Home
Product / Build Guide Tech Articles Other Articles Featured Rangers Readers Rangers Classifieds
Ford Ranger Forum
Shirts & Decals
Choosing A 33-Inch Mud Terrain Tire For Your 4x4
Trucks Of The Month
Translate
Shirts & Decals
CLICK to check out our TRS shirts & decals and support the site
Ranger Buyers Guide
Check Out These Girls!!
Check Out:
Pontiac Hunters
Sponsors Ad
 Sponsors Ad
One of the most important choices you make as a 4x4 owner is your tires. This page will give you information on the different tires available, as well as specifications and side by side comparisons. There's also links to check prices, reviews, and links to the manufacturers.
Hopefully, this page will better inform you of the tires available.
Looking for a 35-Inch Mud Terrain? Click HERE.
Tread Designs:
Light truck tires come in basically (3) designs:
All Season Tire
All Terrain Tire
Mud Terrain Tire
All Season - The all season tire belongs on cars and 2wd trucks. They're pretty much a passenger car tire with no off road capability. Keep walking past those to the better tires.
All Terrain - Every 4x4 truck or SUV should come with all terrain tires. An all terrain tire is built with off-road standards, but designed more for street performance. They'll typically give you slightly better MPG than a mud terrain, and don't create the noise associated with some mud tires. They're best suited for snow, and mild off-road conditions such as dirt roads and mild trails.
Mud Terrain - If you ever plan to take your truck off-road, this is the tire you want. In fact, it doesn't even need to be a true off-road vehicle. Some people use them for traction on the trucks they tow their off-road vehicles with (because you usually end up having to park it in a field somewhere), or on farm vehicles that need to drive in to fields. The aggressive tread and deep voids allow them to get a good bite without clogging up with mud.
(The colored area shows the void in this mud terrain)
In addition, there are some competition and rock crawling specific tires, but we're not going to get in to that. If you're in to competition rock crawling, then you're likely not reading this.
Construction Designs:
Besides choosing the type of tread design, there is also Radial and Bias ply tires.
Bias Construction Tire
Radial Construction Tire
Bias Ply - Although they're not as plentiful as they use to be, there are still several bias ply off-road tires out there. Bias tires typically have the ply cords that extend diagonally from bead to bead at a range of 30 to 40 degree angles. Each successive ply is laid at an opposing angle, forming a criss-cross pattern. This design allows the entire tire body to flex, as the tread and sidewalls share the same casing plies. The flex allows for better gripping, better clean out, and conformity to rough and rocky terrain. Bias type tires are best suited for extreme off-road conditions where grip, cleanout, and traction are top priority. These tires are just as strong in the sidewalls as in the center of the tread. While they may not flex as readily as a radial, the flex in the tread makes up for it.
Bias tires tend to wear out quicker and form flat spots compared to their counterparts. The flexing also means increased rolling resistance, a noisy tire, and less control and traction at higher speeds. A set of bias ply off-road tires will usually only last 20,000 - 30,000 miles when used on the highway.
Radial - Radial constructed tires utilize ply cords that extend from bead to bead at approximately right angles to the centerline of the tire. They are parallel to each other, and are combined with stabilizer belts. They have good directional stability offering a smooth ride, and tend to last for more miles than a bias tire.
Their drawbacks are weaker sidewalls, and the steel belts hamper the radials ability to conform to trail obstacles.
Evolving Technology:
While bias tires have been considered to have a stronger sidewall than a radial tire, manufactures have been working to improve the sidewall strength of their off-road tires.
Goodyear Wrangler MT/R with Kevlar
Goodyear offers their Wrangler MT/R with a Kevlar reinforced sidewall, and they claim it helps increase sidewall puncture resistance by 35%. Some manufacturers also list their off-road tires with a 3-ply sidewall, and claim that it makes them more puncture resistant.
What's Available:
Below is a chart showing the different 33-inch mud terrains available. The chart includes:
  • Tire dimensions / specifications
  • Side by side comparisons
  • Price ranges
  • Links for checking prices
  • Reviews & ratings
  • Links to the manufactures page for the tire listed
You'll notice that most of these tires are not a true 33-inch tire. You'll also see that some have a deeper tread measurement than others. Recommendations follow the chart.
