1988 Bronco II ICM
DGambz
New member
british columbia
Hey i'm new to the forum, I just got a 1988 Bronco II XLT from my grandpa. I need to change my ICM but i cant seem to find where it is. Any help would be awesome!
Rock Auto 5% Discount Code: CFB3B5F7F32B37 Expires: March 30, 2020
Well-known member
1,065
Welcome to TRS :)
1988 2.9l engine ICM(ignition control module) is on the side of the distributor, it is called a TFI module, not at all hard to find
You want to match the color, black or grey are the two options, there is a wiring difference, so if yours is grey then you want to replace it with a grey one, same for black
The PCM(engine computer) is a little harder, but refurbished are available
BIIs and Rangers with 2.9l engine used the same PCMs by year
Transmission type is the thing you need to match, manual or automatic
1988-1992 2.9l engines didn't have EGR so not an issue
This PCM is for 1988 2.9l manual trans: https://www.ebay.com/itm/Engine-Control-Module-ECU-ECM-PCM-Engine-Control-Computer-fits-1988-Ranger-2-9L-/163043518463#vi-ilComp
Automatic here: https://www.ebay.com/itm/Engine-Control-Module-ECU-ECM-PCM-Standard-Reman-fits-1988-Ford-Ranger-2-9L-V6/222684659117?fits=Year:1988|Model:Ranger|Make:Ford&hash=item33d90a3dad:g:PiMAAOSwi~FboMBQ
RWD or 4x4 doesn't matter in 1988
