08 FX4 SAS
Mr. Bossley
167
Kelowna BC
Solid Axle Swap 4x4
Around 6-7"
38x15.5
Shocks and Steering Stabilizer are in. Next up brake lines.
Mr. Bossley
167
Kelowna BC
Solid Axle Swap 4x4
Around 6-7"
38x15.5
Well its pretty much done. Just a couple of finishing touches. Getting some bad tie rod roll. Gonna throw in some of those delrin tie rod spacers. Still have to mount my front driveshaft and t case skid. Then take it to the muffler shop and also get an alignment.
Oh and I have to trim the bumper a bit cause somehow my friend convinced me to get 38s...
38 x 15.50 15 Mud Grapplers
Here it is.
Uncle Gump
Token Old Guy
13,457
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Nice… looking forward to some action photos.
It was brought up in another thread a couple days ago... AOR now offers an extended front skid plate for their front bumper. Not sure I will buy one or perhaps copy what they've done.
Mr. Bossley
167
Kelowna BC
Solid Axle Swap 4x4
Around 6-7"
38x15.5
Its a 4wd again finally! Getting close to a test run. Just need the cure for my steering, exhaust, and rear shocks.
Mr. Bossley
167
Kelowna BC
Solid Axle Swap 4x4
Around 6-7"
38x15.5
Some flex shot. Checking clearances. Had more to go but ran out of tires. Hi-lift wasn't tall enough either lol. I'll try again on the forklift when I take it to work. Rear doesn't rub at all. Front bumper has to be trimmed a bit.
Mr. Bossley
167
Kelowna BC
Solid Axle Swap 4x4
Around 6-7"
38x15.5
Exhaust is all in. Took it for its first drive yesterday. Not bad overall. Steering all over the place but the cure, alignment and steering stabilizer should make that better. I hope.
And it still fits in the garage! Barely
Uncle Gump
Token Old Guy
13,457
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
This truck has been the never ending evolution... lol
Hopefully you have it to a spot where you can just go have some fun and enjoy the beast. Nice work...
09fx4guy
176
USA
Pre Key w/ #1 Bars
265/70R16
Absolutely fantastic job, looks amazing.
Bracket racer
Canada Military - Veteran
235
Socialist republic of Nova Scotia Canadastan
Ranger supercab
Crap load
35X12.5 (bald so I don't break parts)
Low range in Nova Scotia on YouTube!
WOW, what a beautiful build! Excellent fab work...kind of feel embarrassed about the crap I post....
Nice clean truck and the work is being done the right way, not cobbled together. Very impressed.
Rust free BC...sigh....
Mr. Bossley
167
Kelowna BC
Solid Axle Swap 4x4
Around 6-7"
38x15.5
Thanks everyone.Took it out for the first time last weekend. Little test run to see what still needs to be done.
Looks like the front springs settled more than I thought and the tires rub pretty bad. So I have some 1.5" coil spacers to put in the front to level it out. Also going to trim more out of the front bumper.
The doubler popped out of gear a couple times when under heavy load so I think I just need to tighten the shifter adjustment a bit.
Still have to figure out the steering slop. The tie rod rolls bad. The cure didn't fix it so I need to look into other options. Should have gone to crossover steering i guess.. Its not bad off road but on road its a bit scary.
Then I need to get my skid plates and sliders on and get an alignment.
Just little stuff left. But for the most part everything is working well. Rides nice and doesn't make any weird noises.
Uncle Gump
Token Old Guy
13,457
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
That second picture really shows the spring sag.
Those are some big-o tires!
Mr. Bossley
167
Kelowna BC
Solid Axle Swap 4x4
Around 6-7"
38x15.5
Ya it sure does. The truck wasn't sitting on level ground so it looked a lot worse than it was. I got it solved now though. Just threw in a couple of spacers. Truck sits exactly where I want it. About a 3/4" higher in the back with no tent mounted. Also trimmed the bumper a bit more and no more rubbing.
These are definitely the biggest tires I've driven on. Even with the 5.13s it feels slow up the hills. But the traction off road makes up for it. Just gonna take some time getting used to.
I took it out for a good wheel last night and found some deep snow. Over 3 feet in some spots. It did really well overall. The doubler stays in gear now after I tightened the shifter up. And I love the manual trans. Waaay better. So much more control over my wheel speed. I was able to really crawl. Not dig myself down and get stuck.
Only issue I had last night was with my power steering. The brand new pump was making a constant ticking noise a couple hours in. Fluid is full. Maybe there is air in the system, maybe is was getting hot, or maybe the pump just cant keep up. Not sure yet. But either way i'll be looking into upgrades. I'd love to get a saginaw pump in here some how but haven't seen anyone who has done it on the 4.0 SOHC. If anyone has any info let me know. Ill keep searching the forums.
As for my tie rod roll issue, i'm gonna switch to over the knuckle steering to reduce my drag link angle. Then get it aligned, see how it handles and go from there. That's the cheapest and easiest option for now.
twoll86
9
caseyville,il
What’d you do with the take off parts?
Mr. Bossley
167
Kelowna BC
Solid Axle Swap 4x4
Around 6-7"
38x15.5
