Note: For complete listings of Ford Ranger Technical Service Bulletins and Recalls you can also check out CarComplaints.com.
Engine:
SSM 51465 2019-2023 Ford Ranger – Light To Moderate Engine Ticking
TSB 23-2011- Water In Spark Plug wells
SSM 50736 2019-2021 Ford Ranger – Increased Engine Oil Level and/or Fuel Smell in Oil
SSM 52335 2019-2024 Ford Ranger – Oil Leak – Turbocharger
SSM 50597 2019-2021 Ford Ranger – Reduced Engine Power In Freezing Temperatures
SSM 50432 2011-2021 Ford Ranger – Repeat Spark Plug Replacements
SSM 49875 2021 Ranger – Lariat Trim Level – Engine Appearance Cover Deletion
TSB 21-2021 2019-2020 Ford Ranger Catalyst System Efficiency Below Threshold
TSB 19-2052 Engine Cold Start Runs Rough, Excessive Fast Idle And/Or Rough Shifting Transmission
TSB 20-2153 Trouble Code P02EE, P02EF, P02F0, P02F1, P050A, P050B, P1026, And/Or P051B
TSB 20-2339 Buck/Surge During Low Speed Operation And/Or Engine Runs Rough After Cold Start
Transmission:
TSB SSM 47812 – 2019 Ford Ranger – 10R80 – Whine Noise
TSB 24-2101 10R80 Automatic Transmission – Harsh/Delayed Engagement And/Or Harsh/Delayed Shift
Driveshaft:
TSB 23-2251 Ford Ranger – Non Tremor – Shudder/Vibration When Accelerating
SSM 50443 2019-2022 Ranger – Rear Driveshaft Yokes Appear Out Of Alignment/Phase
Brakes / ABS / Axle:
SSM 50296 2021 Ford Ranger / Bronco – Illuminated ABS Warning Indicator Lamp
Towing:
TSB 20-2374 Trailer Connected/Disconnected Warnings In The IPC
Interior:
TSB 23-2062 Ford Ranger Crew Cab – Folding Rear Seat Latch
SSM 50603 2019-2022 Ford Ranger – Condensation Dripping On Driver’s Side
SSM 51263 2019-2023 Ford Ranger – Dust Ingress Into The Cabin
Heat & Air Conditioning:
SSM 50293 2019-2021 Ford Ranger – Lack Of A/C Cooling Performance
SSM 50083 2019-2020 Ford Ranger Poor Or No Temperature Change When Adjusted
