Resurrecting Your Ford Ranger Air Conditioning |
Its summer and your A/C does not work. That sucks. Well, I have the write up to help you get it back on the road. Keep in mind, my write up only covers 134a systems, specifically in the 1997 4.0 OHV configuration. I believe that 94+ Rangers were outfitted with R134a, but 94 was a transition year, so you might have either R12 or R134a for that year. The overall advice given will apply to other engines and years as well, but you might have to make some adjustments mechanically. Difficulty: 9 Out of 10 Wrenches: The reason I am putting this so high is that you really need to pay attention to details. Miss a detail and you can have all of your work be for nothing, including trashing a very expensive compressor. Another difficulty is that messing with the refrigerant cans is dangerous. If you open the wrong valves on the manifold gauge set you can cause the can to explode, possibly severely injuring yourself or any bystanders. Also, keep in mind that the different years of Rangers use different amounts of refrigerant. The 97 has 25 ounces which is a hair over two 12 ounce cans, where the 94 uses 28 ounces (although I have seen 36 ounces for the 94 as well, but I believe that might be for the R12 version) the 1999 uses 30 ounces. This information will also be displayed on the sticker that is on top of the radiator support. Go with that amount if the sticker is still there and readable. I highly recommend that you read this How-To in its entirety before you start the repair, and make sure that you understand each step and what and why you are doing it. If you are unsure of something, ask someone who is knowledgeable, or take your truck to a shop. Before Job Preparations: Remove children, small animals, anyone with sensitive ears and anyone else that you do not want to be a target of your frustration and anger toward the Ford engineers that designed this cussing mess… Disclaimer: The Ranger Station.com, The Ranger Station.com Staff, nor the original poster are responsible for you doing this modification to your vehicle. By doing this modification and following this how-to you, the installer, take full responsibility if anything is damaged or messed up. If you have questions, feel free to PM the original poster or ask in the appropriate section of The Ranger Station.com forums. Lets Look at How Your A/C Works: Before we get to the testing and repair, let’s look briefly at how an air conditioner works. An air conditioner has 5 main parts: The compressor, Evaporator (in the heater box) Condenser (in front of the radiator), Accumulator/dryer (right next to the heater box in the engine compartment) and expansion valve or orifice tube. The engine is what runs the compressor. If there is enough static pressure (the pressure in the system when the A/C is not running) which is over 75 psi, and the electromagnetic clutch is working, when you turn on the A/C, the clutch will engage the compressor which pressurizes the Refrigerant gas. This in turn makes the Refrigerant gas very hot (basic thermodynamics). This hot Refrigerant then goes into the condenser which extracts the heat from the refrigerant using the trucks radiator fan or as the air goes across the condenser when the truck is moving, causing the Refrigerant to condense into a liquid. After the liquid Refrigerant exits the condenser, it goes through the expansion valve or orifice tube into the Low-Pressure side of the system where the Refrigerant starts boiling rapidly as it goes into the evaporator. This boiling causes the liquid Refrigerant inside the evaporator to get very cold as it turns back into a gas (again, basic thermodynamics), and a fan blows over the evaporator which cools the air and because cooler air also cannot hold as much moisture, causes the moisture in the air to condense into water which lowers the humidity of the air as well. After the evaporator the Refrigerant gas goes into the accumulator/dryer. The accumulator/dryer holds excess PAG oil, removes any moisture in the refrigerant using a desiccant and catches any liquid refrigerant that has not boiled into gas yet (Liquid refrigerant going into the compressor will hydro lock it, just like taking water in the intake of the truck). The gas then returns to the compressor to start the cycle all over again. The compressor clutch is controlled by the use of the pressure transducer switches. If the pressure gets too high, the High side transducer (located on the manifold bolted to the back of the compressor) will open and not allow the power to the clutch until the pressure drops back down. The pressure switch transducer which is located on the accumulator/ dryer is open if there is not enough static pressure. If there is enough static pressure, the clutch will engage. You may now wake up, the boring lecture is over. *Note For Those Doing a R12 to R134a Retrofit: You will need to replace your hoses, o-rings, and all of the oil. You want to be very careful of what oil you use, as some will not be compatible with the old mineral oil that the R12 systems use! I will not cover retrofitting in this walk through in detail. Also note, if your truck is not a 97, research the capacities for the oil and refrigerant before starting, and make adjustments to these instructions to fit your particular truck. A word or two about Refrigerants and Oils: I am only doing this walk through for the 94+ trucks that have the R134a refrigerant. If you are looking to do a retrofit as R12 is now illegal to buy or sell, (at least for the average consumer that does not have a proper license to buy and sell R12) you will want to do some more research on what parts you need to replace and how much refrigerant to use, what type of oil to use etc. R134a is a fairly inexpensive refrigerant. You can get it at just about any department store or automotive store from about 7 to 10 dollars for a 12 oz can. Do not use anything but R134a, as other refrigerants can be incompatible with the oil and cause a big mess. Plus, any car that has a refrigerant blend or any weird or exotic refrigerants will not be touched by any mechanic as the recovery process will contaminate his machine and supply of R134a. It is also illegal to knowingly vent the refrigerant into the atmosphere. It must be recovered by a qualified person who has the recovery equipment. For oil, Ford uses PAG 46 in most of its R134a systems. I recommend getting the Double End Capped PAG 46, as it has much better lubricating qualities than regular PAG 46, plus the Double End Capped PAG oil does not absorb moisture. PAG 100 or PAG 150 are too thick. It is not very much more expensive, and for what you are paying to replace the compressor if getting new, it is worth the 2 or 3 bucks extra. I also got some special oil for the o-rings and fittings called Nylog. It is specifically designed to keep the o-rings pliable and prevent leaks.
