the cruise NOTHING happens, truck still goes until I tap the brake 5 or 6 times frantically then the cruise will shut off.
Are there any write up's about this exact issue with other people experiencing this problem and what was the fix? I am ASSuming this is most likely the ( BRAKE SWITCH ) kinda makes sense, please tell me it;s the brake switch,lol
__________________
www.DoubleTapBoomBoom.com
R***A**N**G**E***R is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 12-06-2010, 08:01 AM   #2
James86
James86's Avatar
Vehicle Year: 1999, 2005
Vehicle Make: Ford, Dodge
Vehicle Model: Ranger XLT, Neon Limited Edition
I use this vehicle for: DD, Things it oughtn't do...
My credo: I'll never let an import in my garage again...
James86 will become famous soon enough
Default
It sounds like two different issues here.
First off, it sounds like you may have the same issue my friend just had in his 2000 Explorer. The connecter at the end of the shifter loosened and it got really sloppy, and he would struggle to get it out of park. Finally one day, he was fighting with it and it broke partially, so there was so much slop he had "N" and "D". I ended up loaning him my wheelblocks for a week and we managed to tighten it back up, but one side was broke so we got him reverse until he got it into a shop. I'd look underneath to see if anything is loose. Itll look like this:
Its apparently a common enough issue on RBVs, and this thread goes through it pretty well:
http://www.ford-trucks.com/forums/82...n-shifter.html
As for the cruise issue, it may be something else, such as a relay in the brake circuit not working. That could explain your issues getting out of park as well. My dad keeps having an issue in his Mazda MX6 where applying the brake to shift form "P" doesnt alway disengage the park safety interlock.
Just throwing out ideas... Good Luck
__________________
1999 Ford Ranger XLT, 3.0 FFV.
2005 Dodge Neon Limited Edition.
James86 is offline   Reply With Quote
Old 12-06-2010, 06:30 PM   #3
R***A**N**G**E***R
Vehicle Year: 1996
Vehicle Make: Ford
Default
I had a good look at the brake switch today and one of the two wires was almost broken in half so I just spliced it and now my cruise works when taping the brake and I don't get stuck in parking gear anymore.
__________________
Old 12-07-2010, 03:11 AM   #4
James86
James86's Avatar
Default
Glad it was something simple.
__________________
Old 12-07-2010, 10:44 AM   #5
ozziemo27
June 2010 OTOTM Winner
ozziemo27's Avatar
Vehicle Year: 1999/1984
Vehicle Make: Ford
Vehicle Model: Ranger(s)
I use this vehicle for: Offroad/Daily Driver & Future Project
ozziemo27 is a jewel in the roughozziemo27 is a jewel in the roughozziemo27 is a jewel in the rough
Default
Quote:
that makes sense on both issues. glad to hear you figured it out!
__________________
1999 Ranger 4.0 4x4 - Down for SAS
F*CK YOUR IFS!
1984 Ranger 4cyl 2.3 - 278k miles
CTOR
www.CheapThrillsOffRoad.com
ozziemo27 is offline   Reply With Quote
Old 01-07-2011, 01:24 AM   #6
vamoosevarmint
Vehicle Year: 2000
Vehicle Make: Ranger
Vehicle Model: XLT
I use this vehicle for: Service Truck
vamoosevarmint is on a distinguished road
Default
Thanks for the post I have been looking for this fix for a couple of years now. I will check it out and see if it fixes mine. I thought it would be more complicated
vamoosevarmint is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