33"
Mud Terrains
BFGoodrich Mud Terrain KM2
33x12.50x15
Goodyear Wrangler Duratrac
33x12.50x15
Goodyear Wrangler MTR
33x12.50x15
Firestone Destination MT
33x12.50x15
Dunlop Mud Rover
33x12.50x15
Mastercraft Courser MXT
33x12.50x15
 Construction Radial Radial Radial Radial Radial Radial
 Overall Diameter (in)
32.8
32.8
32.8 33 32.5 32.83
 Overall Width (in)
12.5
12.5
12.5 12.5 12.5 12.1
 Tread Width
N/A
N/A
N/A 9.9 9.6 9.8
 Approved Rim Width (in) 8.5 - 11.0
8.5 - 11.0
8.5 - 11.0 8.5 - 11 8.5 - 11.0 8.5 - 11.0
 Tread Depth (_/32nds)
20
18
21 22 20 20
 Tire Weight (lbs)
59.5
N/A
N/A 60 53 N/A
 Warranty
Life of tread or 6-Years
50,000 Miles
60,000 Miles 5-Years / Free replacement first 3 years, then prorated until 2/32" 6 Years / Free replacement first year or 2/32" of wear, then prorated until 2/32" Undefined
 Price Range (03/2014) $210-$240 $162 - $195 $205 - $220 $213 - $255 $172 - $180 $170 - $175
 Price - Online Dealer
TireRack.com TireRack.com TireRack.com TireRack.com TireRack.com Onlinetires.com
 Rating - Online Dealer N/A
 Price - Amazon Check Price Check Price Check Price Check Price N/A N/A
 Reviews - Amazon Read Reviews Read Reviews N/A N/A N/A N/A
 Rating - Amazon
N/A N/A N/A N/A
 Price - 4Wheelparts
Check Price
Check Price
Check Price N/A N/A N/A
 Reviews - 4Wheelparts
Read Reviews
Read Reviews
 Rating 4Wheelparts
N/A N/A N/A
 Manufacturer Link
BFGoodrich
Goodyear
Goodyear Firestone Dunlop Mastercraft
33"
Mud Terrains
Pro Comp Xtreme MT2
33x12.50x15
Dick Cepek Mud Country
33x12.50x15
Vanderbilt Mudclaw M/T
33x12.50x15
Hancook Dynapro MT
33x12.50x15
Nitto Mud Grappler
33x13.50x15
Nitto Trail Grappler M/T
33x12.50x15
 Overall Diameter (in) 32.6 32.8 32.51 32.8 33.07 33.03
 Overall Width (in) 12.5 12.1 12.5 12.2 13.94 12.99
 Tread Width N/A N/A N/A 9.8 N/A N/A
 Approved Rim Width (in) N/A 8.5 - 11.0 10 8.5 - 11.0 8.5 - 11.0 8.5 - 11.0
 Tread Depth (_/32nds) 20 20.5 19 18.5 21 21
 Tire Weight (lbs) N/A 56 52 N/A N/A N/A
 Warranty 40,000 Mile Tread Wear Warranty Prorated Replacement Undefined 50,000 / Prorated 60 Months / 1st 25% Worn 60 Months / 1st 25% Worn
 Price Range (03/2014) $250 $215 - $232 $180 - $213 $209 - $226 $272 - $282 $247 - $261
 Price - Online Dealer Discounttire.com TireRack.com NTB.com Onlinetires.com NTB.com NTB.com
 Rating - Online Dealer N/A N/A N/A N/A N/A N/A
 Price - Amazon Check Price Check Price Check Price Check Price Check Price Check Price
 Reviews - Amazon N/A N/A N/A N/A N/A N/A
 Rating - Amazon
N/A
N/A
N/A N/A N/A N/A
 Price - 4Wheelparts
Check Price
Check Price N/A N/A Check Price Check Price
Read Reviews
Read Reviews N/A N/A N/A Read Reviews
 Rating - 4Wheelparts
N/A N/A N/A
 Manufacturer Link
Pro Comp
Dick Cepek
Vanderbilt Hancook Nitto Nitto
33"
Mud Terrains
Hercules Trail Digger Mud Terrain
33x12.50x15
Toyo Open Country Mud Terrain
33x12.50x15
Kumho Road Venture Mud Terrain
33x12.50x15
Yokohama Geoloander M/T
33x12.50x15
Mickey Thompson Baja MTZ
33x12.50x15
Mickey Thompson Baja Claw TTC
33x12.50x15
 Overall Diameter (in) 32.5 33 32.3 32.6 32.8 32.7
 Overall Width (in) 12.8 12.8 12.5 12.6 12.1 12.1