A Quick
Tip: Before
doing any work on the A/C, make sure all electrical connections (connector
at the compressor, and the connector at the pressure switches), fuses and
relays are good. Also check the blend doors in the dash, as this is a
trouble spot for the Ranger. If any of these are bad, the A/C will not
come on or will not work right. Also make sure the belt tensioner is
working properly. Check the condenser to see if the fins need cleaning and
/ or straightening. If your condenser has all of the fins bent over you
will have reduced airflow through the condenser and that will decrease the
effectiveness of your A/C. You can get a fin comb from Harbor Freight for
5 bucks. Tools: You will
need access to some special tools for this fix. You will need an A/C
manifold gauge set, and a vacuum pump to evacuate the system. You can buy
the manifold gauge set at AutoZone or O’Reilly for about $90 or Harbor
Freight for about $50. The pump is quite abit more expensive. I recommend
borrowing or renting one for this, but Craigslist can be a source as well.
I picked mine up on Craigslist for $35. Another option is the Harbor
Freight vacuum pump that hooks up to your shop air compressor. This is
only $20, but it will not pull a deep vacuum like a regular vacuum pump
made for refrigeration will. *note, if using the Harbor freight vacuum
pump that attaches to your air compressor, make sure your compressor can
maintain at least 110 psi continually for the time that you are using it.
Most home compressors do not have this capacity, so if you do not have a
commercial compressor, you might be better off buying a used a/c vacuum
pump. Also running an air compressor for an extended period of time will
consume a lot of electricity, so be aware of that when you get your energy
bill. If you are doing the air compressor vacuum route, I also recommend
starting and warming the truck up before pulling the vacuum. The residual
heat from the engine will help boil out the moisture at a much faster
rate. If you warm up the truck before pulling the vacuum you can shorten
the amount of time with the vacuum pump turned on. An hour or so should do
the trick. (Thanks 4x4 Junkie!) Other
Tools Needed: • 27mm
wrench • 22mm
wrench • 13mm
socket and ratchet • 11mm
deep well socket • 10mm
wrench • 8mm
wrench • A/C
– Fuel line disconnect tools (3 different sizes) •
Digital Thermometer • Feeler
gauge set • A pick
to help remove old o-rings and springlocks •
Orifice Tube Puller • A/C
flush kit which has a bottle that can be pressurized with flush solvent
and air and a hose and spray gun. I bought this off of Amazon for about
$45 • Four
Seasons Dura II Flush Solvent – Expensive at $32 a quart, but this stuff
is the best flush compound you can get. You can also use Turpentine as a
flush. I bought a quart of Turpentine to do the initial clean and flush,
and then used the Four Seasons stuff as the final flush. • A
length of hose that fits over the evaporator outlet and condenser outlet
to direct the flush solvent into a catch can. • Catch
can for the flush solvent. I am going
to write this in sections. Each section will be devoted to a specific part
that is being replaced. This way you can go to the section you need to fix
a specific area of the air conditioning system. At the end will be the
Appendixes that will give you some troubleshooting tips and how to flush
and charge the system. For the
component replacement sections keep this important fact in mind: If you do
any component replacement other than the pressure transducer switches or
the clutch, (ie opening the system) you will need to replace the
accumulator/dryer. If you open the system to the air for more than a few
minutes you must replace the accumulator/dryer. In fact, on a very humid
day, a brand new accumulator/ dryer can fill with moisture in as little as
15 minutes, rendering the desiccant inside useless. If your system is
good, but all of the Refrigerant has leaked out, you must replace the
accumulator/dryer. The reason for this is that the accumulator/dryer is
what removes moisture from the Refrigerant. This prevents ice or the water
from forming an acidic compound inside your A/C lines and trashing your
compressor/ condenser/ evaporator. The good news is that this
accumulator/dryer is only about $25 at AutoZone. Parts: I bought
most of my parts from Rockauto.com. Overall, I spent about $500 in parts.
I basically replaced everything but the evaporator, condenser, and the
pressure switches. If you are opening the system for whatever reason, you
will need to replace the accumulator/ dryer and the orifice tube. Another
rule of thumb, if you unhook something with an o-ring, replace the o-ring
before you put it back together. They are cheap, and it would suck to have
to pull the unit apart again after you get it back together and charged up
only to find the old o-rings are bad. If you are replacing the compressor,
to have the warranty honored, you will have to show proof of purchase of
an accumulator/ dryer, orifice tube, and condenser or have the old
condenser flushed. It only takes a few teaspoons of the gunk from the old
compressor that is in the lines to wreck the new compressor. For the
cheap minded, I recommend the local junkyard, especially those of you who
have access to a u pull yard. I picked up a compressor for under 20
dollars with a 30 day warranty at the local Pull A Part in Indy for my 94
Intrepid a few years ago. The car that you yank your parts from should
have no serious front end damage, and I would get a part from a car that
has some refrigerant charge left in it. This will tell you the system is
intact. For compressors, make sure that the pulley spins freely and that
you can turn the compressor with a good firm grip on the hub of the
pulley. You will hear it pumping and it should have a little resistance or
stiffness in it. What not to get in the yard? The accumulator/dryer and
orifice tube. The accumulator/dryer is $25 at AutoZone and the orifice
tube is 2 bucks. Both need to be replaced with new anytime you open the
system. Here is
the list of parts that I bought to get my Ranger ice cold again: •
Compressor •
Accumulator/ dryer •
Orifice tube •
Refrigerant Line – suction and high pressure with High pressure port
(big one that goes from the compressor around the back of the engine to
the top of the accumulator/ dryer) •
Refrigerant line – liquid (little one from the condenser to the
evaporator) • O-ring
kit (all the new parts that I bought had new o-rings/ springlocks
installed, but in case I messed one up…) Now For
The Work. •
Section 1 – Pressure switches •
Section 2 – Electromagnetic clutch and pulley •
Section 3 – Accumulator/ Dryer •
Section 4 – Orifice tube •
Section 5 – Compressor •
Section 6 – Large refrigerant line (suction and high side port from
compressor to accumulator/ dryer) •
Section 7 – Small refrigerant line (liquid – from condenser to
evaporator) •
Section 8 – Condenser •
Appendix A – Flushing the system •
Appendix B – Prepping a new system for a charge •
Appendix C – Charging the system •
Appendix D – Troubleshooting •
Appendix E – Sources Parts
replacement: The first
thing you need to do in all instances except replacing the pressure
transducer switch and replacing the electromagnetic clutch is to have the
system evacuated of refrigerant. Remember, it is illegal to knowingly vent
any refrigerant into the atmosphere, so if there is a charge left in the
system, have it properly reclaimed. Section
1 Part to
be replaced: Pressure
switch transducer (High and Low). Located on
the accumulator/dryer for the low pressure transducer, and right off of
the back of the compressor for the High pressure transducer. These parts
can be easily accessed from the top of the engine and removed with an
appropriate size wrench. These are one of two parts in this section that
you do not need to evacuate the system to replace. You need to unplug the
wire harness from it and you will need a 17mm open end wrench to remove
the low pressure transducer and a 14mm open end wrench to remove the high
pressure transducer. Both transducers have an o-ring, be sure to replace
the o-ring and coat it with Nylog or PAG oil before putting the new
transducer on.
