Introduction
If you’ve lifted the suspension on your 1998 or newer 4WD Ford Ranger, than you’ve likely worn out the Rzeppa Joint in your front driveshaft. The factory front driveshaft simply doesn’t survive at the angle created from lifting the suspension, which is why Superlift offers a replacement driveshaft P/N 9636.
Ford Ranger factory front driveshaft at the top of the photo - Superlift 9636 front driveshaft at the bottom of the photo
(Ford Ranger factory front driveshaft at the top of the photo – Superlift 9636 front driveshaft at the bottom of the photo)
Build Your Own
But what if you don’t want to pay that much?? Well, you could build your own.
Forum Member Mr. Bossley got the dimensions for the Superlift 9636 front driveshaft which is shown below:
Superlift driveshaft diagram
As noted, the driveshaft is 32-inches extended, and 29-inches collapsed.
Here’s a couple more photos:
Superlift 9636 Driveshaft Double Cardan
Superlift 9636 Driveshaft flange
And for comparison, here are a few photos of a stock front driveshaft:
Stock front driveshaft
Parts
When asked how he built his own driveshaft, Mr. Bossley stated “I used a NEAPCO 1310 CV adapter with a TTB Ford Explorer front driveshaft and had it cut down a couple inches. But Powertrain Industries makes an adapter (Part # PTI 3102-411CV) that works better. it’s a little shorter, so you probably wouldn’t even have to cut the Explorer driveshaft.”
Explorer Driveshaft
Here is what the 1990-1994 TTB Ford Explorer front driveshaft looks like
(1990-1994 Ford Explorer Driveshaft)
CV Flange Yoke
NEAPCO – This is the NEAPCO CV Flange Yoke to bolt up the double cardan driveshaft to the Ranger’s transfer case. Click HERE to find it online.
Double Cardan CV Flange Yoke N2-83-288X by NEAPCO
Flange Yoke: 1310 series u-joint / (6) 0.323 Holes on 3.583 Bolt Cirlce
Powertrain Industries – This is the Powertrain Industries adapter Part # PTI 3102-411CV:
Flange Yoke – Series: 1310 / Bolt Circle: 3.583 / Bolt Holes: .328 / Pilot: 4.094
According to Powertrain Industries – “This 1310 CV conversion flange fits in the factory front transfer case flange of late model Ford Rangers and Explorers. It allows you to build a Spicer CV style shaft to replace the factory GKN style. “Rectangular Bolt Pattern 1.800 x 3.125”
Click HERE for more information.
Conclusion
So, you now know what driveshaft to use, that the length should be 32-inches extended, and 29-inches collapsed, and what to use for a flange yoke to attach it to the transfer case.
If you build your own front driveshaft, send us some photos and details of what you did.
Links
Original forum submission
Powertrain Industries P/N PTI 3102-411CV
NEAPCO N2-83-288X CV Flange Yoke
Ford Explorer Front Driveshaft (1990-1994)
Related Article
Rzeppa Joint
About The Author
Jim Oaks is the founder of The Ranger Station, one of the longest-running Ford Ranger enthusiast communities on the web. He has spent over three decades owning, modifying, repairing, and driving Ford Rangers on the street, trail, and cross-country routes.
Since launching TheRangerStation.com in 1999, Jim has documented thousands of real-world Ranger builds, technical repairs, drivetrain swaps, suspension modifications, and off-road tests contributed by owners worldwide. His work has been referenced by enthusiasts, mechanics, and off-road builders looking for practical, experience-based information rather than theoretical advice.
Jim’s hands-on experience includes long-distance overland travel, trail use, drivetrain and axle upgrades, suspension tuning, and platform comparisons across multiple Ranger generations. The content published on The Ranger Station is grounded in first-hand experience and community-verified data, not marketing claims or generic specifications.
