Home
Product / Build Guide Tech Articles Other Articles Featured Rangers Readers Rangers Classifieds
Ford Ranger Forum
Shirts & Decals
4.0L Camshaft Synchronizer
Trucks Of The Month
Translate
Shirts & Decals
CLICK to check out our TRS shirts & decals and support the site
Ranger Buyers Guide
Check Out These Girls!!
Check Out:
Pontiac Hunters
Sponsors Ad
 Sponsors Ad
Original poster: Jaymegriffiths
Original Thread: Click HERE
Difficulty: 7-9 out of 10 (depending on circumstances)
Time to install: With engine out: 10-20 minutes / Engine in vehicle: unknown (estimated 45 min)
Disclaimer: The Ranger Station.com, The Ranger Station.com Staff, nor the original poster are responsible for you doing this modification to your vehicle. By doing this modification and following this how-to you, the installer, take full responsibility if anything is damaged or messed up. If you have questions, feel free to PM the original poster or ask in the appropriate section of The Ranger Station.com forums.
This method is for installing a camshaft synchronizer into the back of the engine.
Tools needed:
  • Razor blade
  • Ruler
  • Set of metric wrenches
  • Set of sockets (3/8)
  • Ratchet
  • 1/2" breaker bar
  • Unknown size socket (for turning over engine)
  • 3/8 Inch extensions if in the vehicle
Parts needed:
  • Camshaft synchronizer
  • masking tape
  • valve cover gasket (passenger side)
Procedure:
Step 1. Remove belts if still on engine.
Step 2. If not already un-installed, loosen and remove hold down clamp before removing Old plug or broken/malfunctioning cam-synchro.
Step 3. Remove valve cover
Step 4. Using 1/2" breaker bar, turn engine clockwise using the big crankshaft pulley bolt. bring engine cylinder #1 to TDC compression stroke (when both valves are closed). The #1 cylinder is the one closest to the front passenger side.
Step 5. Using the ruler, cut a piece of masking tape 34mm long, exactly.
Step 6. Stick tape on the left side of the line on the crankshaft pulley and turn engine clockwise until the timing needle points at the end of the tape:
Step 7. Insert cam synchronizer into its socket in the back of the engine, at a 90 degree angle to the back of the block, with the c shaped piece pointed open end towards the driver side and on the far left mark.
Since the gear is helical, it will rotate as it goes into the engine and hopefully slips right into the oil pump. drive gear. If it does not, try wiggling it around it should drop in. replace hold down clamp, and make sure c shape lines up with the far right line on the sight glass now, perfectly, then tighten hold down. plug in and your done.
More Information From Forum member Slingblade:
The sensor itself is held on by two philips head screws.
You don't need to remove the whole drive gear assembly just to change the sensor. so you don't need to worry about the timing.
I think it would be easiest to remove the upper intake, but might be accessible with it in, but I doubt. My engines out right now anyways. Here are a couple of pics of what it looks like.
Just the cam sensor
Oil drive and synchronizer
New Sensor:
Also Check Out:
Ford Ranger 4.0L Forum
3.0L & 4.0L Camshaft Position Sensor (CMP)
footer
Advertisers
The Ranger Station
   About
   Staff
   Contact Us
   Advertising
   Legal Notices
   959 Media LLC
   Copyright 1999-2018
Submit Content
Have Info To Share?
We're always looking for good content to share with other Ford Ranger enthusiasts. Click on the 'Submit' button to find out how you can get your submission posted and acknowledged for it.