Section
2 Part to
be replaced: Electromagnetic clutch. This is
the other part that does not require evacuating the system. Tools
you will need: • Safety
glasses • 8mm
socket or wrench • 13mm
socket • Flat
blade screwdriver •
Ratchet • Set of
feeler gauges • 15mm
combination wrench • Torque
wrench • Snap
ring pliers •
Plastic or soft face hammer • Three
jaw puller or A/C clutch tool Procedure: 1. If you
are replacing the bearing only, here is the part number from the OEM ford
bearing: Nachi 30BG05S5DS 2. Remove
the serpentine belt. This is done by placing a 3/8” breaker bar in the
tensioner (located in the middle of the engine) and using it to take the
tension off of the belt. 3.
Disconnect the wire to the electromagnetic clutch. 4. Remove
the center bolt from the hub of the clutch assembly (8 mm) you will have
to snap the wrench or ratchet quickly to keep the compressor shaft from
turning while doing this. You can also get a spanner wrench to hold the
compressor from turning. 5. Gently
tap the screwdriver between the clutch plate and pulley with the hammer at
several intervals around the clutch plate to remove the clutch plate and
shim(s). 6. Remove
the pulley and bearing assembly by removing the snap ring holding it on. 7. You
will also need a three jaw puller or clutch puller tool to assist in
removing the pulley assembly. Be careful when setting the jaw on the
puller so that you do not damage the electrical connector to the coil. For
replacing the bearing, you can remove just the pulley and not the coil if
you set the jaws out far enough to just grip the pulley, but the coil is
also pressed onto the shaft and will need a puller to remove. The coil is
really pressed in hard and will need quite a bit of work to pull off. I do
not recommend removing the coil if you just need to replace the pulley,
bearing or clutch plate. 8. If
there is oil all over the clutch from the compressor shaft, your life just
got uglier. See replacing of compressor below. (You technically do not
have to replace the compressor, just the seal to the shaft. And that
requires removing the compressor…) 9. To
install the clutch, if using the same clutch, installation is the reverse
of removal. Be sure to align the socket for the power connector in the
coil so that it is on top of the connector and sitting in the notch of the
compressor housing. You will need to press the coil onto the shaft. A
large socket will help seat the coil. Use the rubber hammer to set the
pulley back on the shaft. 10.
Installing a new clutch assembly or pulley will require you to set the
movement distance (air gap) between the plate and the pulley face when the
clutch is energized. This movement distance must be between .013” and
.033” as measured with a feeler gauge. 11. If the
distance between the clutch plate and pulley is outside of the minimum and
maximum clearances, you will need to add or remove shims to get it into
spec. 12. Torque
the center bolt to 12 ft. lbs.
For the
rest of these parts, you will need to evacuate the system and replace the
accumulator/dryer as well. To evacuate a charged system, take the car to a
shop and have them reclaim the refrigerant as it is illegal, immoral, and
probably fattening to vent it into the air. If you do not have any charge
to the system, all the easier for you :p Whatever you do, make sure that
you do not try *any* of the below repairs until you are absolutely 100%
sure that the system has no charge or pressure in it!! And always wear
safety glasses when dealing with the A/C system! Section 3. Part to be replaced: Accumulator/ dryer Located by the heater box on the passenger side Tools and parts needed: • Safety glasses • A/C – Fuel line disconnect tool • 27mm Combination wrench • 22mm Combination wrench • 8mm wrench or socket/ ratchet • Bottle of PAG 46 DEC oil • Nylog • PB blaster Procedure: 1. Remove the low pressure transducer switch (see Section 1 for details) 2. Soak the nut that is attached to the top tube of the evaporator with PB blaster. Wait a few minutes and soak it again. When you think you have let it soak in enough that you can break it loose, grab the can of PB blaster and hit it again. You might need to repeat this process a few times… 3. Use the 27mm wrench on the nut from the evaporator and the 22mm wrench on the nut for the accumulator. The nut on the accumulator is part of the tube and does *not* turn. It is there so you do not twist the tubing when tightening the nut from the evaporator. Turn the evaporator nut clockwise (as viewed from the front of the truck looking at the firewall. This was a reaaaly tight nut on my truck, with some of the threads showing a fair amount of rust on the accumulator. 4. You may still need to repeat step 1 to get step 2 to work… 5. Disconnect the large refrigerant line from the other side of the accumulator. (This is the line that goes around the back of the engine and then comes underneath the radiator hose and curls in a “U” up to the accumulator.) You will need the largest disconnect tool (white) to unhook this line. Before you put the disconnect tool on, you will need to remove the metal keeper. This can be removed by using your hands or a gentle pry with a small screw driver. They just slide off of the connection point. It will take a bit to muscle the hose off of the accumulator/ dryer as the o-rings will hold it on pretty tight. 6. Take your 8mm wrench/ socket and remove the 8 mm bolt that holds the bracket to the bottom line coming out of the evaporator. The bracket will swing down out of the way. 7. Take the 8mm wrench/ socket and loosen (you do not need to remove it completely) several turns the bolt that holds the clamp around the accumulator dryer. 8. Slide the accumulator/ dryer up and out of the truck. Make sure your new accumulator/ dryer matches the old one. 9. Pour as much oil out of the old accumulator/ dryer as you can into a container. You will need to put in at least this much new PAG oil into the new Accumulator/ Dryer 10. When you are ready to put the new one in (remember, this is the last step you want to do before sealing and refilling the system so do not break the seals on the new unit until you are ready to seal it up and fill the system) be sure that it has all new o-rings and coat them with Nylog or PAG oil. There will be two o-rings at the evaporator end and two o-rings at the refrigerant line end, plus one o-ring for the low pressure transducer.
