Vehicle Make / Model: Model Year(s): FORD / RANGER 1990 Manufacturer: FORD MOTOR COMPANY Report Receipt Date: DEC 22, 1989 NHTSA CAMPAIGN ID Number: 89V234000 NHTSA Action Number: N/A Component: VEHICLE SPEED CONTROL Potential Number of Units Affected: 4,000 Summary: THROTTLE LEVER MAY CONTACT THROTTLE BODY AIR INLET TUBE, WITH THE POTENTIAL FOR THROTTLE REMAINING OPEN FOLLOWING RELEASE OF THE ACCELERATOR PEDAL FROM THE FULL-THROTTLE POSITION IN TRUCKS WITH 4.0 L ENGINES. Consequence: UNCONTROLLED ACCELERATION COULD CREATE LACK OF CONTROL AND CAUSE AN ACCIDENT. Remedy: MANUFACTURER WILL REPLACE AIR INLET TUBE WITH NEWLY DESIGNED REPLACEMENT WITH AN INCREASED THROTTLE LEVER-TO-INLET TUBE CLEARANCE. Notes: SYSTEM: THROTTLE LINKAGES AND CONTROL. VEHICLE CATEGORY: LIGHT TRUCK.
If you have information about known problems or recalls for the Ford Ranger, please use the 'Submit Problem / Recall' button below. Use the 'Buyers Guide' button to return to the Ford Ranger Buyers Guide.
