Ranger Tech ('19-'20)
Ranger Tech ('83-'11) Product / Build Guide Other Articles TRS Events Overlanding
Readers Rangers
  Ford Ranger Forum
TRS Store
Loose Ford 4.0L Intake Bolts
Trucks Of The Month
Ranger Buyers Guide
There have been reports of loose intake bolts on some of the 90's 4.0L's.
Check - Check for loose lower intake manifold bolts.  Pull your #5 plug and check it out.  If you see the fuzzy head or have some oil present around the sides of the plug then bingo.  The 93-94 have this problem VERY often.  Usually you can fix it by simply tightening the bolts (in the PROPER sequence), but sometimes you need a new gasket.  Do you notice a loss of oil with no leaks?  Say 1-quart every 1500-3000 miles?
This is a simple fix...you will need the following:
  • 1/4" Socket Drive
  • 6" extension
  • Short wobble adapter (the broken neck socket adapter)
  • 10mm socket
Follow the pictures below for the location and proper tightening sequence. Most should be able to solve the problem by simple tightening, but some may need to replace the entire gasket as it may be shot. Make sure you follow the sequence for tightening!
footer
Advertisers
The Ranger Station
   About
   Staff
   Contact Us
   Advertising
   Legal Notices
   959 Media LLC
   Copyright © 1999-2020
Submit Content
Have Info To Share?
We're always looking for good content to share with other Ford Ranger enthusiasts. Click on the 'Submit' button to find out how you can get your submission posted and acknowledged for it.