Section 4. Part to be replaced: Orifice tube Located in the lower tube coming out of the Evaporator core. Tools and parts you will need: • Safety Glasses • A/C – Fuel line disconnect tool • Orifice tube removal tool • Bottle of PAG 46 DEC oil • Nylog • New Orifice tube • New Accumulator/ Dryer Procedure: 1. Remove Accumulator/ Dryer (see section 3 for details) 2. Remove the metal keeper and use the second smallest A/C line disconnect tool (blue) and disconnect the short refrigerant line from the bottom line of the evaporator. 3. Use the Orifice tube tool to extract the orifice tube. You can also use a pair of needle nose pliers instead of the Orifice tube tool, but I could not get a grip on the orifice tube with the pliers I had, so rather than fight it for two hours, I went and bought the damn orifice tube tool. Made my life much easier……* Protip: Compressed air can be used to blow the orifice tube out if it is being stubborn. (wish I would have thought of that…Again thanks 4x4 Junkie for that helpful tip) 4. Make sure your new orifice tube matches the old, and pitch the old tube. Don’t bother trying to clean and reuse it, they are only $2.00, it isn’t worth it. 5. Be sure to put some PAG Oil on the o-rings of the new Orifice tube 6. Replace the o-rings and put Nylog or PAG Oil on them when hooking the line back up.
Section 5. Part to be replaced: Compressor. Located at the top of the engine on the driver side. Tools and parts you will need: • Safety glasses • 3/8” breaker bar • ¼” flat blade screwdriver • 13mm socket • 8mm combination wrench • 10mm combination wrench • Ratchet • Torque wrench • Bottle of PAG 46 DEC oil • Nylog • New compressor • New Orifice Tube • New Accumulator /dryer Procedure: 1. Disconnect the battery using the 8mm wrench. 2. Remove the rubber air intake pipe from the upper intake and remove the air filter box. You can leave the end that is attached to the inner fender in the truck. You will need to unhook a few sensors to do this. The pipe is clamped to the upper intake with a regular worm screw hose clamp. Use the screwdriver to loosen it several turns, and it will slide off. The air cleaner end has a spring clamp. Just undo it. 3. Remove the serpentine belt. This is done by inserting the 3/8” breaker bar into the square hole on the tensioner. Move the tensioner enough to slip the belt off of the idler pulley in the center of the belt path. Then remove the belt from the compressor. The tensioner is located just below the alternator on the passenger side. 4. Disconnect the connector to the electromagnetic clutch. 5. Unbolt the refrigerant lines using a 10 mm wrench. Pull the lines out of the compressor and set aside. This bolt is kind of hard to get to as the refrigerant lines and the intake manifold block easy access to it. You can break it loose and then by unbolting the compressor from the truck will make it easier to spin out. 6. Remove the four 13mm bolts holding the compressor onto the bracket. 7. The compressor should be free now to take out of the engine. 8. You will now need to clean/ purge the condenser and lines if you are reusing them. See Appendix A. 9. Installation is the reverse of removal. Be sure to put 5 ounces of PAG oil into the new compressor and stand it up on the clutch pulley for about ten minutes or so to ensure that the front seal gets lubricated before putting it in the truck. If you do not ensure that the front seal is properly lubricated, you will leak coolant through the front seal. 10. Protip: for measuring out proper amount of PAG Oil, my bottle did not have any markings to say how much was in it. Go to your local pharmacy (CVS, Walgreens etc, not your dealer or liquor store J ) and ask for an 8 oz medicine bottle. They are brown and have ounce marks on them, and work perfect for metering out just the right amount of oil. 11. Be sure to put two ounces of PAG oil in the accumulator/ dryer and an ounce in the evaporator. 12. When placing the new compressor in, make sure that the compressor sits flush on all four mounts of the mounting bracket. If the bracket is warped, straighten or replace the bracket entirely. If you mount it to a warped bracket, it will twist the compressor and cause it to leak. 13. Do not tighten the bolts until they are all in and finger tight, then torque them evenly until they are at 15-21 ft. lbs. DO NOT OVERTIGHTEN!!! Over tightening will cause leaks. 14. When hooking up the refrigerant lines, replace all of the o-rings and coat the new ones with some Nylog or PAG oil. Torque the 10mm manifold bolt to 13 – 17 ft. lbs. 15. Protip: I ended up unbolting my compressor so that I could bolt up the manifold to the compressor easier. It made all the difference, then I retorqued the compressor mounting bolts. 16. After you hook up the hoses, rotate the compressor 10- 12 times by hand to push the oil into the lines. Section
6. Part to
be replaced: Large Refrigerant line assembly (the one that wraps
around the back of the engine). Located
attached to the compressor and wrapped around the back of the engine and
attached to the accumulator/ dryer. Tools
Glasses • A/C
– Fuel line disconnect tool • 10mm
socket • 11mm
deep well socket • Dremel
Tool with cut off wheel or grinder • New
Accumulator/ Dryer • New
Orifice tube • Bottle
of PAG 46 DEC oil • Nylog Procedure: 1. If
available, kick a Ford engineer in the ass for this stupid setup.
