Vehicle Make / Model: Model Year(s):
  • FORD / EXPLORER 1997-1999
  • FORD / F-250 1999
  • FORD / F-350 1999
  • FORD / F-450 SD 1999
  • FORD / F-550 SD 1999
  • FORD / F53 1999
  • FORD / MUSTANG 1998-1999
  • FORD / RANGER 1998-1999
  • MERCURY / MOUNTAINEER 1998-1999
Manufacturer: FORD MOTOR COMPANY
Report Receipt Date: MAR 30, 1999
NHTSA CAMPAIGN ID Number: 99V062001 NHTSA Action Number: N/A
Component: VEHICLE SPEED CONTROL
Potential Number of Units Affected: 898,739
Summary:
VEHICLE DESCRIPTION: CERTAIN 1997-1999 RHD EXPLORER EQUIPPED WITH 4.0L OHV/SOHC ENGINES AND CRUISE CONTROL BUILT FROM MAY 29, 1996 THROUGH MARCH 4, 1999; 1998-1999 EXPLORER/MOUNTAINEERS EQUIPPED WITH 4.0L OHV/SOHC OR 5.0L ENGINES OR 1998-1999 RANGERS EQUIPPED WITH 2.5L, 3.0L FFV/EFI OR 4.0L ENGINES AND CRUISE CONTROL BUILT FROM JANUARY 5, 1998 THROUGH MARCH 4, 1999; 1998-1999 MUSTANGS EQUIPPED WITH 3.8L, 4.6L 2-VALVE OR 4-VALVE ENGINES AND CRUISE CONTROL BUILT FROM MARCH 2, 1998 THROUGH MARCH 4, 1999; 1999 F250/F350/F450/F550 (OVER 8,500 LBS.) TRUCKS EQUIPPED WITH 5.4L OR 6.8L ENGINES AND CRUISE CONTROL BUILT FROM MARCH 2, 1998 THROUGH MARCH 4, 1999; AND 1999 F-53 STRIPPED CHASSIS EQUIPPED WITH 5.4L OR 6.8L ENGINES AND CRUISE CONTROL BUILT FROM MARCH 2, 1998 THROUGH MARCH 4, 1999. A CRUISE CONTROL CABLE CAN INTERFERE WITH THE SPEED CONTROL SERVO PULLEY AND NOT ALLOW THE THROTTLE TO RETURN TO IDLE WHEN DISENGAGING THE CRUISE CONTROL.
Consequence:
IF THE CRUISE CONTROL IS USED AND THIS CONDITION IS PRESENT, A STUCK THROTTLE COULD RESULT, WHICH COULD POTENTIALLY RESULT IN A CRASH.
Remedy:
DEALERS WILL REPLACE THE CRUISE CONTROL CABLES. AT THE PRESENT TIME, THE REPLACEMENT CABLES ARE NOT AVAILABLE. CUSTOMERS ARE BEING ADVISED NOT TO USE THE CRUISE CONTROL SYSTEM UNTIL A REPLACEMENT CAN BE MADE.
Notes:
A PRE-RELEASE WARNING LETTER THAT IDENTIFIED AN INTERIM FIX UNTIL THE PARTS FOR THE PERMANENT FIX BECAME AVAILABLE WAS MAILED TO OWNERS BEGINNING MARCH 27, 1999. A SECOND OWNER NOTIFICATION, IDENTIFYING THE PERMANENT FIX WAS MAILED TO OWNERS BEGINNING MAY 24, 1999. OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT FORD AT 1-800-392-3673. ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION’S AUTO SAFETY HOTLINE AT 1-888-DASH-2-DOT (1-888-327-4236).
