Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Help Forums - Styling & Electrical > Misc Electrical & Gauges
Misc Electrical & Gauges Post your speedometer, gauges, interior and non audio/video questions here.
Reply
Thread Tools Display Modes
Old 01-09-2011, 03:42 PM   #1
dirtbikes4fun02
Vehicle Year: 1991
Vehicle Make: Ford
Vehicle Model: Ranger
dirtbikes4fun02 is on a distinguished road
Default fuel gauge reads over full or below empty
i have a '90 4 cyl 5-speed ranger standard cab long bed.
the fuel gauge when u turn the key on goes straight to full or straight to empty and it does it randomly. when u let it go to empty and cycle the key it will go to full, then fall off slowly when u turn the key off, then when u turn it back on, it will either go back to full or go straight to empty. and it has 1/2 tank of gas
i changed the whole pump, sending unit, float and everything last night. i checked all the wiring, and clean the plug wiring. i grounded out the yellow/white wire, checked the ohms on the sending unit, and everything checked out fine.
then i tried the gauge and still the same problems. could this be the slosh module?
i tried pulling the cluster out, but the speedo cable would not give me enough slack to unhook it and remove the cluster
somebody please help me out. i really need this to work.
thanks
dirtbikes4fun02 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 01-10-2011, 10:02 PM   #2
dirtbikes4fun02
Vehicle Year: 1991
Vehicle Make: Ford
Default
thanks guys!
Old 01-27-2013, 03:20 AM   #3
vader436
vader436's Avatar
Vehicle Year: 1994
Vehicle Make: Ford
Vehicle Model: Ranger XLT
I use this vehicle for: everything
vader436 is on a distinguished road
Unhappy
did u solve ur problem, bcuz imhaving the same problem with my gauge, need help please
__________________
ractiv exhaust, 6000k bixenon, 16" blitz staggered, energy suspension bushings, greddy free flow intake, msd streetfire ignition coil, sound system
vader436 is offline   Reply With Quote
Old 02-19-2013, 08:10 AM   #4
Mark_88
Mark_88's Avatar
Vehicle Year: 2007
Vehicle Make: Dordge
Vehicle Model: Care A Van
I use this vehicle for: Space travel
My credo: Love Thy Neighbor
Mark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond repute
Default
A bit late but...could be a bad grouund or a corroded connector on the top of the tank...mine has been wonky since I got the truck...when I had the bed off I cleaned the connectors and it worked better (though not perfectly)...a bit of dielectric grease in the connector goes a long way too...
if that doesn't help then you may need to replace the sending unit in the tank...
__________________
Rome and my Ranger were not built in a day...
1988 Ranger 2.0 5 spd (gone)
1988 Ranger 2.3 " (gone)
1996 Ranger 2.5 (gone)
On-line manual link
http://www.therangerstation.com/foru...94#post1581294
Mark_88 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