Otherwise, cuss him out. 2.
Disconnect the battery using the 8mm wrench. 3. Remove
cleaner end has a spring clamp. Just undo it. 4. Remove
the Accumulator/ Dryer. (See section 3) 5. Remove
High side pressure transducer. (See section 1) 6. Remove
Refrigerant line assembly from the rear of the compressor by removing the
10mm bolt that holds it to the compressor. 7. Using
the second smallest A/C disconnect tool (blue), unhook the small line that
has the high side port from the condenser. 8. Now the
fun begins… 9. Unbolt
the engine wiring harness from the engine, right next to the driver side
valve cover. 10. Unhook
the vacuum line from the EGR valve (if equipped). 11. Unhook
the brake booster line from one side. Does not matter which side, I choose
the booster side because I did not need any tools to pop it out of the
grommet 12. Using
the 10mm socket, unbolt the engine wiring harness from the firewall. 13. Using
the 11mm deep well socket, remove the nut that holds the bracket
supporting the wiring harness (right next to the pigtail socket that you
just unbolted in step 10) and pull the bracket off. This will now expose
an 11 mm stud that secures the ground wire from the harness to the truck
body. 14. Using
the 11mm deep socket, remove the 11mm stud that secures the ground wires. 15. You
will now need to remove the bracket that supports the hose at the rear
passenger side of the block. I have no clue how it is fastened to the
block, It is two tight of a space for me to get my hands in deep enough to
even feel the cussing bolt let alone put a wrench/ socket on it… The
bracket comes up from the rear of the cylinder head/ block and wraps
around the refrigerant hose and is riveted to itself in a shape of a “P”. 16. My
solution…. Take a Dremel tool and grind the rivet off. This will also be
a chore as you will have to lean across the engine and the transmission
dipstick tube is really close. Once the rivet is ground down, spread the
bracket apart enough to drop the hose through the opening. 17. The
new hose thankfully comes with a new bracket that is held to the hose with
an 8mm bolt. Remove the bracket from the hose and reuse the old one still
attached to the engine block and use a zip tie or small bolt to close it
back up when reinstalling. I also used a piece of the foam insulation off
of the old hose to act as a cushion on the new hose between the bracket
and the hose. 18. You
now have everything removed/ loosened and ready to pull the refrigerant
line assembly out of the truck. Start by wiggling/ finagling the end that
was hooked up to the accumulator/ dryer under the radiator hose and heater
hoses. This will take some work to get them under these hoses, but then
the hose should be free from that side. Gently pull the hose up and work
it out from behind the engine. You will come out behind the wiring harness
that was bolted into the firewall. Stop. 19. Go to
the driver side of the truck and take the end where it bolted to the
compressor and move it down and away from the compressor and out from
under the wiring harness where it bolted to the engine harness. You will
then need to finagle it around the brake booster hose and the throttle
cable. 20. The
refrigerant line should then come out. If replacing entirely, drain the
oil out of the old one into a cup to measure out the same amount of new
PAG oil to put in the new hose. 21.
Replace all o-rings and coat them with Nylog or PAG Oil 22. Side
note, I visited the local Pull A Part and noticed that all the 98 and
newer Rangers had the refrigerant line from the compressor to the
condenser was secured to the condenser with what looked like an E-7 bolt
(basically a reverse torx bolt) Something for the newer Ranger owners to
consider…)
Disconnect tool:
Springlock keepers, they can be removed using your hands only or a small screwdriver to pry them off: Section
7. Part to
be replaced: Small refrigerant line Located on
the passenger side attached to the lower evaporator and the condenser Tools
Glasses • A/C
1/4" flat blade screwdriver • 8mm
wrench • Tube
cutter *optional* • Inline
filter *optional* • New
the Accumulator/ Dryer. (See section 3) 4. Remove
the Large refrigerant line assembly (see section 6) or move the passenger
side end of it out of the way if not replacing the large line. 5. Unhook
the line from the evaporator using the second smallest A/C disconnect tool
(blue) 6. Unhook
the line from the condenser using the smallest A/C disconnect tool (red) 7. Replace
the Orifice Tube (see section 4) 8. Be sure
to replace and coat the o-rings with PAG oil or Nylog. 9.
