Trucks Of The Month
Submitted
By: JLSteadman_b2
These are all the wires and their correct
corresponding colors for the gauges and indicator lights in 1993-1994 Rangers.
The labels are just the ones that I came up with. You can label each wire
on the connector what you want. This was necessary to trace the circuits
on the instrument cluster.
Gauge |
Instrument
Cluster Label |
Wire
Color |
Purpose |
Voltmeter |
Ground |
Ignition Wire
(Signal) |
Oil Pressure |
B/W |
R/Y |
W/R |
Ground |
Ignition Wire |
Signal |
Water Temp. |
B/W |
R/W |
R/Y |
Ground |
Signal |
Ignition Wire |
Fuel Level |
B/W |
R/Y |
Y/W,
R/Y, B/W |
Ground |
Ignition
Wire |
Signal (Through
circuit board on side of cluster) |
Tachometer |
T/Y
R/Y |
DB/Y |
B/Y |
Signal |
Ignition Wire |
Ground |
8 Cyl. (Not
Used) |
Wire Color
Codes |
B |
Black |
BR |
Brown |
DB |
Dark Blue |
DG |
Dark Green |
GY |
Gray |
LB |
Light Blue |
LG |
Light Green |
N |
Natural |
O |
Orange |
P |
Purple |
PK |
Pink |
R |
Red |
T |
Tan |
W |
White |
Y |
Yellow |
Cluster Label |
Wire Color |
Purpose |
Left Turn Signal |
Check Engine |
Common (Ignition Wire)
Signal |
Check Oil |
Charge Indicator |
4-Wheel High |
4-Wheel Low |
ABS |
Right Turn Signal |
High Beams |
Seat Belt |
Anti-Theft |
Not Used |
Parking Brake |
Wire Connectors
