Home
Product / Build Guide Tech Articles Other Articles Featured Rangers Readers Rangers Classifieds
Ford Ranger Forum
Shirts & Decals
Charging System Troubleshooting
Trucks Of The Month
Translate
Shirts & Decals
CLICK to check out our TRS shirts & decals and support the site
Ranger Buyers Guide
Check Out These Girls!!
Check Out:
Pontiac Hunters
Sponsors Ad
 Sponsors Ad
Battery will not hold a charge
1. Alternator drive belt defective or not adjusted properly.
2. Electrolyte level low or battery discharged.
3. Battery terminals loose or corroded
4. Alternator not charging properly
5. Loose, broken or faulty wiring in the charging circuit.
6. Short in the vehicle wiring causing a continuous drain on the battery.
7. Battery defective internally.
Ignition light fails to go out
1. Fault in the alternator or charging circuit
2. Alternator drive belt defective or not properly adjusted
Ignition light fails to come on when key is turned on
1. Instrument cluster warning light bulb defective
2. Alternator faulty
3. Fault in the instrument cluster printed circuit, dashboard wiring or bulb holder
Charging System Problems
Problem Cause Solution
Noisy Alternator
  • Loose mountings
  • Loose drive pulley
  • Worn bearings
  • Brush noise
  • Internal circuits shorted (High pitch wine)
  • Tighten mounting bolts
  • Tighten pulley
  • Replace alternator
  • Replace Alternator
Squeal when starting engine or accelerating
  • Glazed or loose belt
  • Replace or adjust belt
Indicator light remains on or ammeter indicates discharge (engine running)
  • Broken belt
  • Broken or disconnected wires
  • Internal alternator problems
  • Defective voltage regulator
  • Install belt
  • Repair or correct wiring
  • Replace voltage regulator/alternator
Car light bulbs continually burn out - battery needs water continually
  • Alternator/regulator overcharging
Car lights flare on acceleration
  • Battery low
  • Internal alternator/regulator problems
  • Charge or replace battery
  • Replace alternator/regulator
Low voltage output (alternator light flickers continually or ammeter needle wanders)
  • Loose or worn belt
  • Dirty or corroded connections
  • Clean or replace connections
For more information on your charging system and how to check it, click HERE.
footer
Advertisers
The Ranger Station
   About
   Staff
   Contact Us
   Advertising
   Legal Notices
   959 Media LLC
   Copyright 1999-2018
Submit Content
Have Info To Share?
We're always looking for good content to share with other Ford Ranger enthusiasts. Click on the 'Submit' button to find out how you can get your submission posted and acknowledged for it.
