BrownRangers
- Aug 20, 2019
- 49
- Burbank, CA
- Ford Ranger
- Engine Type
- 2.8 V6
- Engine Size
- 171cui
- 2WD / 4WD
- 2WD
- Total Drop
- 3"
- Tire Size
- 245/40/15
1984 Ford Ranger 2.8 2wd with 4 gauge left dial, has fuel, oil p, water t, and amp.
When cold under 60 degrees(CA cold) gauges work fine. Sometimes will go out as truck gets hot or temps get hot. Also wont work if truck is then parked when engine hot and outside temp is hot. Next time you start(say after running into a store) gauges wont work.
When hot, even just ambient temp, say 80 plus, the gauges do not work even at start up.
Any tips?
Any tips?