 Tread Width N/A N/A N/A 10.4 9.7 9.7
 Approved Rim Width (in) 10.0 8.0 - 11.0 8.5 - 11.0 8.5 - 11.0 8.5 - 11.0 8.5 - 11.0
 Tread Depth (_/32nds) 20.5 21 19 19 20.5 20.5
 Tire Weight (lbs) 52 69 53.7 51.8 56 60
 Warranty 2-Years / Prorated 1-Year / First 25% 5-Year / Prorate 5-Year Prorated Prorated
 Price Range (03/2014) $194 $269 - $304 $182 - $228 $208 $205 - $230 $210 - $235
 Price - Online Dealer N/A Simpletire.com TireRack.com TireRack.com SummitRacing.com SummitRacing.com
 Price - Amazon Check Price Check Price Check Price N/A Check Price Check Price
 Reviews - Amazon Read Reviews N/A N/A N/A Read Reviews Read Reviews
 Rating - Amazon N/A N/A N/A
 Price - 4Wheelparts N/A Check Price N/A N/A Check Price N/A
 Reviews - 4Wheelparts N/A Read Reviews N/A N/A Read Reviews N/A
 Rating - 4Wheelparts N/A N/A N/A N/A
 Manufacturer Link Hercules Toyo Kumho Yokohama Mickey Thompson Mickey Thompson
33"
Mud Terrains
Maxxis Buckshot
33x12.50x15
Maxxis Big Horn
33x12.50x15
Pit Bull Growler
33x12.50x15
Pitbull Rocker
33x13.50x15
Super Swamper TrXus MT
33x12.50x15
Super Swamper LTB
33x13.50x15
 Construction Radial Radial Bias Bias Radial Bias
 Overall Diameter (in) 32.2 32.9 32.8 33 33 32.8
 Overall Width (in) 12.7 12.7 12.9 13.7 12.7 13.0
 Tread Width N/A N/A 10.25 10.9 9.6 11.3
 Approved Rim Width (in) 10 10 10 11 8.5 - 10.0 10
 Tread Depth (_/32nds) 20 21 22 22 19 22
 Tire Weight (lbs) N/A N/A 56 57 67 60
 Warranty 6-Year 6-Year 5-Year 5-Year Unspecified Unspecified
 Price Range (03/2014) $155 $232 - $252 $279 $308 $276 - $294 $254 - $268
 Price - Online Dealer Onlinetires.com Price Onlinetires.com ok4wd.com Price ok4wd.com Price SummitRacing.com SummitRacing.com
 Price - Amazon N/A Check Price N/A N/A Check Price Check Price
 Rating - Amazon N/A N/A N/A N/A N/A N/A
 Price - 4Wheelparts N/A Check Price N/A N/A Check Price Check Price
 Reviews - 4Wheelparts N/A N/A N/A N/A Read Reviews Read Reviews
 Manufacturer Link Maxxis Maxxis Pit Bull Pit Bull Interco Interco
33"
Mud Terrains
Super Swamper SSR
33x12.50x15
Super Swamper TSL (Radial)
33x12.50x15
Super Swamper TSL (Bias)
33x12.50x15
Super Swamper TSL SX
33x15.50x15
Super Swamper Bogger
33x12.50x15
Dick Cepek Crusher
33x12.50x15
 Construction Radial Radial Bias Bias Bias Radial
 Overall Diameter (in) 33.4 32.7 33.7 33.1 33.2 32.8
 Overall Width (in) 12.5 12.7 12.4 15.2 12.8 12.1
 Tread Width 10.6 9.4 10.2 12.3 11.1 9.7
 Approved Rim Width (in) 8.5 - 10.0 10 10 10 - 12 10 8.5 - 11.0
 Tread Depth (_/32nds) 21 21 24 23 23 20.5
 Tire Weight (lbs) 66 60 62 67 64 56
 Warranty Unspecified Unspecified Unspecified Unspecified Unspecified Prorated Replacement
 Price Range (03/2014) $355 - $372 $274 - $309 $253 - $269 $336 - $360 $332 - $335 $220 - $236
 Price - Online Dealer SummitRacing.com SummitRacing.com SummitRacing.com SummitRacing.com SummitRacing.com TireRack.com
 Price - Amazon N/A Check Price Check Price Check Price Check Price Check Price
 Reviews - Amazon N/A N/A N/A N/A N/A Read Reviews
 Price - 4Wheelparts Check Price Check Price Check Price Check Price Check Price Check Price
