Home
Product / Build Guide Tech Articles Other Articles Featured Rangers Readers Rangers Classifieds
Ford Ranger Forum
Shirts & Decals
Speedometer Calibration Calculator And Information
Trucks Of The Month
Translate
Shirts & Decals
CLICK to check out our TRS shirts & decals and support the site
Ranger Buyers Guide
Check Out These Girls!!
Check Out:
Pontiac Hunters
Sponsors Ad
 Sponsors Ad
This calculator requires the use of Javascript enabled and capable browsers. This calculator is designed to give information related to tire size changes and the general impact they have on the calibration of a speedometer. It determines speedometer error and tire size information based on published and generally accepted tire dimensions as given by the standard US tire system (i.e. 205/45-ZR16). All calculations are based on the assumption of a new tire (as opposed to used) where the numbers on the tire accurately represent the dimensions. The calculator makes no effort to consider the result of any curvature effects of a tire when mounted on a rim it was not designed for. As an example, a 205 width tire mounted on a 15 inch diameter, 5 inch wide wheel will bulge significantly since the tire is designed to be flush with a 7 to 7.5 inch wide wheel. Under that stress, the tire will balloon outward from the sides, which is not taken into consideration within the limitations of this calculator. This tool gives the user a general but reasonable representation of alternative wheel effects. Enter the standard and new tire designation, aspect and wheel size. Click on Calculate for the results. You may click on Clear Values to do another calculation. Consult your tire specialist if you have further questions about such issues.
U.S. Tire Information
U.S. Tire Required Data Entry
Enter Stock Tire Size
/ - R
Enter New Tire Size
/ - R
Enter A Reference Speedometer Value MPH or KMH
Calculated Results After Tire Changes
Stock tire width is inches. New tire width is inches.
Stock tire thickness is inches. New tire thickness is inches.
Stock tire diameter is inches. New tire diameter is inches.
When the vehicle speedometer indicates MPH or KMH
The vehicle speed is actually MPH or KMH.
footer
Advertisers
The Ranger Station
   About
   Staff
   Contact Us
   Advertising
   Legal Notices
   959 Media LLC
   Copyright 1999-2018
Submit Content
Have Info To Share?
We're always looking for good content to share with other Ford Ranger enthusiasts. Click on the 'Submit' button to find out how you can get your submission posted and acknowledged for it.
