By Jim Oaks
After breaking an aftermarket braided brake line, I took it to a local Autozone parts store to find a temporary replacement. The guy at the counter took the line and actually pieced two (2) lines together to create a 24-inch rubber brake hose.
The first photo below shows the two individual hoses:
The second photo shows the two hoses connected next to the old aftermarket braided hose:
(Photo by ‘crawlin91’)
The new lines shown are ‘Brakeware’ that I bought from Autozone. Their part numbers are listed below along with a cross reference to other manufacturers part numbers.
You need (2) hoses from each list below to assemble and make (2) complete brake hoses:
| Manufacturer | Part # | Manufacturer | Part# | |
| Brakeware | 77226 | + | Brakeware | 88291 |
| Wagner | F106887 | + | Wagner | F43757 |
| Bendix | 77226 | + | Bendix | 88291 |
| Raybestos | BH3684 | + | Raybestos | BH36593 |
So, the 77226 gets connected to the 88291 to form (1) hose. Repeat for the other side.
The #77226 cost me $10.00 and the #88291 cost $9.00. At that rate it costs around $40.00 to do both sides. The positive note would be that you could get the hoses from any parts store and could only have to replace 1/2 the line if you broke one instead of having to buy a new set from a suspension manufacturer.
A One-Piece Hose Replacement – A Better Way
Submitted by Bob:
These hoses are 26″ long:
| Manufacturer | Part # | Manufacturer | Part # |
| Brakeware | 70053 | Brakeware | 70054 |
| Raybestos | BH38622 | Raybestos | BH38623 |
| Wagner | BH120541 | Wagner | BH120542 |
There are (2) numbers because there is a right and left side. Unlike the hoses above, these do not have to be pieced together.
Get the right and left brake line for a 1995 Chevrolet Truck K2500 3/4ton Suburban 4WD 7.4L TBI 8cyl.
Rock Auto lists these hoses fitting:
| MAKE | MODEL | YEAR |
| CHEVROLET | K2500 PICKUP | (1989 – 1995) |
| CHEVROLET | K2500 SUBURBAN | (1992 – 1995) |
| CHEVROLET | K3500 PICKUP | (1988 – 1995) |
| GMC | K2500 PICKUP | (1989 – 1995) |
| GMC | K2500 SUBURBAN | (1992 – 1995) |
| GMC | K3500 | (1988 – 1995) |
Brakeware 70053
Brakeware 70054
(Photo by ’89PBR86′)
(Photo by ‘Curious Hound’)
T-Blocks:
The 1983-1988 Ford Ranger, and 1989-1994 Ford Ranger WITHOUT ABS uses a driver’s side T-block to divide the brake line. You’ll need to get a T-fitting for a 3/16-inch brake line with two female and one male connections.
Submitted By brendank69:
The extension line is 13-inches long. A stock 1991 Ford F-350 line is 21.5″ long. Once pieced together, the line is roughly 34″ long. The F-350 and Ranger lines use the same thread and mount to the caliper in the same way. It would be helpful if someone could also provide the length of a stock ranger line.
Since the rear brakes are also fed by a 3/16″ brake line, the same extension line can be used to lengthen the rear line. I used this method, and I have enough brake line to support 6-inch Skyjacker leafs and Belltech shackles with quite a bit of length to spare.
I found that the article was really helpful, but it would have saved me time if I had known some of the lengths of different lines before I went to the parts store. The more that readers know, the easier it is to piece the appropriate lines together to make something that fits your application
Jim Oaks is the founder of TheRangerStation.com, the longest-running Ford Ranger resource online since 1999. With over 25 years of hands-on experience building and modifying Ford Rangers — including magazine-featured builds like Project Transformer — Jim has become one of the most trusted authorities in the Ford Ranger off-road and enthusiast space. In 2019, he was loaned a Ranger FX4 by Ford Motor Company to test and document across the TransAmerica Trail. Jim continues to inspire and guide Ranger owners around the world.
