York On-Board Air Compressor
Introduction
Many off-road enthusiasts get to a point where they find a need for onboard air. Whether it’s for airing up tires, lockers, or using air tools. There are a variety of options including electric air compressors, belt driven air compressors, and CO2 tanks. This page discusses the use of the York air conditioning compressor as an onboard air compressor.
Why Should You Use A York A/C (Air Conditioning) Compressor
York A/C Compressor
(York A/C Compressor)
Most A/C compressors used on vehicles are lubricated by the freon running through the system. Since it’s a sealed system, it stays lubricated. If you use one of those compressors to pump air, it won’t get any lubrication and will seize up. You could add an external oiler, but you’d have to deal with separating the oil out of the air and routing it back to the compressor.
Unlike these compressors, the York has an internal reservoir for oil. So if you remove the freon and use it to pump air, it will still lubricate itself.
There are a few different York compressors to choose from, and some pump more air than others.
Which York To Choose
There are (3) variations of the York compressor:
  • Long stroke 210 Series =10.3 ci (169 cc)
  • Medium Stroke 209 Series – 8.69 ci (142 cc)
  • Short stroke 206 Series = 6.10 ci (100 cc)
SPECIFICATIONS 206 209 210
No. Cylinders 2 2 2
Bore, in. (mm) 1.875 (47.63) 1.875 (47.63) 1.875 (47.63)
Stroke, in. (mm) 1.105 (28.07) 1.573 (39.95) 1.866 (47.40)
Disp., cu. in./rev. (cc/rev) 6.10 (100) 8.69 (142) 10.3 (169)
R.P.M. – Max. 6000 6000 6000
Refrigerant R-12, 22, 502, 134a & new blends R-12, 22, 502, 134a & new blends R-12, 22, 502, 134a & new blends
Initial Oil Charge, fl. oz. (ml)* 14 (413) 14 (413) 14 (413)
Weight, lbs. (kg) 14.6 (6.6) 14.6 (6.6) 14.6 (6.6)
Lubrication Splash and Positive Pressure Oil Return Through Suction Side
* R-12 Heavy Duty models contain 12 fl. oz. (355 ml).
* R-134a Heavy Duty models contain 14 fl. oz. (413 ml).
Some OEM specifications are as high as 17 fl. oz. (503 ml).
The most desirable York compressor is the 210. It’s longer stroke gives it more volume, resulting in more CFM (Cubic Feet per Minute). The 210 is rated at 4 CFM @ 90 PSI, and is capable of 8+ CFM. The larger CFM allows it to run air tools.
You can identify a York compressor by the ID plate.
York compressor label identification
This tag identifies this compressor as a York 210 with a left-hand suction
(This tag identifies this compressor as a York 210 with a left-hand suction)
If your York came out of an AMC or Ford, than you likely have a non-standard ID plate.
York compressor Motorcraft label
(York compressor with a Motorcraft tag)
Ford tag on York compressor
(Ford tag on York compressor)
York tag from a York compressor on a 1979 Jeep CJ7
(York tag from a York compressor on a 1979 Jeep CJ7)
In that case, you may have to remove the pulley and look at the end of the shaft. You’ll need a 1/2″ socket, a 5/8″ course thread bolt, and a 15/16″ socket to pull the pulley.
Shaft detail indicating compressor displacement
Using the diagram above, you can see that each compressor has a different detail to its shaft that helps identify it.
Here is a list of vehicles that came with the York 210 compressor:
Note: There are two types of York upper fittings: ‘Flange’ mount and ‘Tube O-Ring’ (a tube inside a rubber O-ring).
