craveman85
- Dec 2, 2009
- 1
- Age
- 36
- new york
- ford, AMC
- Engine Size
- 2.3l, 2.5
Have an 08 2.3 stick. My battery light started occasionally coming on with no ill symptoms. I tested my battery myself at 12.6 volts even after it sat for a day. Cranking drops it to 10.5 when it was 15° out which is still in spec for a good battery. Most of the time charging it's around 14.6 when I start it then drops to 14.0-14.3 volts. Then on my way to work the other day the lights got really bright, the heater blower started really pushing air, the battery light came on and my passenger airbag off light started turning on and off. Had my battery load tested at a parts store and it's fine. Only a year old anyways. My alternator also tested fine. I was going to buy a new alternator originally because I couldn't find a voltage regulator for it and thought it was inside the alternator. The parts guy told me that the ranger voltage regulator is in the ecm. That would explain the light going off too. There's no check engine light on. I hand a scangauge 2 for monitoring things but I can also check for codes. It says no codes found/not ready. Like you disconnected the battery and need to drive it. However this was before my battery was tested and hasn't been disconnected for about 12000 miles before that. After i had it tested I did go through and clean all battery connections I could find and also added 2 more ground wires just in case. I did have one day where I didn't have enough juice to crank the engine over and that was the day of my voltage spikes. Every time I check my battery it's at 12.6ish with a multi meter.
The parts guy told me dodge people have the same issue and bypass the built in ecm regulator and use an old style voltage regulator. Have any of you guys done this? A general how to would be great. I'm not sure if I want to get a new ecm and have it re flashed at a dealership. But if I could make the regulator work I could continue my 80 mile daily commutes until my inspection runs out next year and I decide what to do. It's a good truck but it's got 180k on it. Needs a steering rack, rear springs and shocks, lower control arm bushings, fuel pump because the check valve in it is bad...
