ATTN: Anyone without a working 1354E (push button 4wd)
gribly
15+ Year Member
Maine
Mine has been acting up lately, so I tore the motor apart completely and found something not mentioned in the tech library. The plate with all the contacts that is attached to the gear has a stop-screw on it. This stop screw has a plastic sheath around it, and mine was shattered. This allows the motor to spin a hair farther than it is supposed to and the whole thing freezes up. Mine partially seizes when it gets there, and the contacts come out of position. I am trying to find a good substitute for the plastic bit that broke, maybe cut down a washer? No way to take pictures at the moment, but if you look in the tech library or have an exploded view you can see the part I am talking about. I'm glad it was something simple, and maybe someone else can fix their motor with this info instead of spending the $75-$100 for another one.
Isn't the bushing around the stop screw what is usually broken on the shift motor?
Yes. This is what all the articles I've seen have discussed repairing.
