Home
Product / Build Guide Tech Articles Other Articles Featured Rangers Readers Rangers Classifieds
Ford Ranger Forum
Shirts & Decals
Ford Ranger Intermediate Steering Shaft Rag Joints
Trucks Of The Month
Translate
Shirts & Decals
CLICK to check out our TRS shirts & decals and support the site
Ranger Buyers Guide
Check Out These Girls!!
Check Out:
Pontiac Hunters
Sponsors Ad
 Sponsors Ad
By: kage
The rag joint is the only component in the steering shaft that you can replace. If the universal joints are bad, you'll have to replace the shaft.
Below is some photos to help you identify the rag joints.
(Photo of intermediate steering shaft from a 1990 Ford Ranger)
(This is the steering box and intermediate shaft from a 1989 Ford Ranger 4x4)
 Replacing The Rag Joint:
The dead joint is on the RH side here, you canít tell in the photo, but it was cracked all the way through on both sides. Surprisingly, the steering didnít really seem to be any sloppier because of it:
Step one is to cut off the rivet heads, and pound the rivets out of the remaining pieces:
Then you pick up Dorman Part Number 31002 (you need one of these per joint), this part is often found in the Help! section of the parts store:
For each joint, youíll need:
  • (4) 5/16x1.5" Grade 8 bolts
  • (4) Nylock nuts to go with the bolts
  • (4) rubber grommets
I saw a few write-ups mention that they used 1/4" bolts, but the holes in my shaft were drilled to 5/16", so the 1/4" stuff was too sloppy:
Assemble everything back together and youíre done. For a little extra security, you can put some locktite on the bolts.:
Steering Couplers:
Another option is a steering coupler (or Steering Coupler Assembly) that looks similar to this:
If your local part store doesn't have one, you can get one from rockauto.com.
footer
Advertisers
The Ranger Station
   About
   Staff
   Contact Us
   Advertising
   Legal Notices
   959 Media LLC
   Copyright © 1999-2018
Submit Content
Have Info To Share?
We're always looking for good content to share with other Ford Ranger enthusiasts. Click on the 'Submit' button to find out how you can get your submission posted and acknowledged for it.
