TheRangerStation.com  SM
Serving Ranger, Bronco II, Explorer & Mazda B-Series Owners Since 1999
Home Forums Tech Library Magazine Video Gallery Truck Gallery Shirts & Decals TRS Fab & Off-Road
Gears Needed After Adding Larger Tires
You will need to know your over all tire diameter in inches to use this calculator.
If you have metric size tires (225/75/15) you can convert them to inches by using the 'Metric Tire Size Conversion To Inches'.
This calculator will take your gear ratio and tire sizes and tell you what the effective or Actual Ratio is.  It will then suggest a New Ratio along with a Hi and Low alternative.  This New Ratio will return the vehicle to it's original performance after the addition of larger tires.  Obviously, you will have to round the new ratio to the closest available ratio.
  Gear Ratio Change From Tire Size Change - Find Gear Ratio Needed To Compensate
New Tire Diameter:
Old Tire Diameter:
Current Gear Ratio:
Actual
Ratio
Hi Ratio:
New Ratio:
Lo Ratio:
© 2000 - 2008 The Ranger Station - James Oaks Enterprises LLC - All Rights Reserved
'The Ranger Station' and it's logo are Service Marks of The Ranger Station owned by James Oaks Enterprises LLC
Legal Notice
