Vehicle Make / Model: Model Year(s):
Manufacturer: FORD MOTOR COMPANY Report Receipt Date: SEP 24, 1985 NHTSA CAMPAIGN ID Number: 85V116000 NHTSA Action Number: N/A Component: ELECTRICAL SYSTEM: WIRING: FRONT UNDERHOOD Potential Number of Units Affected: 7,886 Summary: THE ELECTRONIC ENGINE CONTROL WIRING HARNESS INSULATION MAY BE DAMAGED DUE TO COPPER SPIKES PRODUCED DURING THE WELDING OF ITS WIRES. THIS CREATES A POTENTIAL FOR A SHORT CIRCUIT BETWEEN THE WIRES WHICH ENERGIZE THE FUEL PUMP, CAUSING SOME FUEL INJECTORS TO OPEN, DISCHARGING FUEL INTO THE ENGINE. CONSEQUENCE OF DEFECT: FUEL DISCHARGED INTO THE ENGINE WOULD EVENTUALLY LEAK THROUGH THE EXHAUST SYSTEM TO THE GROUND. THIS COULD RESULT IN A FIRE IF A SOURCE OF IGNITION IS PRESENT. Consequence: SEE ABOVE. Remedy: REPAIR WIRING HARNESS, CHECK ENGINE AND CATALYST FOR DAMAGE. Notes: VEHICLE DESCRIPTION: LIGHT TRUCKS EQUIPPED WITH 2.9 LITER ENGINE. SYSTEM: ELECTRONIC ENGINE CONTROL WIRING HARNESS.
If you have information about known problems or recalls for the Ford Ranger, please use the 'Submit Problem / Recall' button below. Use the 'Buyers Guide' button to return to the Ford Ranger Buyers Guide.