Vehicles That Came With A York 210 Compressor
Audi
Model Year Head Type Suction
100LS 1976-1977 Tube o-Ring Right
Bronco 1978-1981 Tube O-Ring Left
Bronco 1978-1983 Flange Right
Country Squire 1975-1984 Flange Right
Crown Victoria, LTD Full Size 1975-1984 Flange Right
E Series Van 1976-1982 Tube O-Ring Left
E Series Van 1976-1985 Flange Right
F Series Pickup F-150-F350 1976-1981 Tube O-Ring Left
F Series Pickup F-150-F350 1980-1985 Flange Right
Fairmont 1979-1982 Tube O-Ring Left
Fairmont 1979-1983 Flange Right
Granada 1980-1982 Tube O-Ring Left
Granada 1976-1982 Flange Right
LTD II 1983-1984 Flange Right
Maverick 1976-1977 Tube O-Ring Left
Maverick 1976-1977 Flange Right
Mustang 1976-1981 Tube O-Ring Left
Mustang 1979-1984 Flange Right
Pinto 1976-1980 Tube O-Ring Left
Pinto 1976-1980 Flange Right
Ranger 1983-1984 Flange Right
Thunderbird 1977-1982 Tube O-Ring Left
Thunderbird 1980-1988 Flange Right
Torino 1976 Tube O-Ring Left
Torino 1976 Flange Right
Jeep
Cherokee 1976-1983 Tube O-Ring Right
Cherokee 1976-1983 Flange Right
Comanche 1986-1988 Tube O-Ring Right
Grand Wagoneer 1984-1991 Tube O-Ring Right
Wagoneer 1976-1983 Tube O-Ring Right
Mercury
Bobcat 1976-1980 Tube O-Ring Left
Bobcat 1976-1980 Flange Right
Capri 1979-1982 Tube O-Ring Left
Capri 1979-1984 Flange Right
Colony Park 1980-1984 Flange Right
Comet 1976-1977 Tube O-Ring Left
Comet 1976-1977 Flange Right
Cougar 1976-1982 Tube O-Ring Left
Cougar 1976-1982 Flange Right
Grand Marquis 1983-1984 Flange Right
Marquis – Full Size 1980-1982 Flange Right
Marquis – Mid Size 1983-1984 Flange Right
Monarch 1980 Tube O-Ring Left
Monarch 1976-1980 Flange Right
Montego 1976 Tube O-Ring Left
Montego 1976 Flange Right
Zephyr 1978-1982 Tube O-Ring Left
Zephyr 1978-1983 Flange Right
Porsche
911 1978-1983 Flat Top Right
914 1973-1976 Flat Top Right
930 1977-1979 Flat Top Right
Volvo
240 Series 1975-1984 Flange Right
Volvo and AMC hose connections run horizontally across the top of the York, while Ford hose connections stick straight out.
Identifying The Suction Side And Discharge Side
To determine which port is the suction, and which is the discharge, look at the head around where the hoses attach. The area around the ports will have a ‘S’ or ‘D’ for ‘suction’ or ‘discharge’. The may also be labeled as ‘SUCT’ or ‘DISCH’
Testing The Compressor
The York compressor will have a single wire coming off of it. Ground the compressor and apply 12 volts to the wire. You should hear a click from the clutch engaging. With it engaged, you should hear air coming out of the port when you turn the pulley. When you disconnect the power, the pulley should turn freely (with less resistance) and should not be pumping air.
Checking The Oil
The standard York has an oil fill/check hole in the center of each side of the compressor body. They’re plugged with a bolt with a 1/2″ hex head, and sealed with a rubber O-ring.
Make the initial oil level check after the compressor is mounted on the mounting bracket.
Remove one oil fill plug with its O-ring. Either plug on a vertical mount installation, and the upper plug on horizontal mount installations. You can make a dipstick to check your oil level.
York compressor checking the oil level
The oil dip stick, Fig. 1, can be made locally, and is suitable for use on all compressors in any mounting position. It can be formed from 1/8″ diameter x 8-5/16″ (3 mm diameter x 210 mm) long stock, preferably non ferrous material which is not subject to corrosion. Notched ends are helpful in visibly detecting the oil depths.
Compressor Oil Type
When adding or changing oil, use only proper oil. Keep the oil storage container tightly capped at all times. Here is the recommended oil when the compressor is being used as an actual air conditioning compressor:
Refrigerant  Acceptable Lubricants
R-12, R-22, R-502 Mineral Oil, Zerol 150, Zerice S-68, P.O.E.
R-134a Polyol Ester (P.O.E.) P.A.G.
You don’t have to use those accepted lubricants when you’re using it as a regular air compressor. People converting these compressors for onboard air usually drain all the oil out and refill them with 10W-30 motor oil. Some have even used ATF.
The Table below shows the crankcase oil level in fluid ounces (and ml) at various dip stick measurements for both horizontal and vertical mounts. The oil level after the system is stabilized should be maintained with 6 fluid ounces (177 ml) minimum and 8 to 12 fluid ounces (237 to 355 ml) for best results.
Oil Level vs. Dip Stick Depth
Oil Level vs. Dip Stick Depth - Heavy Duty & Standard Models Oil Level vs. Dip Stick Depth - Super Compact Mini Models
oil level at 45 degrees diagram
The compressor oil level should never be permitted to go below the minimum oil level of 6 fluid ounces (177 ml). If oil must be added, the oil should be added until the level is 12 fluid ounces (355 ml). An excessive amount of oil is detrimental to the proper functioning of the entire system.
Mounting The York
The York compressor can be mounted flat, angled or upright. The suction port should always be on top when mounted at an angle. Also, the compressor will work whether it’s spun clockwise, or counter clockwise.
Mounting the York - 180 left to right and clockwise or counterclockwise rotation examples
Compressor Fittings
Volvo and AMC hose connections run horizontally across the top of the York, while Ford hose connections stick straight out of the top.
Compressor fittings
The problem people run in to is connecting to the hose fittings on the compressor.
Converting The Fitting
The York compressors use a 5/8″ flare on the suction side and a 1/2″ flare on the pressure side.