 Reviews - 4Wheelparts N/A Read Reviews Read Reviews N/A Read Reviews Read Reviews
 Manufacturer Link Interco Interco Interco
Interco
Interco Dick Cepek
Shopping Online & Warranties:
Some people feel that they need to go to their local tire shop to buy tires. Sometimes that can limit your options. Some tire shops won't have the size you want when you walk in, and will have to order it.
Companies such as Tire Rack have agreements with local tire shops to install tires. When you buy the tires online, they send them to your local tire shop for installation. Other companies will charge a flat rate for shipping, or may offer free shipping.
Amazon and Discount Tire usually have tires that ship for free.
Some people have concerns about their warranty when they order tires online. If your tire has a manufactures warranty, any dealer that carries that brand will be able to honor it. Any tire shop will mount tires that you bring in. Having a shop mount your tires doesn't usually cost that much.
In this day in age, you have to be an educated consumer and get the best deal. Even if it means getting tires online with free shipping, or having them sent to a local tire shop.
Our Recommendations From The Chart:
Under $200:
There are very few 33-inch tires anymore under $200.
The Maxxis Buckshot Mudder - Is probably one of the oldest mud terrains on the market. It's a quality tire, and the cheapest name brand 33-inch mud terrain you can currently find. It has a 20/32 inch deep tread.
The Mastercraft Courser MXT - Is another great value under $200, and measures 32.83 inches with a 20/32 inch deep tread. Much closer to the true 33-inch diameter.
The Dunlop Mud Rover would also be in the top (3) picks for mud terrains under $200. It's 32.5 inches in diameter with a 20/32 inch tread depth.
Above $200:
The Goodyear Wrangler MTR is 32.8 inches with 21/32 inches of mud tread. It also has sidewalls reinforced with Kevlar.
The Firestone Destination with it's diameter listed at 33 inches and a deep 22/32 inch tread depth.
The BFGoodrich Mud Terrain KM2, a proven winner in various off-road motorsports.
What's The Ultimate Mud Terrain:
Really, anything made by Interco (Super Swamper). The Super Swamper bogger is hands down the best mud tire. It's not that great on rocks, and not a tire you want to drive on the street. Super Swamper TSL's would be the best tires for a dedicated trail rig, and a setup consisting of Super Swamper TSL's on the front, with Super Swamper Boggers on the back, is an amazing mud setup.
The Super Swamper TSL and SSR radials would be a great tire for a trail rig that sees a lot of pavement driving.
Links:
Tire Rack - 33x12.50x15 Mud Terrains
Discount Tire - 33x12.50x15 Mud Terrains
Goodyear/Dunlop Get Rebates Up to $80
Discount Tire Direct
footer
Advertisers
The Ranger Station
   About
   Staff
   Contact Us
   Advertising
   Legal Notices
   959 Media LLC
   Copyright 1999-2018
Submit Content
Have Info To Share?
We're always looking for good content to share with other Ford Ranger enthusiasts. Click on the 'Submit' button to find out how you can get your submission posted and acknowledged for it.