**Optional** the next steps are recommended if you are replacing the
compressor, these will walk you through installing an inline debris
filter. If you replace the condenser or there is nothing wrong with the
compressor, you do not need to do the following steps. 10. Cut
the aluminum tubing on the end that connects to the condenser in the
middle. The inline filter kit that I used had a screen at one end and
would allow you to put a shortened orifice tube in it, but I just used it
for the screen to catch any debris that did not get flushed out of the
condenser during the flush process. You can safely remove an inch of the
tubing from the middle of the aluminum tube at the condenser end to make
up for the length that the filter will add to the line. The flexible
rubber part of the refrigerant line also gives you a little bit of leeway
when installing the line. 11. The
filter that I used came with compressor fittings and rubber gaskets that
fit perfectly inside of the filter housing. You choose the size needed for
the line. The OEM line that I removed was 5/16” but the new replacement
line was 3/8”. Be sure to put Nylog on the gaskets and tighten the
compression nuts down good and tight. You might practice with your old
line first if replacing the line. Section
8. Part to
be replaced: Condenser. Tools
and parts needed: • A/C -
fuel line quick connect tool • 10mm
socket • 8mm
socket • 2”
extension for socket •
Ratchet •
Assorted A/C o-rings • PAG 46
DEC oil • Nylog Procedure: 1. Remove
small refrigeration line from the passenger side of the condenser. (See
section 7) 2. Remove
the driver side refrigerant line from the condenser. (See section 6, step
7) 3. Remove
the two 10mm bolts that hold the top of the radiator to the front clip/
core support. 4. Lift
the radiator up about 3/4” and tilt it back toward the fan. It might
make it easier if you remove the charcoal canister, it is held on by a
single 10mm bolt and sits up against the driver side inner fender and is
kind of up against the radiator support. 5. Keep in
mind that there are two transmission lines connected to the radiator on
the driver side, be careful with those as you are tilting the radiator
back. Also keep in mind that your fan is plastic… and is likely to break
if you are not careful… 6. Remove
the two 8mm bolts that secure the condenser to the front clip/ core
support at the top of the condenser. 7. Tilt
the condenser back and carefully slide it out in the gap between the
radiator and the front clip/ core support. You might have to move the wire
harness that runs along the top of the condenser a little to wiggle the
condenser out. 8. Install
is the reverse of removal. Be sure to replace all the o-rings when putting
it all back together. Remember to replace all o-rings and lightly coat
them with PAG Oil or Nylog. 9. Side
consider…) *I did not
remove my condenser, the above procedure is based upon examining the truck
and how it is put together and removing the radiator bolts to see if it
could be tilted forward enough for the condenser to be removed. If anyone
has experience removing this and has an easier procedure or notices faults
or omissions in mine, please let me know.* Appendix
A Flushing
the components. Tools
glasses! • Flush
kit. I used a Mastercool A/C system flush kit. Got it off of Amazon for
$45 • Flush
solvent Ford recommends a terpine based solvent or Dura Flush for its A/C
systems. I used turpentine for the initial flush to get the big gunk out,
then the Dura Flush as a final flush, as the Dura Flush solvent cost $32 a
quart… • Shop
air to charge the flush kit bottle. • A
metal catch can to reclaim the solvent as it comes out of the component. I
used a 32 oz tomato juice can that I cleaned out. • Paper
towels • Funnel Procedure: 1. Put
your safety glasses on! 2. Do NOT
flush a compressor. 3. Do NOT
flush an accumulator/ dryer or any hose with a filter permanently
attached. Those items will need to be replaced. 4. Place
the catch can at the end of the component being flushed. If flushing the
component on the truck, be sure to put the catch can at the lowest
opening. You may need to put a tube at the outlet end to reach the can. I
was able to use the short refrigerant line plugged back into the bottom
line of the evaporator, and the condenser was already in such a way that I
did not need a hose or tube to extend from the condenser. 5.
Assemble the hose and the nozzle on the flush kit. 6. Fill
the flush kit bottle with the flush solvent to the half way mark and
replace the cap/air fill nozzle assembly 7. Charge
the bottle with shop air 8. Put the
rubber tip in the opposite end from the catch can. Be sure that you firmly
press the rubber tip into the part being flushed so that it seals well,
and have the bottle tipped so that the hose is pointing down from the
bottle. 9. Squeeze
the trigger until all of the solvent and air are released from the flush
bottle. 10. Get
the catch can and then open the bottle. Put the funnel back in and a paper
towel in the funnel to filter the solvent. 11. Put
the solvent in the bottle and repeat steps 2 through 8 several times. 12. Once
you feel that you flushed it enough, change out the solvent to a clean
solvent and repeat steps 2 – 8 again, and then do it again with the Dura
Flush as the last step. 13. Let
the solvent evaporate out of the system for a few hours 14. I
highly recommend putting a filter on the liquid line coming out of the
condenser after flushing the condenser. The design of the condenser is
such that it will be nearly impossible to flush all of the debris out of
it. If you are getting a serious amount of black gunk out of it or your
compressor died from the “black death” replace the condenser! Reasons
why you flush the evaporator and condenser...
Appendix
B How to
prep your newly rebuilt A/C system for its first charge of refrigerant. So now you
got it all together. You are ready for some Ice Cold A/C again. Here is
what you need to do before you put refrigerant in it. Tools
you will need: •
Manifold gauge set • Vacuum
pump for evacuating automotive A/C systems. Procedure: 1. Hook up
your manifold gauge set. Blue to Low side (top of accumulator/ dryer) Red
to High side (refrigerant line behind driver’s headlight) Make sure all
four of the valves are closed. 2. Hook
the vacuum pump to the yellow hose on the gauge set. Make sure the valve
on the pump is off. 3. Turn on
the pump motor 4. Open
all four valves on the gauge set 5. Open
the valve on the pump. 6. Let the
vacuum run and the low side gauge (blue) should show negative pressure.
Let it pump down to as close to a negative full atmosphere as you can
(this varies depending on altitude, see chart below) Normal atmospheric
pressure is about 28 or 29 inches of Hg for people at 1000 to 1500 ft
above sea level. 7. If it
is not pumping down, you have a pretty good sized leak in your system
somewhere. 8. After
it gets down to the proper vacuum level, let the pump run for about 2
hours. If it is very warm and/or humid, let it run longer. On an extremely
hot and humid day, let it run for 4+ hours. Running it longer than 4+
certainly won’t hurt. You can cut the time down on running the vacuum
pump by starting the engine and letting it warm up to operating
temperature. This will help boil out any moisture in the lines quicker.
With the engine hot, your vacuum pull time will be about an hour or so, 2
on the very hot and humid days. Again running the vacuum longer won’t
hurt it. *special
note for atmospheric pressure/ vacuum and altitude... The vacuum you will
be able to pull will be directly related to your height above sea level
(see chart below) Your atmospheric pressure is lower as you get higher in
altitude. Please use this chart to calculate how much vacuum you should
pull for your altitude: Sea Level
= -29.92 in-Hg 500 feet =
-29.4 in-Hg 1000 feet
= -28.9 in-Hg 1500 feet
= -28.3 in-Hg 2000 feet
= -27.8 in-Hg 3000 feet
= -26.8 in-Hg 4000 feet
= -25.8 in-Hg 5000 feet
= -24.9 in-Hg 6000 feet
= -24.0 in-Hg 7000 feet
= -23.1 in-Hg 8000 feet
= -22.2 in-Hg (Thanks
4x4 Junkie!) 9. After
it has run for the required length of time, close all 4 valves on the
gauge set 10. Close
the valve on the pump. 11. Turn
off pump. Do not turn off the pump until the valve on the pump is closed. 12. Remove
the pump from the gauge set and then remove the gauge set from the car. 13.
