RangerTony
- Sep 9, 2019
- 0
- Reno
- Ranger
Hello all, and thanks in advance. I really need some help, and it's getting down to the wire. I've had my '86 Ranger here in Reno at Greg's Garage for almost a month. The tech there can't seem to figure out what the idle issue is, and nor could I. I'm nearly ready to take the truck back and try again. Here's the symptom: It starts up great, warms up, and then the idle goes buggy. Yeah, first thing that comes to mind is the IAC. I've tried two after market units, and because I was told there's a potential problem with those in the electrical circuits, I went to the salvage yard and got a Motorcraft unit. That was over a week ago, and I haven't heard from Greg's Garage. This engine has 10K on it, and I've replaced the following: O2 sensor, IATC sensor, MAP sensor, Fuel Pressure Regulator, high-pressure fuel pump, Throttle Position Sensor, ECM, Ignition module, rotor cap... (I hope I didn't forget anything). I'm thinking there may be a bad wire to a sensor, and I did make the mistake of piercing (slightly) the wires to the TPS and the IATC, and the MAP sensor, and read voltages that seemed to be okay. I don't know if I should dive into the wiring and unplug the sensors and search for a break.... or what? I need this truck before the rain comes. My emergency car is a convertible and the top is shot. Thanks for any help you can offer.
Tony
I
Tony
I
