Trucks Of The Month
This
page is here to help you break down the V.I.N. on your Ford truck.
Following the 17-digit
V.I.N. on your
truck, select the character for each box that matches it's place in
the V.I.N.
Sample
V.I.N. (Vehicle Identification Number)
Typical VIN
Position Number |
Position
1-3 |
World
Manufacturer Identifier |
Position 4 |
Restraint System Type
Brake Type and GVWR Class (Trucks and Vans Only) |
Position 5-7 |
Line, Series, Body Type |
Position 8 |
Engine Type |
Position 9 |
Check Digit |
Position 10 |
Model Year |
Position 11 |
Assembly Plant |
Position 12-17 |
Production Sequence
Number |
V.I.N. Number Breakdown
Position |
Definition |
1st
Position (Nation Of Origin) |
1 - USA |
2 - Canada |
3 - Mexico |
2nd
Position (Manufacturer) |
F - Ford |
3rd
Position (Type Of Vehicle) |
C - Basic (Stripped) Chassis |
D - Incomplete Vehicle |
M - Multipurpose Vehicle |
T - Truck |
4th
Position (Gross Vehicle Weight Rating |
A - Up To 3,000 lbs. |
B - 3,001-4,000 lbs. |
C - 4,001-5,000 lbs. |
D - 5,001-6,000 lbs. |
E - 6,001-7,000 lbs. |
F - 7,001-8,000 lbs. |
G - 8,001-8,500 lbs. |
H - 8,501-9,000 lbs. |
J - 9,001-10,000 lbs. |
K - 10,001-14,000 lbs. |
L - 14,001-16,000 lbs. |
M - 16,001-19,500 lbs. |
5th,
6th, 7th Position (Line, Series, Body Type) |
E11 — Econoline Club Wagon |
E31 — Econoline Club Wagon
(Heavy Duty) |
S31 — Econoline Club Wagon
(Super Club Wagon) |
E14 — Econoline E-150 (Cargo
Van) |
E24 — Econoline E-250 (Cargo
Van) |
E27 — Econoline E-250
(Commercial Cutaway) |
E29 — Econoline E-250
(Commercial Basic) |
E30 — Econoline E-350 (RV
Cutaway) |
E34 — Econoline E-350 (Cargo
Van) |
E37 — Econoline E-350
E39 — Econoline E-350
S24 — Econoline E-250 (Super
Van) |
S34 — Econoline E-350 (Super
Van) |
E40 — E-Super Duty (RV
Cutaway) |
E47 — E-Super Duty
F07 — F-150 Flareside, 4x2 |
X07 — F-150 (SuperCab)
Flareside, 4x2 |
F08 — F-150 Flareside, 4x4 |
X08 — F-150 (SuperCab)
Flareside, 4x4 |
F17 — F-150 Styleside, 4x2 |
X17 — F-150 (SuperCab)
Styleside, 4x2 |
F18 — F-150 Styleside, 4x4 |
X18 — F-150 (SuperCab)
Styleside, 4x4 |
F27 — F-250 Styleside, 4x2 |
X27 — F-250 (SuperCab)
Styleside, 4x2 |
F28 — F-250 Styleside, 4x4 |
X28 — F-250 (SuperCab)
Styleside, 4x4 |
U12 — Bronco II 4x2 |
U14 — Bronco II 4x4 |
U22 — Explorer (2-door), 4x2 |
U32 — Explorer (4-door), 4x2 |
U24 — Explorer (2-door), 4x4 |
U34 — Explorer (4-door), 4x4 |
U35 — Explorer (4-door), AWD |
U52 — Mountaineer (4-door)
4x2 |
U54 — Mountaineer (4-door)
4x4 |
U55 — Mountaineer (4-door)
AWD |
R10 — Ranger 4x2 |
R11 — Ranger 4x4 |
R14 — Ranger 4x2 (2-door
SuperCab) |
R15 — Ranger 4x4 (2-door
SuperCab) |
R18 — Ranger 4x2 (4-door
