Ranger Tech ('19-'20)
Ranger Tech ('83-'11) Product / Build Guide Other Articles TRS Events Overlanding
Readers Rangers
  Ford Ranger Forum
TRS Store
Broken Cross Pin Retaining Bolt
Trucks Of The Month
Ranger Buyers Guide
If you go to pull the rear shafts, or try to do a gear ratio change on your Ford 7.5 or 8.8 inch axle, you may find that the bolt retaining your cross pin is broke, or may break it trying to remove it.
If the bolt broke below the threads, than you can probably get it out with a magnet and pick. If the broken piece still had threads on it, you'll likely need a tool to extract it.
This is actually a common problem on the Ford c-clip axles. GM shares this problem as well. The problem is common enough that companies make a kit for extracting the broken piece in the carrier.
Extractor Kits:
These kits generally contain:
  • 12" Long 1/8" Drill Bit
  • (1) Spiral Screw Extractor
  • (1) Straight Flute Screw Extractor
  • (2) Drill Guide Bolts
  • Instruction Sheet
You may be able to use a left hand drill bit or EZ Out (bolt extractor) to drill and remove the broken piece. The problem is drilling straight in to the middle of the broken piece. This is where the kits alignment bolts are handy.
(Cross pin bolt)
These kits can be found at:
James Oaks Enterprises
Matco Tools (P/N DPK1)
etoolcart.com
Skyway Tools
Replacement Bolt:
footer
Advertisers
The Ranger Station
   About
   Staff
   Contact Us
   Advertising
   Legal Notices
   959 Media LLC
   Copyright © 1999-2020
Submit Content
Have Info To Share?
We're always looking for good content to share with other Ford Ranger enthusiasts. Click on the 'Submit' button to find out how you can get your submission posted and acknowledged for it.