Replace the caps on the valves on the compressor. 14. Let
the car sit for about an hour or so. If you can, leave it sit overnight,
this can let you know if you have a slow leak. 15. After
letting it sit, hook up the manifold gauge set again. Open the valve on
the blue hose. Note the reading. It should still have a -28 inches Hg
vacuum. If it does not, you have a slow leak somewhere. 16. If you
still have vacuum, Hook up your vacuum pump and pull a vacuum for 5 to 10
minutes (just to be sure) and you can now charge the system using Appendix
C. 17.
Remember to purge the yellow hose with refrigerant first! You might
be wondering why the vacuum needs to be applied for so long. This is to
remove any excess moisture from the system. As the pressure decreases, the
moisture will boil from the air easier and be pumped out. You may even see
this on a really humid day as the water spits out of the vacuum pump. Letting
the car sit is a good way to test for leaks without having to put
refrigerant in, this way you can fix them easier. Another protip given to
me by 4x4Junkie is to start the truck and get it up to temperature for
several minutes before pulling the vacuum. this will allow the boiling off
of the moisture inside the system much quicker.
Appendix
C Charging
the system. Tools
you will need: •
Manifold gauge set for R134a automotive A/C Do not opt for the cheap
single gauge filler hose that hooks into the low side. You really need to
monitor the pressure on both sides to properly fill and test the system.
If you do not have and cannot afford the manifold gauge set, rent or
borrow one. •
Thermometer • The
appropriate amount of refrigerant for your truck. (97 Ranger’s require
1lb 9oz or 25 Oz.) Keep in
mind, the only way you can accurately put the correct amount of
refrigerant in is to evacuate the system and add the recommended amount of
refrigerant and then stop. (25 ounces in the case of 1997 Ranger) Unless
you have access to very expensive machines that can weigh and meter out
the exact amount needed you will want to keep a very close eye on the
pressure for both Low and High side, and the outside temperature and the
inside the center left dash vent temperature to get you close to the mark.
Remember, if you overcharge the system, you can break some expensive
parts. A little bit of info that might make your life easier: 1 pound = 16
ounces. The common r134a can is 12 ounces. The sticker under the hood is
rated in pounds and ounces (my 97 calls for 1 lb and 9 oz) Procedure: 1. Make
sure all 4 valves are closed on the manifold gauge set. 2. Hook
the blue quick connect to the low side valve on the compressor. (Top of
the Accumulator/ dryer) 3. Hook
the red quick connect to the high side valve on the compressor.
(Refrigerant line behind the driver side headlight) 4. Hang
the gauge set from the hood making sure that none of the hoses can contact
the belts or fan. 5. Let the
yellow hose run from the gauge set so that it hangs over the bumper. 6. Take a
can of refrigerant and put the tapping device/valve on the can and run the
valve in to puncture the can. Keep the valve closed. 7. Attach
the valve to the yellow hose. 8. Open
the valve on the can 9. At the
manifold end of the yellow hose, there should be a shrader valve to bleed
off pressure. Open the valve on the refrigerant can and take a small
screwdriver and depress the shrader valve until the refrigerant comes out
of it. This purges the yellow hose of any regular air and moisture which
you do not want in the system. 10. If
this is just a recharge or “top off” SKIP to Step 14!! 11. With
the truck off, open both the blue and red valves on the hoses next to the
trucks refrigerant lines. 12. Open
both valves on the manifold portion. This will allow refrigerant to
equalize on both sides of the compressor. 13. Close
the low side manifold valve. 14. Close
the High side Manifold valve. You must do this before going to the next
step!! 15. Start
the truck, and with the A/C off, check the static pressure. To check the
pressure, open both the blue and red valves on the hoses next to the car’s
refrigerant lines. DO NOT OPEN THE VALVES ON THE MANIFOLD PORTION!!! If it
is above 70 psi, you should have enough Refrigerant to cycle the
compressor. A rule of thumb, your static pressure will be close to the
outside (ambient) temperature when you are checking it. 16. Put
the A/C controls to Max A/C and the blower on the highest setting. Make
sure the A/C switch is on. 17. Make
sure the engine is running and A/C is on full blast. 18. Look
at the low side gauge (blue). It should read above 20 psi and below 55 psi
depending on the temperature outside at the time. Your high side gauge
(red) will be in the range of 100 psi to 350 psi, depending on how hot it
is outside. When the engine fan kicks in, your high side pressure will
drop quite a lot. 19. If you
are doing a fill with the exact amount of refrigerant (25 oz for a 97
Ranger) you may add the rest of the refrigerant now. 2 full 12 oz cans and
a smidge of a third can total. Do not add any more than this!! (if your
Ranger is a different year, please look up the proper amount for your
truck) 20. For a
top off of a low charge system, if your low side pressure is below 20 psi,
you can add refrigerant to the system via the yellow hose. Pay close
attention to the pressure temperature chart when adding coolant. Something
else to consider, if you are doing this on a cool day (below 65 degrees)
you can easily overcharge the system and not know it, so I would recommend
charging it on a day that is warmer than 70 degrees. If your High side
pressure goes above 300 you are in danger of blowing out your condenser… 21. Now
that you have the R134a can attached and the valve open, open the blue
manifold valve. DO NOT OPEN THE RED ONE UNDER ANY CIRCUMSTANCE AS THE HIGH
PRESSURE WILL CAUSE THE REFRIGERANT CAN TO EXPLODE!! Opening the blue
valve allows the refrigerant to be pulled into the low side of the
compressor to charge the system. Keep an eye on the gauges and charge the
system until the low side is just under the low side pressure that
correlates to the outside temperature. The high side should not get much
higher than 350 psi on a hot day. On a cooler day, both your low and high
side pressures will be lower. If you empty your refrigerant can, turn off
the blue valve on the manifold before unhooking the empty can. Be sure to
purge the yellow hose again when you attach the new can. 22. Protip:
if you want the can of refrigerant to load a bit faster, get a pan of hot
tap water (no need to put it on the stove to heat it, straight hot water
will work) and dip the can in it as it fills. This will heat the
refrigerant and make it fill a bit faster. 23. When
you reach the desired pressure and temperature settings (as confirmed by
your pressure/ temp chart), you should have nice cold air again. Close the
blue manifold valve, close the refrigerant can valve (leave the can on the
gauge set. This way you will not have to purge it the next time you use it…even
if the can is empty, leave it on the gauge set, it will protect the yellow
hose from getting contaminated with dirt.) 24. Your
air temperature coming out of the middle vent in the dash should read as
noted in the below table for the outside temperature listed. Since you
cannot accurately measure how much refrigerant is in the system and how
much you have added, I would keep an eye out on the temp pressure chart.