Pressure Side
On the pressure side, people have converted the 1/2″ Flare to 3/8″ male NPT by using:
1/2″ Flare to 1/2″ Flare Swivel Union
1/2″ Flare to 3/8″ NPT adapter
On the pressure side, people have converted the 1/2" Flare to 3/8" male NPT
Another example using an elbow:
Suction Side
They have converted the suction side to 1/2″ OD Copper so they could slide a filter on. This was done using:
5/8″ to 1/2″ flange swivel union
1/2″ to 1/2″ flare
1/2″ flare nut to piece of 1/2″ copper
5/8" to 1/2" flange swivel union, 1/2" to 1/2" flare, and 1/2" flare nut to piece of 1/2" copper
Suction side fitting example
York compressor fitting example
When you remove the factory A/C lines, the threaded fittings that remain are standard 45-degree flared gas line (JIC) fittings. The intake fitting is 1/2″ (-8) and the discharge fitting is 5/8″ (-10). In the photo above, the owner swapped the factory fittings side to side so that the larger fitting was on the intake. He used a 1/2″ flare to 3/8″ NPT fitting and a 3/8″ to 1/4″ NPT reducer to connect the factory discharge fitting to an air hose. The air filter is attached to the factory JIC fitting using a 5/8″ flare to 1/2″ NPT adapter purchased from a hydraulic supply shop (Grainger sells them).
The filter is a Solberg FS-06-050.
Others have removed the factory connectors and head, drilled and tapped the inside of the factory fittings to accept a 3/8″ NPT fitting, and used 3/8″ NPT 90 degree elbows.
Factory fittings drilled to accept a 3/8" NPT fitting, and used 3/8" NPT 90 degree elbows
Making It All Work
On-board air system components diagram
Item # Item Description Item Use
1 Compressor Clutch Engages & disengages the compressor
2 Compressor Compresses air to fill the tank
3 Compressor Fittings Connects the lines to the compressor
4 Intake Filter Makes sure your compressor only runs on clean air
5 Coalescing Filter Removes oil from the air coming out of the compressor
6 Check Valve One way valve. Not needed if you’re not running an air tank
7 Air Manifold A union to place the safety valve, gauge, and pressure switch
8 Pressure Gauge Allows you to see how much pressure is being generated
9 Safety Valve A pressure relief valve that will open to release pressure if the pressure switch fails
10 Pressure Switch Turns the compressor on/off depending on the air pressure in the system
11 Air Tank Stores compressed air
12 Air Couplers Allows you to connect air tools and tire chucks
13 Oil Return Kit Routes oil from the filter back to the compressor
14 ON/OFF Switch Sends power to the pressure switch to turn the compressor ON/OFF
This isn’t a very complicated setup.
12-Volt Switch
You need the in-cab switch to override the system so you can shut it off if needed.
It’s best to use a relay to run the power for your pressure switch off the battery. When the switch in the cab is activated, the power turns on the relay, which sends the power to the pressure switch.
12-volt switch and relay diagram
Pressure Switch
The compressor pulley constantly turns with the engine. When you activate the switch in your cab, the power goes to a pressure switch. If the pressure is low, it send power to activate the clutch in the compressor. It fills the air in to your tank until the pressure switch shuts off. Companies such as VIAIR make pressure switches with different ON/OFF PSI settings. Some even include a relay.
Pressure switch
(Pressure switch)
Safety Relief Valve
A safety relief valve is used (usually on the tank) to release pressure if the switch fails to shut off the compressor. This keeps the tank or hoses from blowing apart. Make sure your pressure switch is set to shut off 15-25 PSI less than your safety valve. This will keep it from accidentally blowing the valve and emptying your system.
Safety relief valve
(Safety relief valve)
Air Regulator
It’s not shown in the above diagram, but you should include an air regulator with a gauge somewhere after the pressure switch, and before the air chuck. This will allow you to control the air output if you want to run air tools.
Air regulator with a gauge
(Air regulator with a gauge)
Filter
You’ll want a filter to remove water and oil from your air. You can even find them with a built in air regulator.
Coalescing filter
(Coalescing filter)
Air Tanks
VIAIR makes air tanks ranging in size from 0.5 gallons to 5 gallons.
Small air tank Large air tank
(You’ll need an air tank)
Add a quick disconnect at the tank with a hose long enough to reach every point of the truck.
More Diagrams
Complete on-board air system diagram
Labelled online air system diagram
There you go! We hope you find this page helpful. Please post photos and details of your project in our Discussion Forum.
Resources
York Service Manual
Related Articles
Smittybilt 2780 & 2781 Instructions
On Board Air – Options & Reviews
On Board Air From Ford A/C Compressor
Onboard Air From Sanden A/C Air Compressor
Smittybilt 2781 Compressor Mods
York Compressor Service Manual
1993 Ford Ranger On-Board Air Using A/C Comp
Inflate / Air Down Four Tires At Once
About The Author
