Vehicle Make / Model: Model Year(s): FORD / RANGER 1983-1984 Manufacturer: FORD MOTOR COMPANY Report Receipt Date: JUL 09, 1984 NHTSA CAMPAIGN ID Number: 84V082000 NHTSA Action Number: N/A Component: FUEL SYSTEM, GASOLINE: STORAGE: TANK ASSEMBLY: FILLER PIPE AND CAP Potential Number of Units Affected: 302,500 Summary: IF TRUCK IS STRUCK FROM THE SIDE, THE CAP ON THE FUEL TANK COULD BECOME UNSEALED, ALLOWING UNSAFE LEAKAGE OF FUEL. THIS IS A FAILURE TO COMPLY WITH THE REQUIREMENTS OF FEDERAL MOTOR VEHICLE SAFETY STANDARD 301, "FUEL SYSTEM INTEGRITY". LEAKAGE CAN BE CAUSED BY AN ORANGE-COLORED PLASTIC DIESEL FUEL INFORMATION RING WHICH IS FOUND AROUND THE FUEL TANK NECK, OR BY THE TETHER. Consequence: SEE ABOVE. Remedy: UPON INSPECTION, FUEL CAP TETHERS WILL BE REPLACED OR DIESEL FUEL INFORMATION RINGS WILL BE REMOVED. Notes: VEHICLE DESCRIPTION: TRUCKS EQUIPPED WITH MID SHIP FUEL TANK, TETHERED FUEL FILLER PIPE CAPS OR DIESEL ENGINES. SYSTEM: FUEL; FUEL CAPS (LOCKING AND NON-LOCKING). CONSEQUENCES OF DEFECT: LEAKING FUEL COULD CAUSE A FIRE IN THE PRESENCE OF AN IGNITION SOURCE AND COULD RESULT IN PERSONAL INJURY TO VEHICLE OCCUPANTS OR BYSTANDERS.
If you have information about known problems or recalls for the Ford Ranger, please use the 'Submit Problem / Recall' button below. Use the 'Buyers Guide' button to return to the Ford Ranger Buyers Guide.
