Home
Product / Build Guide Tech Articles Other Articles Featured Rangers Readers Rangers Classifieds
Ford Ranger Forum
Shirts & Decals
Actual Speed Change From Ring Gear And Pinion Change Calculator
Trucks Of The Month
Translate
Shirts & Decals
CLICK to check out our TRS shirts & decals and support the site
Ranger Buyers Guide
Check Out These Girls!!
Check Out:
Pontiac Hunters
Sponsors Ad
 Sponsors Ad
This calculator requires the use of Javascript enabled and capable browsers. This calculator is designed to determine the difference between the indicated speedometer speed and the actual speed after a change of gear ratio on the ring gear and pinion. This assumes no other changes such as tire or wheel size, engine changes or transmission changes. Enter the ratio of the original ring gear and pinion (changed from) and the new ring gear and pinion (changed to). Enter the indicated speed as read on the speedometer. Click on the Calculate button. At any given speedometer indicated speed, the true speed is the ratio difference multiplied by the speedometer indicated speed. Depending on the vehicle manufacturer and the transmission type and manufacturer, there are speedometer gears available to correct the indicated speed. Check with your manufacturer's parts supplier.
Designation
Value
Required Data Entry
Initial Ring Gear and Pinion Ratio Ratio
Changed Ring Gear and Pinion Ratio Ratio
Indicated Speed MPH
Calculated Results
Actual speed MPH
footer
Advertisers
The Ranger Station
   About
   Staff
   Contact Us
   Advertising
   Legal Notices
   959 Media LLC
   Copyright 1999-2018
Submit Content
Have Info To Share?
We're always looking for good content to share with other Ford Ranger enthusiasts. Click on the 'Submit' button to find out how you can get your submission posted and acknowledged for it.
