Vehicle Make / Model: Model Year(s):
Manufacturer: FORD MOTOR COMPANY Report Receipt Date: JUL 13, 2011 NHTSA CAMPAIGN ID Number: 11V352000 NHTSA Action Number: N/A Component: EXTERIOR LIGHTING: TAIL LIGHTS Potential Number of Units Affected: 26,715 Summary: FORD IS RECALLING CERTAIN MODEL YEAR 2011 RANGER TRUCKS BUILT FROM JANUARY 25, 2011, THROUGH APRIL 25, 2011 AT THE TWIN CITIES ASSEMBLY PLANT, AND SERVICE PARTS DISTRIBUTED TO DEALERS FOR CERTAIN 2004 THROUGH 2011 MODEL YEAR RANGER TRUCKS, 2002 THROUGH 2005 MODEL YEAR EXCURSION VEHICLES, AND 2002 THROUGH 2007 MODEL YEAR F-250, F-350, F-450, AND F-550 TRUCKS FOR FAILING TO COMPLY WITH THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD NO. 108, "LAMPS, REFLECTIVE DEVICES, AND ASSOCIATED EQUIPMENT." THE MULTI-FUNCTION SWITCH WAS SHIPPED WITH A SUBCOMPONENT (SLIDER) THAT MAY EXPERIENCE DEFORMATION. A MULTI-FUNCTION SWITCH WITH A DEFORMED SLIDER MAY MALFUNCTION CAUSING THE TURN SIGNAL, TAIL LIGHTS, HAZARD WARNING SIGNAL FLASHERS AND/OR BRAKE LIGHTS NOT TO ACTIVATE. Consequence: NON-FUNCTIONING LIGHTS COULD INCREASE THE RISK OF A CRASH. Remedy: DEALERS WILL REPLACE THE SWITCHES FREE OF CHARGE. THE SAFETY RECALL BEGAN ON AUGUST 15, 2011. OWNERS MAY CONTACT FORD MOTOR COMPANY CUSTOMER RELATIONSHIP CENTER AT 1-866-436-7332. Notes: FORD'S SAFETY RECALL NO. 11C18. OWNERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153)
If you have information about known problems or recalls for the Ford Ranger, please use the 'Submit Problem / Recall' button below. Use the 'Buyers Guide' button to return to the Ford Ranger Buyers Guide.
