Cheap Dual Battery Setup |
Looking for a cheap dual battery setup for your Ranger or Bronco II? There's a few thing you'll need: (2) batteries Battery cables (some have found it's cheaper to buy a set of jumper cables and cut the clamps off) - Battery Cables Battery lugs for your cables (You'll need these for your cable ends) - Battery Lugs Battery terminals to connect to the batteries - Battery Terminals 12 gauge wire - 12 Gauge Wire ANL Fuses & Fuse Holder (1 For Each Battery) - ANL Fuse & Holder Battery Isolator Relay (Choose One): Diagram & Instructions: Follow the picture above Find a location to mount the second battery.. Make a short battery wire (4GA-6GA) from your main starting battery (+) positive to a fuse block. Make another battery wire (4GA-6GA) from your fuse block to the isolator. Make another battery wire (4GA-6GA) from the other side of your isolator to the other fuse block. Make a short battery wire (4GA-6GA) from the other fuse block to your other battery (+) positive. Make a single battery wire (4GA-6GA) from the (-) negative on your starting battery to the (-) negative on your other battery. Connect a 12GA wire from pin on the isolator to a fuse in your fuse box that is only 'hot' when the key is in the 'ON' position.
