Introduction:
Do you find yourself working on projects, grabbing Grade 5 or Grade 8 bolts from the hardware store, but not knowing what to torque them to?
This should help.
Suggested Starting Values:
The below estimated torque calculations are only offered as a guide. Use of its content by anyone is the sole responsibility of that person and they assume all risk. Due to many variables that affect the torque-tension relationship like human error, surface texture, and lubrication the only way to determine the correct torque is through experimentation under actual joint and assembly conditions.
Grade 5 Bolts:
Bolt Size TPI (Threads Per Inch) Tightening Torque (ft lbs)
Galvanized Plain
14 20 11 8
516 18 22 17
38 16 39 31
716 14 62 49
12 13 94 75
916 12 136 109
58 11 188 150
34 10 333 266
78 9 537 429
1 8 805 644
118 7 992 794
114 7 1,400 1,120
138 6 1,836 1,469
112 6 2,438 1,950
134 5 2,857 2,286
2 412 4,297 3,438
214 412 6,284 5,027
212 4 8,594 6,875
234 4 11,651 9,321
3 4 15,391 12,313
* SAE J429 grade 5 bolts do not exceed 1-1/2″ diameter.
Grade 8 Bolts:
Plain Lubricated
14 20 12 6
516 18 25 12
38 16 44 22
716 14 70 35
12 13 107 53
916 12 154 77
58 11 212 106
34 10 376 188
78 9 606 303
1 8 909 454
118 7 1,287 644
114 7 1,875 938
138 6 2,382 1,191
112 6 3,161 1,581
134 5 4,988 2,494
2 412 7,500 3,750
214 412 10,969 5,484
212 4 15,000 7,500
234 4 17,794 8,897
3 4 23,507 11,753
314 4 30,286 15,143
312 4 38,266 19,133
334 4 47,545 23,773
4 4 58,100 29,085
* SAE J429 grade 8 bolts do not exceed 1-1/2″ diameter.
Notes:
Values calculated using industry accepted formula T = KDP where T = Torque, K = torque coefficient (dimensionless), D = nominal diameter (inches), P = bolt clamp load, lb.
K values: waxed (e.g. pressure wax as supplied on high strength nuts) = .10, hot dip galvanized = .25, and plain non-plated bolts (as received) = .20.
Torque has been converted into ft/lbs by dividing the result of the formula by 12
All calculations are for Coarse Thread Series (UNC).
Grade 2 calculations only cover fasteners 1⁄4“-3⁄4” in diameter up to 6″ long; for longer fasteners the torque is reduced significantly.
Clamp loads are based on 75% of the minimum proof loads for each grade and size.
Proof load, stress area, yield strength, and other data is based on IFI 7th Edition (2003) Technical Data N-68, SAE J429, ASTM A307, A325, A354, A449, and A490.