Once the vents get close to the temps listed, stop filling. 25. Close
both valves at the refrigerant lines. Turn the engine off and release the
quick connects. Warning: they will be hot, especially the red or high side
connection. 26.
Replace the caps for the valves and put your tools away, you are done.
Appendix
D Troubleshooting So let’s
say that you have not led a clean life and karma has caught up to you and
your truck needs more than a recharge. I will show you how to replace the
accumulator/dryer, the refrigerant lines, condenser and the compressor.
This next section will be devoted to some simple troubleshooting to find
out what is wrong with the A/C. The first
thing you want to do is find out why your A/C is not working. Let’s
start with pressure. Does it hold a charge? If it is leaking, you need to
find where it is leaking at. Here is how to look for leaks: 1.
Following the steps above to recharge the system, put a leak detecting dye
refrigerant can in the system. Then after a week or whenever the system
leaks out, get a UV light and find out where the leak is. 2. Check
the condenser thoroughly, especially looking for places where a rock could
have damaged it. 3. Check
the connections where the hoses hook into the components, and the
compressor around the pulley, valves and hose connections. 4. Make
sure the lines are not cracked or bent sharply. If you
have not found the leak in the engine compartment, you have probably have
a bad evaporator. It is inside the heater box. Ok, so I
have a charged system, and still no cold air. What now, Einstein? Well let’s
define “charged system”. For the A/C to work there must be around 70
psi static pressure in the system. If the pressure is below 70 or
extremely high, the transducers will not send a signal to turn on the
clutch. If you have pressure within the 40 to say about 70 psi static
pressure range, your compressor should start. If it doesn’t start, check
these areas: 1. Make
sure the condenser is clean and not clogged with bugs, dirt, small
animals, children etc.. 2. Also
make sure the fins are straight and allow air to pass through. You can get
a fin comb to straighten them out if needed. 3. Make
sure all the fuses for the A/C compressor and blower are good. 4. Check
the relay for the compressor clutch. You can do this by swapping it with
other relays (Horn relay is a good one to use) 5. Check
to make sure all connectors are getting good connection, especially the
clutch coil and Pressure transducer switch harness. 6. Take an
ohmmeter and check for continuity on the clutch coil by unhooking the
connector and checking for continuity between the terminals. If there is
no continuity, your electromagnetic clutch is bad and will need replaced. 7. If all
the above check out, you are left with a bad pressure transducer switch or
wiring harness to the compressor or pressure switches. So we now
know that it is charged, everything checks out mechanically and
electrically. The compressor kicks in and turns, but it just does not put
out cold air. Well, I hate to tell you this, but your compressor is worn
out and is not building pressure on the refrigerant. You will need to
replace the compressor. This can also be confirmed by the manifold gauge
set. If the pressure differential between the high and low side is very
small, with typically fairly high low side pressure and low high side
pressure, the compressor is shot. So what
say the compressor snaps belts or continuously squeals? The compressor is
probably locked up; you will need to replace the compressor. Appendix
E Sources: Flush or replace the condenser? http://www.aa1car.com/library/2003/us40330.htm Flushing agents: http://www.acsource.com/brightsoluti...3832quart.aspx http://www.amazon.com/Four-Seasons-6...sim_sbs_auto_1Flush gun: http://www.amazon.com/Mastercool-910...sim_sbs_auto_2 Inline A/C filter: http://www.autozone.com/autozone/par...er=946933_0_0_ Refrigerant and oil capacities for Ford vehicles: http://www.techchoiceparts.com/refri...ties/efgh#ford Note: the values in this chart were different than what the sticker on my radiator support supplied for my truck, I went with the sticker’s values. General A/C Knowledge by TRS’s very own MAKG (from TRS Magazine from June 04) http://www.therangerstation.com/Maga...une04/tech.htm This is an excellent source for those of you driving the older model Rangers, but much of the info provided carries over to the newer R134a equipped trucks. Why get Double End Capped PAG oil instead of regular PAG Oil? http://www.autoactech.com/issues.htm Good all-around information: http://www.explorerforum.com/forums/...d.php?t=221950 Another chart to confirm capacities: http://www.scribd.com/doc/48453503/p...application-05 Where I got my DEC PAG 46. Pretty good price too: https://www.ackits.com/pc/PCG46CT/Co...6+8+ounces+DYE Where I got the Nylog: https://www.ackits.com/pc/RT201B/Nyl...or+HFC+Systems Temperature and Pressure calculator: http://www.csgnetwork.com/r134apresstempconv.html Altitude atmospheric pressure chart for calculating how much vacuum to pull:http://www.engineeringtoolbox.com/ai...ure-d_462.html Thanks to: 4x4Junkie Cvar for their input in making this How-to more precise, easier to read and just all around better. Hope this helps you get your A/C going again. AJ
