Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Help Forums - Styling & Electrical > Lighting/Illumination
Lighting/Illumination This forum is for headlamps, auxillary lighting, interior lighting, and LED conversions.
Reply
Thread Tools Display Modes
Old 01-07-2011, 04:59 PM   #1
puty72
puty72's Avatar
Vehicle Year: 1989
Vehicle Make: Ford
Vehicle Model: Ranger XLT
I use this vehicle for: beater, work truck
puty72 is on a distinguished road
Default headlight adjustment
1989 ford ranger 2.9 xlt 4x4
I was wondering how to adjust my headlights because they are shining in different directions.
puty72 is offline   Reply With Quote
Advertisement (Not shown to 'Premium Members')
Old 01-09-2011, 11:25 AM   #2
Tedybear
Vehicle Year: 1994, 2001
Vehicle Make: 1994 Ford Bronc
Vehicle Model: 2001=Volkswagen Beetle
I use this vehicle for: Daily Driver
My credo: Failing is easy. Everyone can do it.
Tedybear is a jewel in the roughTedybear is a jewel in the roughTedybear is a jewel in the roughTedybear is a jewel in the rough
Default
Two adjusters on each headlight unit. You'll see the heads sticking out. They are very very small hex head shafts that run down to the adjuster gear.
S-
Tedybear is offline   Reply With Quote
Old 01-09-2011, 11:53 AM   #3
greenpus
greenpus's Avatar
Vehicle Year: 2000
Vehicle Make: Ford
I use this vehicle for: 31x12.5x15 rubber on 15x10 wheels
greenpus is on a distinguished road
Default
LOOKS OK TO ME
greenpus is offline   Reply With Quote
Old 01-09-2011, 11:56 AM   #4
greenpus
greenpus's Avatar
Vehicle Year: 2000
Vehicle Make: Ford
Default
I found this and thought it was funny
"Well, here's what my brother does. He adjusts both headlights up and to the left as far as they can go. Then, every day he moves them a quarter turn down and to the right. And when people in oncoming vehicles stop giving him the finger and cursing at him as they pass, he figures he's getting pretty close. "
Old 01-09-2011, 12:09 PM   #5
Tedybear
Default
Here's the really sad part. Keeping in mind I used to turn a wrench 20 or so years ago for a living.
Replaced both headlight assys due to the yellowing problem being so severe no amount of 'refinishing' kits would touch it. (and I tried several).
Went to the local dealership (they actually have the cheapest labor rates) to get a hand pulling the diff plug due to it being seized. I figured I would have them align the headlights the correct way and save the headache.
The "tech" had to heat the diff plug and it finally broke free. Good fluid and he put anti-seize on it when reinstalled. Then he pulled out the very DUSTY "Hoppy" headlight aim set.
Anyone want to guess who trained him that day on how to calibrate and adjust the headlights correctly?
The shop manager didn't charge me a cent for the 60 minutes I spent working with the young "Tech" showing him how to calibrate---use the blue rod attachements--and the internal mirrors to gain the right aim. I told the shop manager these Hoppy tools are perhaps the most under-rated $$ maker a shop can have. 20-30 minute charge to align headlights..and about 70% of all cars/trucks? Have bad headlight aim. I used to do this procedure about 8 times a day at the shop I worked at. (NYS inspection at the time (not sure now...no longer an inspector for 20 years) required headlight aim checked and repaired).
And people came back within a few days to THANK ME because now they see the road at night--and not the corn fields.
S-
Old 01-09-2011, 12:22 PM   #6
greenpus
greenpus's Avatar
Vehicle Year: 2000
Vehicle Make: Ford
Default
Quote:
I used GlassyLite. It's expensive but worked well to get rid of yellow and cloudiness of the lens. It does work like most with sanding and polishing the lens but the sealant that is put on at the end does something to the lens to make it look new again. I was amazed.
Old 01-09-2011, 02:16 PM   #7
BRUTUS_T_HOG
BRUTUS_T_HOG's Avatar
Vehicle Year: 89
Vehicle Make: Ford
Vehicle Model: Ranger S
I use this vehicle for: everything
BRUTUS_T_HOG is a glorious beacon of lightBRUTUS_T_HOG is a glorious beacon of lightBRUTUS_T_HOG is a glorious beacon of lightBRUTUS_T_HOG is a glorious beacon of lightBRUTUS_T_HOG is a glorious beacon of lightBRUTUS_T_HOG is a glorious beacon of light
Default
Quote:
i used DOT 3 brake fluid and a rag. works good
BRUTUS_T_HOG is offline   Reply With Quote
Old 01-09-2011, 05:33 PM   #8
yyc_tbird_sc
yyc_tbird_sc's Avatar
Vehicle Year: 1997
Vehicle Make: Ford
yyc_tbird_sc is on a distinguished road
Send a message via MSN to yyc_tbird_sc
Default
-Park your truck 10' from a flat wall. Be sure that it is perpendicular with the wall and front end pointed towards the wall.
-Measure from the ground up to the center of the headlight.
-Make a horizontal tape line on a flat wall that height (1" masking tape works well)
-Measure how far apart your lights are
-Make vertical lines using the tape again, be sure that these vertical lines are directly in front of your truck.
-Turn on you headlights (low beam, not high beam).
-Adjust the headlights so that the hot spot is about 2-3" below the horizontal line, and inline with the vertical lines.
yyc_tbird_sc is offline   Reply With Quote
Old 01-14-2011, 02:14 AM   #9
Snafu
Junior Member
Snafu's Avatar
Vehicle Year: 1988
Vehicle Make: Ford
I use this vehicle for: Daily driver
Snafu is on a distinguished road
Default
you could go through what tbird said or just park it infront of a wall or garage door and use the adjustment screws to adjust them to your liking it may be more accurate with all the taping and measuring but it also takes up time you could be using for something else
__________________
I would rather push a Ford than drive a Chevy.... but i work for GMC
Snafu is offline   Reply With Quote
Old 01-16-2011, 12:21 PM   #10
MNBen
MNBen's Avatar
Vehicle Year: 2003
Vehicle Make: Ford
Vehicle Model: Ranger XLT 4x4 Ext Cab FX4 Off Road
I use this vehicle for: Winter Driver
MNBen is on a distinguished road
Default
I did what Tbird said. It is done and over with and you do not have to second guess. Some manuals say 20', at least for my '99.
MNBen
p.s. Would the fog lights be aligned the same way??
MNBen is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
