1.9 turbo diesel
hummer_maxxer
New member
hey guys thinking of putting a 1.9 vw turbo diesel in my ranger, the mechanical one. just wondering on what trannys i can run behind them and also what kinde of horsepower and torque that i could get out of it. im hopping to have atleast 200 hp and around 350 ft lb. wondering if it possible and what kinde of upgrades i would need??
Rock Auto 5% Discount Code: 57CD9601BD5AB4 Expires: July 1, 2019
Captain Ledd
Well-known member
37
Michigan
302, 2.3
If you're not making mistakes, you're not learning.
I was well on my way for that very swap, then got laid off.
I really don't think you're going to hit those numbers unless you know exactly what your doing (I.E.,there's no reason you would ever need a message board), or spend some very serious $$$ on a professional tune and rebuild, at least if you want to see any real life-span out of it. Even then you're running it close to max, and a good chance it'll blow up anyways.
A mechanical engine would not come close to the numbers of a computer controlled engine.
A simple chip would get you to around 110 HP and 180 lb/ft ish of torque (Up from 90 HP and 160lb/ft). You can squeeze a tiny bit more out with injectors before you really start smoking (and at that point you're just wasting fuel). Crank her up a little more and you're going to be doing mechanical upgrades / rebuilding it.
There are no RWD tranny's (stateside) that bolt up to the 1.9L TDI to my knowledge. You will need an adapter.
There was a guy in Canada that had one in his '97 Ranger.
zukirider21
New member
5
NJ
2.9
why??? i could get better performance out of an early ranger perkins with a turbo, injectors, and a pump. all while being 10x as reliable. AND, its basically a bolt-in deal.
Captain Ledd
Well-known member
37
Michigan
302, 2.3
Huh?
Try finding parts for that engine. And no, they're not nearly as reliable. They're an industrial engine cranked up with barely enough power to move the truck around. The VW diesel is intended as an automotive engine and has a rather long service record and much more massly (is that even a word?) produced, as compared to only a few ever manufactured diesel Rangers, usually in dire need of a rebuild or with cracked heads.
Usually I make an attempt not to criticize others ideas, but I truly believe that 10x reliability is completely unfounded. There is also WAY more thought and tuning involved than the mods you suggested to achieve his desired power. And it's only bolt in if you are very lucky and find a complete, working, truck.
TwoWhels
New member
Saginaw, MI
This is what I want to do also.
Do you have the VW engine?
How about the Ranger?
I have an extra 2.9 belhousing
and a 1.5 VW diesel ... same bolt pattern as the 1.9
I can get my machine shop to make adaptor kits
Anyone in
Captain Ledd
Well-known member
37
Michigan
302, 2.3
Nope, was in the process of saving for it, but pretty much all of that is gone now. I still had some other parts to track down as well. Though in the meantime I'm still re-arranging my shed so I can actually accomplish the swap in an actual legitimate time span lol.
I did some work for friends, and combined with all the new tools and parts I acquired for my other Ranger (see sig), I was pretty much left with a 2'x2' work bench area lol. I have things laying out under towels because I have no where else to put them.
The VW engines really are one of the best for swaps. Power, weight, economy, aftermarket support. Back when I first started researching diesel swaps (years ago) they were still working out the bugs swapping them, only a few had trickled into the junkyards. They've really come a long way as to how to set them up.
It'll probably take me a year to get back to where I was. :bawling::bawling::bawling::bawling::bawling:
Sunk
New member
124
Everett, WA
3.5 Eco
I believe the 1.9 is a common ( or at least heard-of) swap for some yota and sami guys so you may have more luck searching through that realm.
I have a friend swapping an early 80's Mercedes 5 cyl diesel into his 92 4Runner, and it bolted up to the stock tranny after re-drilling the flywheel and/or an adapter. I know nothing about the motor, just that he's doing it.
hummer_maxxer
New member
so what kind of numbers can i expect from the 1.9 this is gona be for a trail truck. already started the project with the rear 4 link, next is the 609 with custom radius arm and then comes the motor. im thinking 5 13 gears and probly about 40s. im a gona be good to turn them ??
dangerranger83
5.0 HO under the hood!!!
51
Lafayette, IN
5.0 HO carbed with an np435 and np208
Theres a guy on youtube (daves farm) that did this swap to his dodge mini van and he said hes getting 35 mpg with it. From the looks of it he has had great luck with it in his van and he shows him driving it and it doesnt look like it lugs around. He got his engine for free.
zukirider21
New member
5
NJ
2.9
Huh?
the perkins is far from "cranked up" in stock form. the thing is, in order to make power with the perkins, you need to be very "crafty" i guess you could say. a metric sh!t ton of parts (bigger pumps and injectors) for example will interchange with other industrial perkins engines. there are turbo versions of the engine and something could easily be rigged up. before i decided on the 302 swap, i wanted a diesel ranger BAD. and after speaking to numerous friends in the industrial/heavy duty diesel field we've concluded that 200+ reliable horses are possible out of that motor...
keep in mind, the perkins motor has MUCH heavier castings than the vw motor since it's intended for industrial use. this construction lends itself to higher performance setups.
while all of that sounds great, the number one reason i'm for the perkins is because its such a simple, practically bolt in install.
bobbywalter
TRS Technical Staff
62
woodhaven mi
FORD
BIGGER
you are firmly in 4bt territory with those goals. unless you can keep the weight down under 3500. or you only need to do slow technical wheelin.
power numbers can be made but tire speed and the amount of time an engine is maxxed out puts the 1.9 out of the picture in my eyes. the 1.9 is ideal for a small low 2wd though.
there is a specific reason i put a 6.5 diesel in my ranger....overall use and the engines simplicity and operating charactoristics and the fact it was free were the biggest factors
hummer_maxxer
New member
well i guess since the 1.9 is out of the question il go with a 6bt. easier to find and makes more power then the 4bt
dangerranger83
51
Lafayette, IN
And much heavier meaning your front end will have to be upgraded too.
hummer_maxxer
New member
ya a few post up i say that im putting in 609 and custom radius arm suspention
bobbywalter
TRS Technical Staff
62
woodhaven mi
FORD
BIGGER
if you can handle 40's.......you can handle a 6bt.
but that does push the thought.....i would never run a diesel in a rig that sees mostly trail work. especially a huge clattering bastard.
my reason for diesel was pure economy and alternative fuel capacity.