SuperCab) |
R19 — Ranger 4x4 (4-door
SuperCab) |
8th
Position (Engine Type) |
A - 2.3-Liter 4-Cylinder
(Ranger 1997 and older) |
B - 2.5-Liter 4-Cylinder
Diesel (Ranger) |
C - 2.5-Liter 4-Cylinder
(Ranger)(2.0 on older Rangers) |
E - 2.3-Liter 4-Cylinder
Diesel (Mitsubishi) |
E - 4.0-Liter 6-Cylinder -
SOHC (Explorer, Mountaineer) |
F - 7.3-Liter 8-Cylinder
Diesel (Econoline) |
L - 5.4-Liter 8-Cylinder (Econoline,
F-150, F-250) |
M - 5.4-Liter 8-Cylinder
Natural Gas (Econoline, F-150, F-250) |
P - 2.2-Liter 4-Cylinder
Diesel (Ranger) |
P - 5.0-Liter 8-Cylinder
(Explorer/Mountaineer) |
S - 2.8-Liter 6-Cylinder
(Ranger) |
S - 6.8-Liter 10-Cylinder (Econoline) |
T - 2.9-Liter 6-Cylinder
(Ranger) |
U - 3.0-Liter 6-Cylinder
(Ranger) |
W - 4.6-Liter 8-Cylinder
(F-150, F-250) |
X - 4.0-Liter 6-Cylinder
(Explorer, Ranger) |
Z - 5.4-Liter 8-Cylinder (Econoline,
F-150, F-250) |
2 - 4.2-Liter 6-Cylinder (Econoline,
F-150, F-250) |
6 - 4.6-Liter 8-Cylinder (Econoline,
F-150, F-250) |
9th
Position (Check Digit) |
Ignore |
10th
Position (Model Year) |
A - 1980 |
B - 1981 |
C - 1982 |
D - 1983 |
E - 1984 |
F - 1985 |
G - 1986 |
H - 1987 |
J - 1988 |
K - 1989 |
L - 1990 |
M - 1991 |
N - 1992 |
P - 1993 |
R - 1994 |
S - 1995 |
T - 1996 |
V - 1997 |
W - 1998 |
X - 1999 |
Y - 2000 |
1 - 2001 |
2 - 2002 |
3 - 2003 |
4 - 2004 |
5 - 2005 |
6 - 2006 |
7 - 2007 |
8 - 2008 |
9 - 2009 |
11th
Position (Assembly Plant) |
B - Oakville (Oakville,
Ontario Canada) |
C - Ontario Truck (Oakville,
Ontario Canada) |
D - Avon Lake (Avon Lake,
Ohio) |
E - Kentucky Truck (Jefferson
County, Kentucky) |
H - Lorain (Lorain, Ohio) |
K - Kansas City (Claycomo
Missouri) |
L - Michigan Truck (Wayne,
Michigan) |
M - Cuautitlan, Mexico |
N - Norfolk (Norfolk,
Virginia) |
P - Twin Cities (St. Paul,
Minnesota) |
S - Allen Park (Allen Park,
Michigan) |
T - Edison (Edison, New
Jersey) |
U - Louisville (Louisville,
Kentucky) |
Z - St. Louis (Hazlewood,
Missouri) |
12th
Position (Sequential Number) |
Last
6-Digits
Are The Sequence Number Beginning With A00001 (Ford) or J00001 (Lincoln/Mercury)
A00001-E99999 = Ford Division
J00001-L99999 = Lincoln / Mercury
Division
Here
Is A Sample Ford V.I.N. To Break Down:
V.I.N.#
1FTCR15X0TTA01050
Using
the sample V.I.N. given, you can see that this vehicle is:
Sample
V.I.N. Decoded |
Position
Code
Definition
Made
in the USA
(F)
Made
by Ford
(T)
Is
a Truck
4
(C)
Has
a G.V.W.R. of 4,001 - 5,000 lbs.
5,
6 & 7
(R15)
4x4 (2-Door SuperCab)
8
(X)
Has
a 4.0 Liter V-6
9
(5)
Check
Digit - Ignore
10
(T)
Was
built in 1996
11
(T)
Was
built in Edison New Jersey
12
(A)
Division
13
thru 17
(01050)
Was
the 1,050th truck built that year
