Chuckc
- Aug 21, 2019
- 2
- Florida
- Bronco ii
Okay so I have a 1988 bronco ii with the a4ld automatic transmission. Went bad took it apart forward gear is torn up along with planetary gear. Rebuild kit with bushings bc mine are tore up plus used forward gear on eBay bringing me over 500$ to rebuild.. searched junkyard and can find plenty 2wd newer a4ld seems newer one has different electronic connections.. my question is can I make a 2wd a4ld with different electronic connections work? Looks like I can take off adapter for 2wd and swap in spacer between trans and tranfer case. And if not are internal parts the same (forward gear) to swap? Please help, thanks.
