Ranger Tech ('19-'20)
Ranger Tech ('83-'11) Product / Build Guide Other Articles TRS Events Overlanding
Readers Rangers
  Ford Ranger Forum
TRS Store
Gears Needed After Adding Larger Tires
Trucks Of The Month
Ranger Buyers Guide
You will need to know your over all tire diameter in inches to use this calculator.
If you have metric size tires (225/75/15) you can convert them to inches by using the 'Metric Tire Size Conversion To Inches'.
This calculator will take your gear ratio and tire sizes and tell you what the effective or Actual Ratio is.  It will then suggest a New Ratio along with a Hi and Low alternative.  This New Ratio will return the vehicle to it's original performance after the addition of larger tires.  Obviously, you will have to round the new ratio to the closest available ratio.
  Gear Ratio Change From Tire Size Change - Find Gear Ratio Needed To Compensate
New Tire Diameter:
Old Tire Diameter:
Current Gear Ratio:
Actual
Ratio
Hi Ratio:
New Ratio:
Lo Ratio:
footer
Advertisers
The Ranger Station
   About
   Staff
   Contact Us
   Advertising
   Legal Notices
   959 Media LLC
   Copyright © 1999-2020
Submit Content
Have Info To Share?
We're always looking for good content to share with other Ford Ranger enthusiasts. Click on the 'Submit' button to find out how you can get your submission posted and acknowledged for it.
