DISCLAIMER: Activities and vehicle modifications appearing or described at The Ranger Station and it’s pages may be potentially dangerous. We do not endorse any such activity for others or recommend it to any particular person – we simply describe the experiences and opinions of other Ranger/Bronco II owners. If you choose to engage in these activities it is by your own free will and at your own risk. Any and all modifications will likely cause a vehicle to behave differently than stock. Some modifications may significantly increase your risk when driving the vehicle or be dangerous in some driving situations. Use good judgment when engaging in any activity or making any modifications. Do not take unwise risks. Consult a certified professional if you are not sure of something. The Ranger Station and the authors of these articles assume no liability for how any particular individual chooses to use the information presented here. Some of these modifications may void your vehicles warranty. Please also read our Legal notice HERE.
Original Version:
This section replaced the old Tech Library of the original website that can still be found HERE. (No new articles added here after 2018)
2019-Present Ford Ranger Tech:
If your looking for tech specific to the 2019-present Ford Ranger, click HERE.
Other Info:
Interior:
Interior Cleaning
Interior Painting
Custom Interior Pieces
83-88 & 89-92 Door Interchange Guide
Compass / Temperature Mirror Install
Explorer Overhead Console & Lighted Visors
’89-’94 Dash Install Into ’83-’88 Ranger
New Carpet Installation
Windows & Locks Install
Installing Keyless Entry
Triple Bulb Dome Light Upgrade
Recovering Your Headliner
Wet Floor Boards – Finding The Leak
Visors:
Lighted Visor Mirrors
Floppy Visor Fix
Sun Visor Swap
Sun Visor Upgrade
Seats:
Ford Ranger Seat Swap
60/40 Split Bench Converted To Buckets
Center Console:
A Guide To Center Consoles
Ranger Center Console Fix
How To Remove The Center (Short) Console
Explorer Short Center Console Install
1995-2001 Explorer Long Center Console Removal / Install
1995-2001 Explorer Long Center Console Install
2002-2005 Ford Explorer Center Console Removal
1995-2001 Ford Explorer Information Center
1995-2001 Explorer Information Center Installation (.pdf)
1998 Ford Explorer Message Center Pinouts
Fiberglass Center Console Build
Truck Audio:
What Fits Your Ranger
Radio Wiring Diagrams
Stereo/CD Install
Double Din Radio Install
1988 Ranger Stereo Install
Aftermarket Speaker Install
New Stereo / No Sound / Factory Amplifier
Infinity Subwoofer
Probox Loaded Universal Enclosure
CB Antenna Installation & Tuning
Speedometer, Tach & Cruise Control:
How Speedometers Work
Checking Speedometer After Tire Size Change
Speedometer Correction – Changing The Speedo Gear
Wiring a 4.0L to a 1983-1988 Dash
1983-1988 Ford Ranger Speedometer Head Replacement
1983-1986 Gauge Cluster With Tachometer Swap
Tachometer Install
Ford Ranger Odometer Gear Replacement
Odometer Worm Gear Replacement
Odometer Worm Gear Replacement #2
Odometer Gauge Swap
Installing Cruise Control
Ford Ranger Red Gauge Needles – How To
Adjust / Repair Instrument Cluster Gear Indicator
Add Cruise Control To Your Ford Ranger
Electrical – Gauges & Misc:
How To Replace Instrument Cluster Light Bulbs
Variable Oil Pressure Gauge Modification
Troubleshooting Your Ford Fuel Gauge
1995+ Gauge Cluster Removal
Installing A Tripminder (MPG Display)
Instrument Cluster Wires
Selecting The Proper Wire Size
Intermittent Windshield Wiper Fix
Door Contact Pin
Factory Power Doors
Wire Defined By Color (1983-1991)
Properly Wiring Accessories
Ford Electrical Connector Identification
Fuses:
1983-1992 Fuse Box Diagrams & Checking Fuses
1993-1997 Fuse Box Diagrams & Checking Fuses
1998-2000 Fuse Box Diagrams & Checking Fuses
2001-2003 Fuse Box Diagrams & Checking Fuses
2004-2011 Fuse Box Diagrams & Checking Fuses
Calculators:
Check Speedometer After Tire Change
More Articles:
