Home
Product / Build Guide Tech Articles Other Articles Featured Rangers Readers Rangers Classifieds
Ford Ranger Forum
Shirts & Decals
K&N Airfilter Set-Up - Provided By Mike DeHosse
Trucks Of The Month
Translate
Shirts & Decals
CLICK to check out our TRS shirts & decals and support the site
Ranger Buyers Guide
Check Out These Girls!!
Check Out:
Pontiac Hunters
Sponsors Ad
 Sponsors Ad
An easy way to increase your airflow with a K&N filter is by eliminating the air box completely.  The photo of Mike's 2.9-Liter shows where he has removed the airbox and intake hose and clamped a K&N filter right to the throttle body.  This is what he did:
I found a parts store that sold K&N filters.  I measured the outside diameter of my throttle body where the hose attached.  It's 2 3/4-inches in diameter.  I told the parts guy I wanted a cone shaped K&N filter that clamped on to a 2 3/4-inch flange.  The filters that would work had a can shape.  I knew that shape would interfere with the radiator hose so we found a filter that had an angled  mount, K&N part number RU-1460.  A K&N filter can also be mounted at the airbox end of the intake hose by inserting a small tube, and then clamping the hose, tube, and K&N filter together.
When removing the factory airbox you will also remove the hot air hose coming from the exhaust manifold and a vacuum hose.  The vacuum hose should be removed and plugged at the engine.  You should keep these pieces to bolt back on later if you live in an area with emissions tests / inspections.
   (K&N RU-1460 FIlter)
footer
Advertisers
The Ranger Station
   About
   Staff
   Contact Us
   Advertising
   Legal Notices
   959 Media LLC
   Copyright 1999-2018
Submit Content
Have Info To Share?
We're always looking for good content to share with other Ford Ranger enthusiasts. Click on the 'Submit' button to find out how you can get your submission posted and acknowledged for it.
