Vehicle Make / Model: Model Year(s):
Manufacturer: FORD MOTOR COMPANY Report Receipt Date: MAR 06, 1984 NHTSA CAMPAIGN ID Number: 84V023000 NHTSA Action Number: N/A Component: WHEELS: LUGS/NUTS/BOLTS Potential Number of Units Affected: 3,320 Summary: COMPONENTS IN THE LOCKING HUBS WERE IMPROPERLY HEAT-TREATED AND MAY CRACK OR FRACTURE UPON ENGAGEMENT OF THE FRONT DRIVE AXLES. THE BROKEN COMPONENT ON THE LEFT FRONT WHEEL MAY BECOME JAMMED AGAINST THE NUT. Consequence: SEE ABOVE. Remedy: CAM ASSEMBLIES IN FRONT WHEEL AUTOMATIC LOCKING HUBS WILL BE REPLACED. Notes: VEHICLE DESCRIPTION: VEHICLES EQUIPPED WITH FRONT AUTOMATIC LOCKING HUBS. SYSTEM: POWER TRAIN; AXLE HUBS, LOCKING. CONSEQUENCES OF DEFECT: THIS COULD CAUSE THE NUT TO COME OFF AND RESULT IN LOSS OF THE LEFT FRONT WHEEL, CAUSING LOSS OF VEHICLE CONTROL AND AN ACCIDENT.
If you have information about known problems or recalls for the Ford Ranger, please use the 'Submit Problem / Recall' button below. Use the 'Buyers Guide' button to return to the Ford Ranger Buyers Guide.
